Question about Cisco Ws-c2960-24tt-l Catalyst 2960 24 Port Switch - Factory Sealed
Ethernet light blinking - Cisco Ws-c2960-24tt-l Catalyst 2960 24 Port Switch - Factory Sealed
Amber light blinking next to ethernet cable
In most cases an amber lights are usually just connection lights. They let you know the ethernet cable is connected and able to transfer data.
You will want to ensure the printer has a static ip address set in it's configuration, otherwise the ip address will change from time to time causing print issues.
Jun 24, 2013 | Office Equipment & Supplies
How to fix orange blinking light on ethernet
orange blinking on ethernet means that your connection is 10 Mbps and green blinking means 100 Mbps
there's nothing wrong with it
Aug 27, 2012 | Toshiba Satellite M35X-S163 Notebook
Why do my Ethernet and Internet light keep blinking?
Some routers blink to show there is ACTIVITY on the ethernet and internet ports, For example you broadband modem is connected to a port on hte back of your router this has a light it would blink on some routers to show activity, and likewise with the ethernet side.
If you have internet access and have zero issues this is NORMAL.
thanks for your question please do rate your answer, Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 05, 2010 | Netopia ADSL 2+ MODEM 10/100 EN AND USB...
Describe your zyxel p-600 dsl light turns off then on
Hello kb_gimper,
The power light and all other lights blink when the ZyXel P-600 is initializing. The ethernet, dsl and internet lights blink when data transfer is detected. The lights are from left to right:
* Power Light
* Ethernet Light
* DSL Light
* Internet Light
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Dec 19, 2009 | Zyxel Prestige 660R Router (91004397002)
2wire ethernet and wireless lights blinking
They shouldn't become solid. Most lights blink when there is a communication between the devices. It's never a solid connection light.
Oct 04, 2009 | 2wire Computers & Internet
Ethernet
if the light is blinking when you plug the ethernet cable, it should be ok. If it blinks, unplug the modem, wait 15 secs. then plug it back in so the modem can get the computer's ip adderss. Now, if it does not blink, try another cat5 cable first, and if that does not work you may need to replace your ethernet card.
Sep 24, 2009 | ASUS P4B266 Motherboard
Westell 6100 is blinking Ethernet and Internet lights and Media player buffers and times out. Help
ethernet light should no blink
check the LAN drivers..if possible reinstall them..do a complete powercycle.of the system.
Switch of the pc-modem-router..wait for 1 minute then switch on the router/modem wait for all light to come back-switch on the pc..if intermet light is blinking there might be an issue at the ISP's end.
Http://www.ikarmatech.com
cheers.
Sep 11, 2009 | Westell Wirespeed LiteLine 6100...
WRT55AG router- wireless lights blink on and off and no ethernet?
If you plug in computers on the ethernet ports and they dont light up at all but you are sure that the cables that you are using works as well as the ethernet port on your computer that means that the unit is already defective. You can contact 8003267114 for replacement if its under warranty
Mar 06, 2009 | Linksys A+G WRT55AG Wireless Router
I have a Compaq SR 1000 desktop set and I can't get the power to go on. When I plug the unit in a green light in the back keeps blinking. When I disconnect, hold in the power button the blinking stops, but...
Hello shapscomp
The blinking green light is likely your Ethernet card's LED. Is the blinking light located near your Ethernet (network) cable?
It sounds as though your power supply has failed. You may be able to purchase a replacement power supply for it.
Would you like some assistance in deterimining if that is the case?
Thank you
BJ
Apr 05, 2008 | Computers & Internet
My ethernet light is blinking
Make sure you have internet. The ethernet light is blinking because what ever u have plugged into it is talking to the modem. The modem will then take that request and ask for it on the DSL/internet line. Make sure the DSL light is steady on and the internet light is on or flashing with activity.
Oct 10, 2007 | Westell Wirespeed LiteLine 6100...
Cisco Ws-c2960-24tt-l Catalyst 2960 24 Port Switch - Factory Sealed Logo
22 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
