Question about Delta Plumbing
Bathroom weltec washerless faucet for rp1740 reinforcement body
5 Suggested Answers
SOURCE: dripping faucet
Take a cloth and lay over the top of the stem so as not to damage it. With pliers, grasp the top of the stem and turn it a quarter turn counter clockwise. The stem should lift right out.
Posted on Mar 14, 2009
  • 297 Answers
SOURCE: waltec washerless faucets
i cant draw it for you but the spring fits inside the seat and the seat goes in the hole last. in the hole goes the spring then the seat goes on top then the stem.put the seat on a small screw driver,then the spring then slide it all into hole, try it good luck.
Posted on Jul 29, 2009
  • 251 Answers
SOURCE: bathroom sink faucet,(washerless) has a drip when
http://www.housetask.com/Leaky_Faucet_Repair.htm
a repair kit/cassette
most decent plumbing centres will be able to match up the old cassette
Posted on Oct 21, 2009
  • 1739 Answers
SOURCE: I need the cold water stem for a American Standard
American Standard has an on-line Repair Parts centre:
http://www.americanstandard-us.com/store/repair-parts/
Posted on Mar 23, 2011
Water continuously is running
Single handle? Two handle? Washerless? Bathroom or kitchen?
Nov 28, 2013 | Plumbing
Tip
WASHERLESS FAUCETS A leak in a washerless faucet usually indicates that the...
WASHERLESS FAUCETS
  • A leak in a washerless faucet usually indicates that the working parts need replacing. Often, prepackaged repair kits are available. Kits may contain all the necessary parts, or may include only the specific parts that need replacing. Follow the instructions for installing the replacement parts. Washerless faucets on tubs and showers are repaired in the same way as those on sink and washbasins.
on Jan 16, 2010 | Plumbing
Dripping water unless I totally shut off cold water line.
If you will make contact with George at M-One-Specialites he can track that down for you and help you get that fixed.
He has a very extensive list of repair parts for faucets.
Rod
US Parts Center
Jan 29, 2013 | Kohler K-12265-4-CP Fairfax Widespread...
Dripping facet
If a faucet is leaking the necessary repair will be either:
1. For a ceramic or washerless faucet, replace the cartridge.
2. For a typical old fashioned faucet, open the faucet, replace the washer (and packing if it has any) and verify that the faucet seat has not eroded.
The newer washerless faucets cannot be repaired except by replacing the cartridge. Cartridges for most common faucets are available at most home improvement stores or plumbing supply houses.
It sounds a lot more difficult than it really is, just shut off the water (usually a shut off valve under the sink). After the water is off, remove the handle and any chrome protective covering. Depending on the faucet type, it may be a little difficult to remove the cartridge since they are often covered with mineral build-up or corroded into place.
Once you remove the old cartridge the new one usually goes into place easily.
NOTE!!!
For single handle faucets, make sure you put it in the right way, some of them will put the hot to the wrong side if you put them together backward.
Mar 13, 2011 | Home
Bathroom sink faucet,(washerless) has a drip when closed. what part do I need to fix this. Gerry
Oct 21, 2009 | Plumbing
When I installed my delta replacement cartridges, RP1740 two handeled faucet, the water will not turn off no matter which way I turn the handle. I have a new rubber cup and spring. It looks so easy, I must...
Sounds like you might have the rubber cup seals installed upside down? The spring goes int he body first, then the cup seal goes over and on top of the spring.
Jun 25, 2009 | Delta Plumbing
Dripping faucet
Mar 14, 2009 | Kohler Model 102704A: FortĀ® Centerset...
Plumbing Logo
61 people viewed this question
Top Delta Plumbing Experts
Donni Steen
Ed Mac
bwbconstruct
Level 1 Expert
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
