Question about Insignia 32" 720p Flat-Panel LCD HDTV
HDTV and cable box; no volume on channels higher than 99
Cable Box is Scientific Atlanta, Explorer 3250HD Digital Interactive Set-Top.
At first, there was no volume on ANY channel. We tested the DVD player and DID have volume, then my granddaughter went into General Settings, then Audio Out and set it to "HDMI" which gave us volume for channels up to 99. Any suggestions?
  • rhschacht Mar 13, 2009
    Yes, johncaman, the set top box is directly connected to the TV.
    Thanks.
  • 201 Answers
Can you tell me, is the set top box connected directly to the tv? (i.e. not to a surround sound receiver or anything)
Posted on Mar 13, 2009
  • John Aman
    John Aman Mar 13, 2009
    I'll need a descriptions of what wires are going between the set top box and the tv, and where there connected on both to give you a better answer, but at this point I would suggest that if the General settings/Audio out setting you made was on the cable box, it should probably be on "Analog Out" or "Stereo Out" (I don't have the manual at the moment, so I'm not sure what settings there are).
Can I connect a Toshiba DVR620KU to a scientific atlanta explorer 4200 cable box?
Please follow guidelines given in operation manuals of both.
Aug 02, 2012 | Televison & Video
I can't turn on closed captioning on Hitachi with Comcast scientific atlanta explorer 2200 cable box. Any words of wisdom?
Both the set and the box used should have the closed caption feature.
If box is in line to rear audio/video jacks you will have to engage the CC from the box.
I doubt it will work if hooked that way from within the box---go to menu and in CC area in either set or box select CC1 which is the most common one used.
May 25, 2012 | Hitachi P50H401 50 in. Plasma HDTV
I have a Scientific Atlanta 3250HD cable box that loses sound everytime a channel is changed. The box must be rebooted to get the sound back each time. I have no problems with the 4250HD boxes. Any...
Did you call Scientific Atlanta to find out if this could be a software issue in their box, or if there is a failure occurring?
I have had cable boxes do similar things to what you are describing. It turned out to be the box was defective and had to be changed. They were not serviceable. I believe these cable boxes were made by Scientific Atlanta.
Jerry G.
Nov 14, 2009 | Insignia 32" 720p Flat-Panel LCD HDTV
Change default channel on cable box
Called the cable provider, Time Warner, and used the "settings" menu to navigate to power on channel, where I selected the default channel.
Nov 13, 2009 | Atlantic Scientific Network connector
Connecting a standard cable box to an HDTV and remote doesn't run cable box. After I connect my new HDTV to my standard(non HD) cable box if I use my remote to do a channel up or down it just starts...
are you connecting by scart ? if so some hdtvs send signal backfeed/try aerial tv out to tv/also try basic scart lead as scarts can be faulty dont fit a pound shop one get a top one from maplins etc
Nov 10, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Cable box remote doesn't work when tv is turned on.
I am having this same problem with our Mitsubishi LCD Flat Panel TV, Model LT-46246 ans our Scientific Atlanta remote cable box, same model as yours. We cannot use the remote at all to change the channel. I called Mitsubishi and they said they have never heard of this. I find this incredibly hard to believe. Time Warner, our cable provider says that it is not the box because it works when not hooked up to the TV. What a pain. I would love to hear if anyone else is having this problem or has a fix for it.
Mar 25, 2009 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Why is there a long delay changing channels on my new Sanyo HDTV?
Are you connected to a cable box from your cable TV service Provider and use this device to select the channel you want to view? I have an HDTV which has the QAM tuning feature. Changing channels was instant until I accepted an offer from Cablevision for a 1 year rent free box and remote combo. The tuning box is a digital & analog Scientific Atlanta Explorer 4200 HD with a card slot for your subscription specs. This bypasses the tuner in your TV and the TV functions as a monitor.
If this is similar to what you have and you don't care about the channel/current program on screen display that appears for several seconds before the channel selection completes, perhaps the cable co. can adjust your box to supress this display if it will speed up the channel selection.
There is another annoying problem with this box. If you have a fraction of a second ac power interruption which might not even cause your computer to reboot, the cable box goes into a reinitialization that could take 5 minutes or longer. In my opinion, it is not worth the $6.50 per month charge we will receive when the year is up.
Aug 05, 2008 | Televison & Video
Set top box and remote control
My remote wasn't working until I programmed it to work with itself ... (how odd it wasn't done already).
"CBL" button and ""OK/SEL" held down simulataneously for 3 seconds ... then "001" for the Scientific Atlanta. If the unit turns off, you're in business.
Feb 03, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Cable Box compatibility.
my cable box want turn on
Oct 18, 2007 | Aiwa AV-D57 Receiver
Picture, No Sound from HDTV Box
CON-YOU'VE DIAGNOSED YOUR OWN REPAIR.GET A NEW CABLE BOX.JOE TV
Apr 20, 2007 | Panasonic TH-42PX500U 42 in. Plasma...
Insignia 32" 720p Flat-Panel LCD HDTV Logo
509 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
