Question about Samsung TXN2726 27" TV
Vchip i don't have the code to my samsung t.v to turn the parental rating off. i can only watch 3 shows anything 14 and older gets blacked out. i need your desperate help please.
  • Jillian Olmsted Aug 05, 2007
    can any one help with my vchip problem???
    Novelist:
    Champion:
  • 236 Answers
If you can get into the menu, and know the proper password, then you can change the parental control setting. If not then the memory chip may have to be replaced. Stargazer
Posted on Aug 10, 2007
My tv is locked i cant push anything to cut it on it is on but there is a key on the screen and i do not have the remote control what do i do.
hi,
To unlock your TV you must need the original remote of it. If you don't have then you have to purchase it. After the do the following for unlock you TV
Apex TVs have parental locks that allow you to block certain programs based on their rating. When this feature is no longer needed and you want your TV to display all programming no matter its rating, you must unlock your TV. Unlocking your Apex TV is done completely from your remote control and does not require any tools. The process takes less than 5 minutes.
1. Press the "Menu" button on the remote control and use the arrow buttons to scroll down to the "Parental Guide" option, then press the "Enter" button.
2. Type in the default parental code "6688" if you have not set your own code. If you have set your own code, type it in. If you set your own code and forgot it, override it by using "6688."
3. Use the arrow keys to switch the parental lock to "OFF." This allows all programs to be viewed no matter the rating. Press the "Exit" button on the remote and start watching all your channels
ok
May 22, 2011 | Apex Digital AT2402 24" TV
V-chip activated
Hit the Menu button on the TV. 2. 'INPUT SECRET No.' should appear. 3. Press and hold both VOL (+) and CH DOWN (9) on the TV set simultaneously until the message 'INPUT SECRET No.' disappears. 4. The vchip settings should be disabled now and the Parental controls menu should be presented, 'disable' Status if need be.
Mar 14, 2010 | Sharp 32C-240 32" TV
Tv wont turn on its a mitsubishi wide screen model number WS-65809. also forgot password for parental locks so when it is on cant watch anything but Disney, and Nickalodian!!!
I can help you unlock your Mitsubishi HDTV V-Chip at least, for when you get it back on.
Please follow these steps to bypass the vchip or reset the V Chip password.
I hope that helps.
_______________________________________________
Reset Mitsubishi HDTV VChip Password
Bypass Mitsubishi HDTV Front Panel Lock
Mar 13, 2010 | Mitsubishi WS-65809 65" Rear Projection...
I accidentally activated the parental controls on my samsung tv and now I can't watch any stations with a PG rating. please help!
To change this, you need to access the Digital Menu, Setup, Parental Lock and turn the lock for PG off. Or enter the 0000 code.
Jul 15, 2009 | Samsung HP-T4254 42 in. Plasma Television
Trying to find parental code so i can watch a movie on it?
I too have the Ramone DVD player and had quite a surprise the first time I popped in a PG rated DVD.
There is no mention of a parental code, turning it on or off or ANYTHING in the manual.
On another website, I found the code 1369, which seems to work. I taped it to the bottom of the really cool remote. Still found nowhere to change it, etc. Least you can watch your movie!
Mar 30, 2009 | Disney Cars Ramone DVD Player
I dont have vchip code fof my used tv
1. Hit the Menu button on the TV. 2. 'INPUT SECRET No.' should appear. 3. Press and hold both VOL (+) and CH DOWN on the TV set simultaneously until the message 'INPUT SECRET No.' disappears. 4. The vchip settings should be disabled now and the Parental controls menu should be presented, 'disable' Status if need be
Remember do it on the tv not the remote
Nov 14, 2008 | Televison & Video
Mitsubishi parental control reset for tv model vs-5061
I can help you unlock your Mitsubishi HDTV V-Chip.
I hope that helps.
Jul 20, 2008 | Mitsubishi VS-50611 50" Rear Projection...
Resetting V-Chip pin code
I don't know the sharp(mfg) code to activate my universal remote
May 12, 2008 | Sharp 27U-S60 27" TV
How to erase parental control code
I finally found out how to reset the V-chip password on this princess DT1350-P Tv. All you have to do is turn the TV on and turn to a channel that doesn't prompt the V-chip password (even if it's snowy) and hold down the volume (down -) button on the main unit while holding down the number "0" on the remote control. It might take a few tries, and you might need to change the TV channel for some reason but if done correctly, either the TV will turn off, or the menu screen will pop up and ask if you want to set the vchip password, either way you should be able to watch your TV now! :)
Nov 12, 2007 | Disney DT1350-P 13" TV
V. chip
According to the Samsung website, this is the method to reset the Vchip PIN.
1. Turn TV on.
2. Press power button on the remote, TV will turn off.
3. Press Mute on the remote.
4. Using the remote, press the buttons 8, then 2, then 4
5. Press the power button, TV should turn on.
At this point the PIN should be reset to four zeros.
If that doesn't work, you could have someone mess with the internal circuits as someone else posted, but I wouldn't recommend trying it yourself.
Or you could call the Samsung tech support hotline at 1-800-726-7864. Never tried it so I don't know how good their customer support is.
Aug 03, 2007 | Samsung TXK2754 27" TV
Samsung TXN2726 27" TV Logo
98 people viewed this question
Jerry Greenberg
Jerry Greenberg
