Question about Pioneer SD-643HD5 64" Rear Projection Television
Can't get full power on
When I turn on the main power on my set the light goes green for a second then turns to red and I get no power. Any suggestions? Looking for fuse location too.
  • jasonkraft Apr 26, 2009
    I have the same problem but after replacing the fuse it just blows again when I try to power it back on.
    Jason.
    Problem Solver:
You all have convergence chip issues and they need to be replaced go to tvrepairkits.com
Posted on Aug 17, 2009
I have this exact same issue; search engine took me here. I have been experiencing this problem for about a year now. When you power on, the RED standby light goes out, the power light turned GREEN, you might hear a small pop sound, then the RED standby light goes back on. YOU HAVE BLOWN A FUSE. My problem is this is occuring much more frequently now and I'm going through fused like crazy. So I'm looking for a long term solution. To replace the fuse, turn off the standby power switch on the front. Unplug the power cable. Open the back panel. All logic and power modules are on the bottom of the cabinet. Therer is a large power module in the middle. In the middle of this module are 3 fuses. The one that typically blows is the one in the middle. It's a 5 amp fuse, but double check the rating before replacing. Good luck, Mark
Posted on Aug 26, 2007
Jason. i got this info from ladywinn. fuse 302 5 amp and 303 5 amp. Replace both stkics big black ics- stk 392-180's. Good luck!
Posted on Jan 11, 2011
I have a call in with Pioneer for help. Some additional info. Parts can be found at parts.pioneerelectronics.com . The fuse that is blowing is identified on the PCB as FU303. The part number for the Power Assembly is AWV1887 (OLD model) or AWV2011 (New Model). Depending on what Pioneer says, I'll probably replace the Power module; $311.
SOURCE:
When I turn on the TV the green light goes green to red to green to red. If I keep turning it on and off eventually I get a picture. The picture is very dark at first
Sounds like back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced.
Dec 26, 2015 | Akai Televison & Video
Klv32s310A sony bravia gets start on with green light and after a second turns to stand by mode blinking the red light 6 times after each 2 second interval
Hello Sagar,
green led means tv powered on and status ok.
Red blinking light almost always means defect, overcurrent or overload.
6 blinks for Sony lcd flat tv means trouble in backlight circuit, or backlight inverter (backlight illumination or lighting makes your tv screen visible).
common problems in the inverter circuit, which drives the backlight, or shorted drivers, or short-circuit transformers or open circuits.
You should find the problem in the inverter circuit, or in the power supply board or in the main board.
Also look for bad capacitors (electrolytic caps) which are bulged and swollen on top.
Decoupling plugs from printed circuit boards can help you in finding the problem board by elimination method.
If you power up the set after unplugging certain plugs on f.e. the inverter board , this could result in getting a green power led and concluding that this board is faulty.
succes,
Walter from Antwerp, Belgium.
Dec 30, 2014 | Sony Televison & Video
Toshiba regaza 37rv635db wont turn on
seems like capacitor problem, chack them and if thay have exploded replace them.
Aug 25, 2013 | Toshiba 37RV635DB Regza 37-inch Widescreen...
My protron pltv-37c will turn on for 10 seconds the light turns green then goes to red after ten seconds
The green light indicates power is being applied. The change from green to red indicates that the power supply has failed
Oct 29, 2012 | Protron PLTV-32 Television
Sony Wega 60" TV lamp light
Nope. It appears that you now have a main power supply issue since the set is dead.
Jun 23, 2017 | Sony Grand WEGA KDF-60XS955 60" Rear...
Mitsubishi big screen HD 1080 series model WS-55809. it switched off one day. and when i turn it back on it switches right back off. red light in front. what part do i need to fix it/
That model does not have a red light---Green.
If set powers up for a few seconds (green power light) and goes out do the self check the model indicated has:
On front of set (not with remote) press and hold both the input and menu buttons for at least 5 seconds and release both.
Green power light will blink a two digit error code like 2 blinks, 2 blinks a pause and repeat it several times.
Let me know what error code you find (if you have unplugged the set that will clear all errors and you have to plug it in and try to turn set on again---when it fails do the self check)
Mar 31, 2012 | Mitsubishi WS-55809 55" Rear Projection...
Replaced bulb yesterday worked fine. Today light will not turn on. projector turns on both lights green for 10 seconds, then power goes red and status blinks green for about 5 seconds, then status light...
green green is power on, normal
then it tries to light the lamp, but it can't so the protection circuit comes activated.
you get red and green blinking
Then it goes to standby, red and off.
so something has happened to the lamp, or lamp ballast power supply.
Take the lamp out and check if all is OK with the 2 terminals in the connector, and the leads to the lamp are intact.
Failing that, I would suspect the ballast lamp power unit
Mar 25, 2011 | Mitsubishi HC1600 Projector
My Loewe Aconda TV will not turn on - buzzing noise.
My Loewe Aconda 81 HDR TV will not turn on. When I press the power button the green light comes on but the red light stays on with it and after a few seconds the green light goes out and the red light stays on. Any help please.
May 15, 2010 | Loewe Aconda ACO9383 38" TV
Power
same problem here
Dec 20, 2007 | Pioneer SD-P50A3-K TV
Pioneer SD-643HD5 64" Rear Projection Television Logo
510 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
