Desktop smps when i on the machine SMPS runs 5mint and then stops working... what are the steps to overcome from this probltem
  • Computers & ... Master
  • 5,660 Answers
Problem is one of the following three listed; or can be -> 1), and combined with the others;
1) FOLLOWING Anti-Static Procedures, clean the inside of the computer out.
The Processor (CPU) is overheating, and turning off. (BIOS turns it off)
2) Replace the Power Supply.
Power Supply is ready to go out.
3) Bad capacitors on the motherboard,
http://capacitorlab.com/visible-failures/index.htm
http://www.youtube.com/watch?v=Lut7MX5Dd_A
If you do NOT know what Anti-Static Procedures are, DO NOT reach into your unplugged from power computer; UNTIL you do.
Post back in a Comment.
Regards,
joecoolvette
Posted on Apr 24, 2013
map9966
  • 2351 Answers
SOURCE: no beep no display but fan is steel moving
Hi Rajesh_KS
How many beeps did you hear? It matters. Every Bios has a name. (Award, AMI, Phoenix, IBM ect).
You'll need to enter your bios & check the name. It will be at the top of the menue or you can catch it just as your PC starts up.
Once you know the name of your bios & how many beeps you hear, Ex: 1 long 2 short & repeating. You'll know just what the problem is with regaurds to the memory.
I'll post a link for bios beep codes. All you'll need is the name.
Regardless of the error, it's suggested you remove your memory & than re-seat it. You will not get video display if your memory has a problem.
Here's the bios link: http://www.bioscentral.com/beepcodes/awardbeep.htm
On the right side of the page other manufactures bios's are listed & each have their own code system.
Support link for your Acer:
http://support-web.acer-euro.com/app/csd/etkdb.nsf/4b7a708d8dbc41cdc1256bd6003c0165?SearchView&SearchView&Query=Veriton%207700G&start=1&count=10&seq=1
You can also test your memory if re-seating did not help.
Go to this link:
http://www.memtest.org/
Scroll down till you see ** Memtest86+ V2.01 (21/02/2008) **
all typed in red. You can download a bootable CD program to test your memory. File; Download - Pre-Compiled Bootable ISO (.zip)
If you rather use bootable floppy disk, File; Download - Pre-Compiled package for Floppy (DOS - Win)
Good luck & Kind Regards!
please vote ;-}
Posted on Mar 09, 2008
bharrie
  • 158 Answers
SOURCE: AsRock Motherboard won't boot. Need Advice.
Here's the solution!
Check if NUM lock glows if tapped on the Keyboard ::
Yes - If your Power LED is blinking change the SMPS, if it is Solid, change the I/O cables or RAM or Display Adaptr - whichever you think the problem to be.
N0 - Change the board.
PS. If processor is the problem, CPU fans won't spin in the first place.
Posted on Jan 10, 2009
arpit47
  • 162 Answers
SOURCE: SMPS Fan not rotating fully
you can check that how much time you spent with the SMPS if it is more then 2-3 years then change it because it is damaged in 2-3 years and after changing then also not work then you go to mechanic and checked your motherboar
Posted on Jun 29, 2009
anandsharad
  • 137 Answers
SOURCE: dell smps ps-5141-2d pin layout
145 watt smps was shipped in very very old computers, its not manufactured any more. how ever you may still want to try for best buy. 1% chance you may get it. i searched everywhere its images are not avilable. the pin layout inside and outside is the same. as in 180 or 200 watt smps. repairing is not a good option. get it replaced if its okay with you. please tell me the system model number or service tag so i can look for alternative smps for your computer. thanks.
Posted on Oct 17, 2009
Testimonial: "thnks for the soln, i was confuse that it may have pinout changed, thanks again & happy diwali..."
  • 104 Answers
SOURCE: i want to purchase of LITE ON smps model PS 5221 06 AT BANGALORE
Your best best would be to order it online. I found 3 on ebay that is willing to ship to your country. As for local dealers I am not sure. Hope this helps.
Posted on May 27, 2010
No power to hp envy
I suggest you step by step follow check it your Desktop issue.
A> All power plug proper connect or not, if possible change another port.
B> Have your ups get power or not, If ups on then nest step follow.
C> Check it SMPS on or off position. If your power ok and come to smps or smps not start then you SMPS damage position, you check it smps ok conduction or not..
Checking method:
SMPS more wire available you see it one more bulk wire available and black wire and green wire cross check, if not start smps then damge. But my friend if you smps ok or your are wrong wire attach then may be your smps damage. So better contact good Computer Hardware Technician.
Thanks.
Computer Support
Feb 19, 2014 | HP ENVY 23-d065 TouchSmart All-in-One...
Tip
How to check the SMPS in Desktop Computer while the system is Dead Condition
1.Remove the all power jacks from Motherboard before check the SMPS. 2.after removing the SMPS then follow the below steps
i) Short the Green and Black wires with a small conductor(wire) in 20 pins jack of SMPS ii)Now plug the main wire into SMPS
iii) On the SMPS Now see the SMPS fan whether it is running or not if the fan will be run then the SMPS has no Problem else SMPS will be Problem. 3.Change the New SMPS with same ratting of Watts
on Apr 17, 2010 | Computers & Internet
I have compaq power supply "PS2018", Part no
open smps take a pin & insert in green end & th other n black end.so if fan runs u'r smps ok & pc will be ok
else replce by new smps
read here
http://pctells.blogspot.com/
http://mailerror.blogspot.com/
http://faqall.blogspot.com/
http://net2go.blogspot.com/
Feb 18, 2011 | Compaq Computers & Internet
I experience "unexpected shut-down" on
First please check ur SMPS is working correctly. to check the SMPS is working fine or not please shot the yellow and black wire and connect the power cable to the power socket and watch it for 5-10 mins if it is stopping then u change your SMPS
Jan 29, 2011 | Dell Inspiron One 2305 Desktop Computer...
I am able to turn on cpu but the monitor is not displaying it. Power is coming, Two fans are running in C.P.U. Some times fans not work. Kindly suggest me why this happens and give the solution for it.
093aba5.jpgYou have a problem with your SMPS. Kindly send your SMPS to a repairing shop. If the guy suggests you to buy a new SMPS then there is hardly anything that u can do instead of buying a new one. I had the same problem once had to replace the SMPS as even after two repairs the SMPS wasn't working properly. There is a prob with the switching regulator for sure if your monitor works perfectly then.
Sep 24, 2010 | Computers & Internet
Cannot turn on cpu
when you say cannot turn on cpu - what do you mean - ?
cannot boot up?
try removing the cmos battery for a minute then replace and try again.
any error beeps ?
working fine before ?
Oct 11, 2009 | E-Machines eMachines Desktop PC
My Dell Demension 2300 will not power up.
open cpu cabinet then refix RAM.
Reattch all connection to motherbord also check your smps power unit works fine.
may be your smps is gone .
SMPS is aquare box which with you connect power code.
Jul 29, 2009 | Dell Dimension 2300 PC Desktop
Had a power outage and the computer won't come back on. Compaq Presario Desktop - SR1230NX
open CPU cabinet and give power to computer thencheck your smps is working?
it is square box where you connect power code to cpu.
If its running then it is ok.Then check for loose connection from smps to motherbord.
But if its not working then you have to change smps or repair it.
Thanks for using fixya.
Please rate solution if it helps.
Jul 25, 2009 | Computers & Internet
Jun 29, 2009 | HP Computers & Internet
Color Printer fan error
The SMPS Fan Error is caused by slow or no rotation of the SMPS Fan. The firmware solution from Samsung disables monitoring so if the fan stops the printer will keep working. Thankfully, it's not physically hard to fix this issue though and can be done by removing 9 screws and using a little oil.
I've actually posted a step by step guide to fix this here.
Mar 25, 2008 | Samsung CLP-600N Laser Printer
Computers & Internet Logo
David Payne
David Payne
