Question about Battery Biz WIPRO AcerNote 350cx AC Adapter
Tft185w80ps saying no signal
NO signal vga cabel proper connect mother board display ok
Is there a reset button on the mother board. Or is there a reset. Button on the moniter it keeps on is playing no signail
no and no
no signal means that the connection to the computer is not there (cable not properly in or broken wire ) or the mother board is not working the VGA section of a push in board or the mother board proper
have a computer repair shop check it over for as proper diagnosis and a quote
May 04, 2016 | Computers & Internet
LG monitor displays "D-SUB POWER SAVING MODE" when it is starting
The message it is displaying indicates that a VGA cable is connected and is not sending signal, or is sending a Monitor Off signal across the VGA cable. The motherboard battery will have no impact on this. If you are using something other than a VGA cable to send the signal to the monitor, then you should ensure that no VGA cable is plugged into the monitor, or the source on the monitor is not using the VGA connector.
Mar 28, 2014 | Computers & Internet
No display signal
Hi do you know that if the settings in the bios are correct, also check that it s not the mother board itself , see if you can get an addition Graphics Card to check it out
Jan 08, 2014 | Foxconn H67a-s Lga 1155 Intel H67 Sata 6gb...
The front panel does not work, after I followed the directions to plug the wires. The VGA does not show anything also, it says no signal.
FIRST CHECK THE MONITOR AND ALSO CHECK SO ALL
CABELS ARE SEATED TIGHT.SECOND CHECK THE VIDEOCARD REMOVE IT AND REPLACE IT SHOULD BE
SEATED TIGHT.
Aug 26, 2013 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Akai tv problems
if you know for sure you got signal in your inputs. you are left with a bad TV mother board. this is where all inputs connect to
Jun 02, 2013 | Televison & Video
Why is there no signal when i connect my desktop to my flat screen?
if its you tv flat screen you might have to go to the menu and select pc on that...if its your pc flat screen make sure its connected fully to blue vga connection and turned the right way up...hope this helps
Oct 13, 2010 | E-Machines eMachines Desktop PC
Intel dg31pr mother board why dont show display?
First check your num lock led if it on and off when you press num lock key then your cpu is ok.
Then therer is issue with monitor to cpu loose connection
or
Screen resolution problem.
For that when you power up press F8 key then enter in enable vga mode.then go to control panel and dispaly then settings then change screeen resolution to 1024*768 then apply and ok.
Aslo reconnect connection from monitor to cpu vga port.
Also check in bios some times your harddisk is not detected proeprly.
If problem still remains open cpu cabinet and reconnect data cable and power cable to harddisk.
Refix RAM memory.
Pull cmos cell for 15 minutes then check.
Thanks for using fixya.
Pls rate solution if it help you .
Jul 18, 2009 | Intel DG31PR Motherboard
Start up failure;
try to start in safe mode using F5 at the time of window booting
Mar 23, 2009 | Microsoft Windows Vista Home Premium with...
NO VIDEO SIGNAL
There is no input yet meaning, it is not yet properly connected to your computer. Check the cable connection. Please make sure that the computer or laptop is already turned on.
Oct 14, 2008 | NEC LT 260K Multimedia Projector
No signal to monitor when booting.
(1) Remove memory from mother board and start the system if you happen to listen long beep then RAM is not working properly.
(2) Clean RAM conducting area on mother board with clean cotton cloth, put one peice of RAM and test and check the othe peice also, if working you could any sign display . Before doing all these check mother board any LED is glowing if so your SMPS is working after you turn on UPS.
(3) Check for all proper connection for all cables. Have you connected video cable of monitor to mother board VGA (it will not work because it is disabled as soon as you installed XFX GeForce 8800 GT), your viedo output only will come through XFX GeForce 8800 GT VGA port.
(4) If propelm persits Deassmble complete the system and reassmble & do n't connect HDD, DVD, floppy. Cehck with bare mother baord, processor, RAM (put one picese at a time) by connecting viedo cable of monitor
Apr 19, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Battery Biz WIPRO AcerNote 350cx AC Adapter Logo
21 people viewed this question
Top Battery Biz Computers & Internet Experts
justwinwin
Lawrence Oravetz
Greg Baldwin
Are you a Battery Biz Computer and Internet Expert? Answer questions, earn points and help others
