Question about Interlink Computers & Internet
Model number vp6700r
How do i connect the mouse to my computer? how do i charge the mouse?
My gateway wireless mouse won't sync
- Have you tried the steps mentioned in the link to connect a wireless keyboard and mouse to the Gateway computer? http://support.gateway.com/s/desktop/2009/gateway/zx/zx4800/ZX4800faq3.shtml
http://www.support.gateway.com/s/Manuals/Profile/WirelessKb_MouseGuide.pdf
Also follow the generic troubleshooting steps mentioned in the link to connect a wireless keyboard and mouse to a computer.
http://support.microsoft.com/kb/838398
Note: The steps provided in the link mainly works for Microsoft hardware but the steps can be applied to any wireless keyboard and mouse. Do not install any software given in the link as it will not help you if you do not have a Microsoft Hardware.
It would be helpful if you could provide us the exact computer model number and also the make and model number of the keyboard and mouse.
Feb 14, 2015 | Gateway GM5664 Desktop PC
How to enable a wireless mouse?
No. That model of laptop does not have a special RF transmitter or Bluetooth adapter factory installed, so it has no special way to connect to a wireless mouse. If you have a wireless mouse, and if you wish to use it with this computer, you will need to make sure that the mouse has fully charged batteries, connect a USB receiver for the device to the laptop, wait for the receiver to be recognized by the laptop's operating system and then verify that the mouse is synchronized with the receiver.
Aug 19, 2014 | Gateway Computers & Internet
After ge mouse is left idle for awhile, it wont work. I have tried to press connect on receiver then press connect on bottom of mouse but it stll wont work. what now?
I would try replacing the batteries first of all. If this doesn't fix the problem then uninstall the software and reinstall it. Hope this helps!
Feb 28, 2011 | GE Wireless Optical Mouse
My acer mouse model number mg-0919 stops working after about 2 minutes. I have to turn the mouse off then back on. This happens constantly. What is going on? Is it defective? My mouse is under...
I had the same problem. This mouse came with my Acer Revo which was still under warranty. Tech support basically says to check the obvious (batteries, USB connection, RF interference). Their obviously canned answer goes on to detail a manual reconnect procedure that does not apply to this model. And when all else fails, get a new mouse.
This is what Acer tech support emailed me:
If you are experiencing issues with your wireless mouse not working properly, perform the following steps to troubleshoot the wireless mouse.
1) Ensure that the receiver is 8-inches from other electrical devices. Avoid placing the cordless devices on metallic surfaces.
2) Verify that the USB connector from the receiver is properly plugged into a USB port on the computer. Try plugging the receiver into a different USB port to ensure that the USB port is working properly.
3) Remove the batteries and then reinsert the batteries into the mouse, making sure that the battery polarities are correct.
4) Test the batteries to ensure that they still have a charge.
5) Try the manual connect procedure.
Manual connect procedure:
1) Press and release the Connect button on the receiver.
2) Within 30 seconds, press and release the Connect button on the mouse.
If the issue persists, we can replace your computer's wireless mouse.
We will ship the new wireless mouse within 3-5 business days.
Before placing an order for wireless mouse we would like to confirm the following.
1) Complete shipping address:
2) email address:
3) phone number:
In order to place an order for wireless mouse, the computer must be registered.
Oct 06, 2010 | Acer Aspire One PC Notebook
Does the labtec wireless mouse turn itself off when not in use
You should always safely shut down and turn off your computer before plugging or unplugging the mouse from the PS/2 mouse port. If you do not safely turn off your computer, you may damage the mouse port, the mouse, or both.
Your Labtec mouse should detect and function by simply connecting it to the computer´s PS/2 mouse port or USB port. If you have 3 Button Labtec Mouse (M/N: M-CAC64), your mouse will work in the PS/2 and serial port with the supplied adaptor. If you are using the 3 Button Labtec mouse, we recommend using the PS/2 port. To determine the model number of your device, turn it upside down and look at the label. Model numbers are indicated by "M/N:". This will help you determine what system ports your Labtec mouse can be connected to.
Thank you
Mar 14, 2010 | Labtec Wireless Desktop Keyboard/Mouse...
CRAYOLA MOUSE WONT CONNECT
1. Go to your manufactor's website.
2. There should be a search bar on the top of there website.
3. click in the search bar and enter your model number of the
computer or you can enter hardware model.
4. After you hit you come accross to technical support page click on
that.
5. There should be a word pertaining drivers click on that.
6. Finally, click download and download the correct version of driver for
your windows.
Dec 28, 2009 | Sakar Crayola 12071 Mouse
It will not connect and I can not find the product number anywhere it is a 98812 ge mouse
if you press connect on the bottom of the mouse and then press connect on the USB thats plugged into the computer it should work.
Aug 16, 2009 | GE Wireless Optical Mouse
Install a Logitech cordless mouse on my desktop computer
You didn't say what model it was, so this is general. If it doesn't work, comment back, before rating, with the specific model and I will be more detailed.
Make sure you have good batteries in the mouse.
Plug the receiver into a usb port. try to keep it as close to the mouse as possible. There should be a small connect button on the receiver. Press it. Then there should be a small connect button on (under) the mouse. Press it. The mouse should begin working.
To get the most out of it, you can download software from Logitech Support
Again, if this doesn't work, comment back with the model number before rating. Thanks for using Fixya.
Nov 19, 2008 | Logitech Cordless Mouse
"Cyber" brand wireless rechargable mouse
Okay i got the same problem i did everything press the big blue botton and the one on the bottom of mouse and still nothing....
ITS THE BATTERYS!!!! the ones that come with it are shiet i put some tranisonic ones into and it worked instantly the moment i put "good" ones in the red light came on instantly
Aug 23, 2008 | Computers & Internet
Mouse not functioning
You should have a USB adapter that goes from the Charging base to your computer to make the connection. the wireless is from the base (charging unit) to the mouse.  once you connect your USB it should find the mouse and work. you may need to sync the base unit and mouse to complete the process, by first click the sync button on the base unit then the small sync button found on the bottom of the mouse
Oct 12, 2007 | Logitech MX700 CORDLESS OPTICAL MOUSE...
Computers & Internet Logo
Top Interlink Computers & Internet Experts
David Payne
David Payne
Are you an Interlink Computer and Internet Expert? Answer questions, earn points and help others
