Jvc tv circuit diagrams
Pin caution
    Top Expert:
  • Televison & ... Master
  • 74,243 Answers
What is the model number that you wants circuit diagrm?
Posted on Apr 24, 2013
Can I have a diagram for TV JVC Model AV-21MT35? Anybody can help, thanks in advance.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Circuit diagrams of many popular brand TVs are given.
Sep 27, 2015 | JVC Televison & Video
Tv circuit board diagram repair
I've the schematic diagram, but it can't be send it to you by this windwo. It is a PDF document.
Apr 25, 2013 | JVC Televison & Video
JVC TV keeps turning on and off
The on button activates a micro switch (all the front controls) and you would have to unsolder that switch to take it out of circuit----two pins.
If taking it out of circuit allows set to work just use a remote.
May 20, 2012 | JVC AV-32920 32" TV
Wiring diagram and board lay out for jvc lt42x579 tv
I have the copy of JVC LT-42X579 service manual that covers the following :
precaution
specific service instructions
disassembly
adjustment
troubleshooting
wiring diagram
block diagram
circuit diagrams
pattern diagrams
voltage charts
waveforms
using p.w. board & remote control unit
exploded view parts list
exploded views
printed wiring board parts list
remote control unit parts list (rm-c2050-1c)
packing
packing parts list
If you want the copy click it HERE.
Jdvillanueva
Sep 29, 2011 | JVC LT-42X579 42 in. LCD TV
Pin cushion falt
Circuit diagrams are available online from 5-20 dollars. I doubt it will do you much good, as you will need to be an expert at tv repair in order to read the diagram, and trace the problem. It sounds to me like a bad capacitor near the horizontal deflection circuits, or a resistor near the pincushion adjustment could have blown. If you really want to learn how to fix your tv, you should visit some learning websites that explain the different areas of a tv circuit board and their functions.
Dec 06, 2008 | Philips Magnavox 27MS343S 27" TV
GET PHILIPS CIRCUIT DIAGRAM
mi brothers,help mi, diagram panasonic/ tv /TC-36SX31 /circuit pin 13 off fly back ,tank you>>> pokedy@hotmail.com ///
Jun 18, 2008 | Televison & Video
56" jvc projection
You need to re-solder the circuit board that contains the STK convergence modules. They're on the center circuit board attached to an aluminum heat sink that's about 8" long and 6" tall, about dead center in the circuit board. You may be able to recreate the problem (hour glass effect) by gently moving the heat sink (which the modules are connected to). This gives the hour glass effect on the picture and the advanced convergence screen. This is an indication that the modules pins aren't solidly connected (meaning soldered) properly. Remove the circuit board and clean the old solder off & resolder the modules pins to the circuit board reconnected the board and then retest by again pushing on the heat sink. This is a caused by a minimum effort (a.k.a. minimum cost) solder job, probably done in some 3rd world sweat shop. The "factory" job was good enough for 3-4 years but the heat (and these modules do create a lot of heat) and stress created from repeated use eventually takes it's toll, weakens the pin connections and our problem occurs. take the appropriate cautions working around the high voltage of the set & use a non-conduting piece of wood to push the heat sink when we doing tests. Best of luck, hope ya fix it.
Jan 31, 2008 | JVC AV-56WP74 56" Rear Projection...
JVC C-21MU1 / High Voltage Problem
Try checking the filter in the 116v line. You may have an intermittent spike coming through the B+ line.(The filter may have decreased in value) Also a small filter in the X-ray circuit could have lost capacitance. There is a low value capacitor (about .047uf @400v) in the collector circuit of the horizontal output transistor that will detune the horizontal circuit causing the HV to go too high. If this cap is intermittent it may be causing your problem. Stargazer Hope this helps
Aug 25, 2007 | JVC AV-28-BD-5-Bl 28" TV
JVC model AV 278p6 standard television
I'll bet you have vertical output IC with some pins not soldered. This IC ( integrated circuit) is a "chip" that makes the picture fill out from top to bottom. After a period of time heat will cause the pins to crack loose on the circuit board. You need to have a tech check it for you. Stargazer
Aug 16, 2007 | JVC AV-27530 27" TV
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
