Question about Kitchen Ranges
Diplomat Manual for extractor fan/cooker hood HJA2440
SOURCE: Kitchen extractor fan
hi! most of the time this will be sticky switch normally located on the inside edge of the extactor unit behind the filter mesh!.hope his helps
Posted on Dec 20, 2008
SOURCE: Fan and light not working where is fuse box?
Hi - I have a neff extractor fan and have the same problem. The light and fan have both stopped working. Does anybody know where I can find the fuse as I suspect that this may be the problem too?
Posted on Feb 16, 2008
SOURCE: cooker hood not working
Check power from the wall.
Check power in the wiring coming into the hood.
Check to see wiring is not broken.
Posted on Feb 18, 2008
  • 142 Answers
SOURCE: CDA CPX9 COOKER HOOD - how to remove chimney/disconnect power
remove filters, inside there will be mounting screws, support the unit prior to removing screws. there might be ducting inside clamped on, and a power plug(hopefully) to disconnect.
Posted on Jan 27, 2009
SOURCE: Bulb has blown on one of the lights but the other light will not
Its definetly the control board again.
Its worth $110.00
Read other answers ive given to others about similar problem
gtp_jmp
Posted on Feb 08, 2009
Where are the fuses in a Victoriana Deluxe Leisure cooker? The extractor fan and light have stopped working
It would be fused to the house current most likely through a circuit breaker on your service box.
Jul 19, 2016 | Kitchen Ranges
HJA2440 extractor (60cm model) light goes but the fan does not. I do not know where to find the fuse? Or other suggestions for getting the fans to restart?
Check for the proper power at the fan motor and fan switch. If the correct power is there the fan motor is bad.
Aug 30, 2014 | Kitchen Ranges
Hygena APP2500 cooker extractor hood?the lights on the hood work but the extractor itself does not work, is this likely to be the motor that needs replacing or the switch unit ? Plz advice
if u have a meter u can check the switch and the motor,By putting it on the continuity mode and check to see if u have a bad motor or switch
Apr 02, 2011 | Dryers
Diplomat Range Cooker User Manual
There should be a source of manual here;
http://www.google.co.uk/search?q=Diplomat+Range+Cooker+User+Manual
I can't find Diplomat as a manufacturer, sorry
Jan 03, 2011 | Microwave Ovens
Minimum distance between diplomat chimney extractor and gas hob
Minimum above a gas burner should be 750mm and for electric hob should be 650mm.
Aug 07, 2009 | Kitchen Ranges
The light on my cooker hood comes on but motor dos,nt work it is a diplomat APP3440
It's probably a bad fan switch or a loose/corroded/broken electrical connector in the fan circuit. Another possibility (but not as likely) is the fan motor has failed.
Apr 21, 2009 | Imperial C2036PS1-TW Kitchen Hood
Elica oven hood fan not working
fan & light on elica extractor fan not working over cooker
Feb 25, 2009 | Kitchen Ranges
Dec 07, 2007 | Whirlpool GZ7730XGS Stainless Steel...
Kitchen Ranges Logo
699 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
