Question about Aquabot Pool Rover Above Ground Robotic Pool Cleaner
Pool rover JR running slow
Had my pool rover jr about 2-yrs,,been working great...filter clean..
beginning to run slower??..could my PUMP be slowing down?.......
  • Anonymous Apr 08, 2009
    hayward pool sweep run slow some time not at all.
  • Anonymous May 08, 2009
    In second year, my pool rover suddenly stopped working!!!
This has happened to me several times. Hair can get caught on the impeller. This causes the flap inside the jet to not close completely. Unplug the unit, remove two screws off the jet exhaust and gently remove the hair.
Posted on Aug 28, 2009
Power supply fuse blows
either shorted cord or bad power supply if only when unit in water shorted cord or bad motor
Jun 24, 2013 | Aquabot Pool & Spa
Slow running water at the return of in ground pool
Maybe your local Pool repair shop is useing a 'super-soaker' water gun to jet milk into your pool at night hence drumming up business. Don't laugh I heard of some doing that. You mentioned this occured after you cleaned, maybe you dislodged something that found it's way into the intake that is causing a blockage. Check all valves and filters again, there may have been something that was in pipe and has now found it's way to the filter. You mention that the pressure is up. If the gauge is on the outflow side of the pump then the blockage is between the pump and the outflow to the pool.
Jun 04, 2013 | Hayward Pool & Spa
Pentair pump flow slows during operation
go to utube see the video on your pump programming sounds like you have the run time on 1200 rpm
Nov 17, 2012 | Pentair IntelliFlo VS-3050 & VS+SVRS...
The water flow from my pump slows to almost nothing after 5 or 10 minutes. I change the filter and it has a great flow for a few minutes then slows to a trickle.
There are screens at the hose connections to the pump and at the inside pool outlets and inlets. Check to make sure their clear. Also be sure your using a New filter not one you have cleaned off.
Jun 25, 2010 | Intex Krystal Clear Model 635 Pool Filter...
How deep does the water have to be for the pool rover jr.?
If this is the type of cleaner that runs with a long hose connected and has one end stuck in the skimmer, the pool will need to be completely filled to normal level. The pool is filled with crud right? Use a long extension pole with a leaf net on the end to get out all the stuff you can. There is no way around the hard work. Don't be surprised if you need to use quite a few bags of powdered chlorine or jugs of liquid chlorine to clear the water up. Don't give up, it's gonna be hot this summer.
May 23, 2010 | Aquabot Pool Rover Above Ground Robotic...
Aquabot Pool Rover Above Ground Robotic Pool Cleaner Logo
1,362 people viewed this question
Top Aquabot Pool & Spa Experts
Ian Summerfield
Ian Summerfield
David Spradling
David Spradling
Robco Water
Robco Water
Are you an Aquabot Pool and Spa Expert? Answer questions, earn points and help others
