Question about Canon iRC3100 Printer
Canon ir 5870 c showing the error code E000003 - 00051
    New Friend:
Canon IR 5870c showing the error code E000061-0003 please tell me how to remove error E000061-0003
Posted on Mar 09, 2014
  • 199 Answers
SOURCE: Canon IR 3300 switchs on it displays the Erro E000602-0003
replace hard disk drive
Posted on Feb 15, 2009
SOURCE: Canon IR3300 showing the error code E000602-0003
ERROR CODE E000602-0003 what i do
Posted on Feb 08, 2010
  • 199 Answers
SOURCE: canon ir 2200 Error code E000064-0000
E064 The presence of a high-voltage error is communicated by the composite power supply PCB. (The output for primary charging, developing, or transfer
has deviated from a specific level of voltage.)
Main cause The contact has poor connection. The wiring is faulty. The composite power supply PCB is faulty. The DC controller PCB is faulty.
Action
1. Contact
Is any of the contacts of the primary charging roller, developing assembly, or transfer charging roller soiled? Or, is there poor contact?
YES: Clean the contact, and set it once again.
2. Wiring
Is the wiring between the contacts for the following normal: DC controller
PCB (J301), composite power supply PCB (J136), primary charging roller, developing assembly, transfer charging roller?
a. DC controller PCB (J301) <-> composite power supply PCB (J136)
b. composite power supply PCB (J130-7) <-> primary charging roller contact
c. composite power supply PCB (J130-1) <-> developing assembly contact
d. composite power supply PCB (FT133) <-> transfer roller contact
NO: Correct the connection.
3. Composite power supply PCB, DC controller PCB
Try replacing the composite power supply PCB. Is the problem corrected?
YES: Yes.
NO: Replace the DC controller PCB.
Posted on Feb 26, 2009
SOURCE: error code e000007-0000 in caonon ir 3300
my canon ir 3300 shows error e-000007-0000 how can i solve this problem
Posted on Feb 11, 2010
canontech
  • 1219 Answers
SOURCE: canon ir 3530
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
E490 wrong DF type
E500 finisher communication error
E503 finisher internal communication error
E505 finisher backup memory error
E514 stack delivery/trailing edge assist motor error
E519 gear change motor error
E520 off-set motor error
E530 rear alignment error
E531 stapling error
E532 stapler shift error
E535 swing error
E537 front alignment error
E540 stack tray ascent error/upper tray ascent error
E542 lower tray ascent error
E577 paddle error
E584 shutter error
E590 punching error
E591 puncher dust sensor error
E592 punch horizontal registration sensor error
E593 punch shift error
E5F0 saddle paper positioning error
E5F1 saddle paper folding error
E5F2 saddle guide error
E5F3 saddle alignment error
E5F4 saddle rear stapling error
E5F5 saddle front stapling error
E5F6 saddle butting error
E5F8 saddle connector error
E5F9 saddle switch error
E602 hard disk error
E604 image memory error/shortage
E609 hard disk error
E610 herd disk coding key fault
E674 fax board communication error
E710 IPC initialization error
E711 IPC communication error
E716 communication error for pedestal/ communication error for 3-way unitA1
E717 communication error for NE controller
E719 coin vendor error
E730 PDL software error
E732 scanner communication error
E733 printer communication error
E740 Ether board error
E743 DDI communication error
E744 language file/boot ROM error
E745 TokenRing board error
E746 accessories board wrong model error
E748 controller board and SDRAM size mismatch
E805 fan error
Posted on May 04, 2010
Replaced drum & developer bizhub42, how to clear counters
as you have not mentioned the brand and the model number i assume you are using canon ir series
how to counter clear In Canon Ir 5870 5800 photocopier
Oct 29, 2016 | Office Equipment & Supplies
Canon ir 2015 is showing error code e007
Easily found. I've just searched online for "error code e007 " and the first hit was for canon ir 2016. I guess that the difference in models is not that critical. So, go to "copytechnet.com".
Jun 29, 2015 | Canon Office Equipment & Supplies
My Canon copier, Model IR 400s, Shows the error code : E 604. What is the problem ? How can I Solve it ?
Problem :
E604 Error Code. You followed all the troubleshooting steps in the service manual and still have an E604 code.
Solution :
Check the Image Server Memory or the Image Processor PCB. The recommended Image Sever Memory should be Kingston 32MB, 144 pin EDO Module, 64 Bit, 60 nanoseconds, No Parity.
Jul 13, 2012 | Canon imageRUNNER 400S Copier
CAnon xerox Machine IR 2318 L Error code : E 000007-0000
My canon ir 2318L shows error**E000007-0000 how can i solve this problem
Feb 28, 2011 | Office Equipment & Supplies
My Canon copier, model IR 400s, Shows the error code : E604. What is the problem? How can I solve it ?
Sep 25, 2010 | Canon imageRUNNER 400S Copier
I have Canon iR 2016 it show E808 code error
i have canon Ir2016 it give 808 error code can u help me please
May 29, 2010 | Canon iR 2016i Black and White Copier
Error code e000007-0000 in caonon ir 3300
Jan 16, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Canon iRC3100 Printer Logo
232 people viewed this question
old marine
old marine
