Question about Music
Peavey blazer 158 (red stripe)
I am getting a distorted sound on the clean channel> How can this be resolved?
soundchasr
  • 11 Answers
SOURCE: Peavey sound board 2 channels not working
check for cold solder joints from the input jacks and the fader. If any look suspicious (dull or grainy) re-solder.
Posted on May 29, 2009
SOURCE: my amp has 2 channels, clean and distortion.
I have same problem where distortion works but clean doesn't on same amp. What might be helpful for someone to help me is that sometimes the clean does work.
Posted on Feb 09, 2010
  • 5603 Answers
SOURCE: Peavey Rage 158 guitar amp
I don't believe there is a power "outlet" on this, only an "inlet".
Usually the inlet will have a lead, often green, that goes to the chassis.
There will usually be two other wires, often black and white that connect to the other two pins.
From the back of the connector, with the center pin tied to the grenn wire of the triangle lower, the pin to the right should be the white and the pin to the left is the black wire
Posted on Jul 25, 2010
  • 5603 Answers
SOURCE: My Peavey vk100 head is
You may simply be overdriving the clean channel and causing it to "flat top" . See if it occurs when you back the gain down a bit. New tubes PROBABLY will not help and be a waste of money. You may be unconciously playing harder during the popping episodes. You cannot hear level variations smaller than about 3 Db BUT the electronics will sense much smaller variations. You could gently tap the tubes with a lead pencil to listen for any pops... NOTE: tubes can be slightly microphonic so some sound from tapping is normal.
Yes, a cable can be noisy and not show itself when using intentio0nal distoprtion... try another to verify it is not the problem.
Posted on Jan 02, 2011
  • 52 Answers
SOURCE: Wires to main speaker are, Yellow & Blue
Yellow should be the positive. Try plugging in and reversing. The louder of the two is the one in phase and the correct wiring. If the speaker is pushing out when playing , it is in phase and correct also.
The distortion problem could be a speaker going out. It may not be totally blown, but may be verging.
Holding your hand out as wide as you can push against the speaker lightly. If there is a rubbing or scratching sound, the speaker could be damaged.If it moves freely, and there is no scratching its okay.
Another possibility is the clean channel may have a channel volume set to high. Make sure the clean channel volume is set lower than the master volume otherwise you can get distortion on that channel too.
Good Luck.
Posted on Feb 21, 2011
I only have a vintage Peavey XR600B and I want to connect and ipod and ipad up to it so I can play music. Can I do this or do I need special cables?
Sure you can, but that mixer amp is a mono amp instead of stereo. Head for radio shack and get an 1/8" stereo male phone jack to 1/4" female mono adaptor. Plug the adaper into the headphone output of your device. Then run a shielded cable with 1/4" mono phone plugs on both ends (like an electric guitar would use) from the device to one of the channels on the Peavey. Bring the volume up on both the channel and master on the amp up maybe 1/3 the way. Play a track on your device and adjust the devices out put as high as it will go with out distorting the channel input. Then adjust the amp's channel and main output as you would normally to get the final volume you need.
Jun 28, 2014 | Peavey Xr 8600 8 Channel Powered Mixer
Peavey bandit 112
have you tried using a foot pedal? Are you sure it is switching (green light turns red, etc?). On the lead channel are you turning up the gain all the way and the volume down?
Oct 12, 2013 | Music
I own a Peavey Valveking vk100 and when using the distortion channel on high gain it makes a weird whistle-like noise (not a feedback sound). The strange thing is that if i lower the gain, the sound...
Sounds like Tube Microphonics to me...
Change the 12AX7 (I guess) for that channel for starters.
If not, some condenser went crazy.
Nov 12, 2017 | Music
I have a TNT 115 S that is distorting when i play E string on my bass. What might be causing that?
Please add more information to improve help, does the amp just distorts in that particular note or teh entire sound is distorted? does the amp distorts at low volumes?
Sep 05, 2013 | Peavey Electronics Peavey Tour Tnt 115...
How can i get more metal distortion from my peavey 6505+ 112 combo amp?
Tone is a hard thing for some to achieve. Kinda sounds like the amp isn't satisfactory to you as a player. I use an ADA MP-1 with a quadraverb GT and I can sound like Steve Vai with almost any amp. The pedals you mentioned should all sound pretty good with almost any amp. You kinda sound as if your amp sounds wimpy. ALSO, a good metal distortion is a combo of effects as well as tone(layering). The sound you may be expecting may be the sounds of 4 effects combos at a time through a line mixer making it all sound like one sound. I use rack stuff BECAUSE I can get the sounds that NO pedals can give. This also sounds like your knowledge of the equipment needs improvement. True tweaking of gear takes years to perfect, especially if you're a picky guitarist like myself.
Mar 04, 2013 | Peavey 6505+ 112 Combo Amp Combo
Clean channel distorts after a couple of hours use - then cuts out
Check the power supply voltage and look for a hot component. If it takes a while to bring on the symptom it's probably something getting hot.
Nov 12, 2017 | Fender Hot Rod Deluxe Guitar Combo...
Wires to main speaker are, Yellow & Blue witch one is the positive ?. Also I am getting distortion from the clean channel even at low volume, the speaker is Peavey 1230 model 8 ohms.
Good Luck.
Feb 21, 2011 | Peavey Bandit 112 Guitar Amplifier With...
My Peavey vk100 head is running through a Carvin Legacy 2x12 cab. On the clean channel there is an inconsistent popping sound. It will happen loudly for a few seconds, and then not at all for a while, and...
Jan 02, 2011 | Peavey Valveking Vk100 Guitar Head
I have a peavey bandit 112 transtube guitar amplifier. Ive had it for nearly 15 years, but over the last few its become quite noisy when turned on even if nothing is plugged into the input. This is on both...
This has several vacuum tubes and those are suspect. Take a pencil and tap the glass of the smaller tubes to look for noise changes. You may have to take off the tube metal shield to do this.
If you have got 15 years of life from the tubes that is great. Also suspect are electrolytic filter caps.
If you are not electronically adept, take it in for repair.
Dec 30, 2010 | Peavey Bandit 112 Guitar Amplifier With...
Apr 29, 2009 | Peavey Pv 2600 Power Amplifier
Music Logo
53 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
