Question about Hardware & Accessories
Rain bird wp2
How to reset rain bird wp2
Need to find out how to operate them. Is there a manual I can look at on line?
Manual - Rain Bird
www.rainbird.com > Homeowners
Rain BirdHave a question? Looking for a manual or troubleshooting guide? Enter your query in the search box below to find helpful resources on the Rain Bird website.
Sep 24, 2015 | Garden
Rain bird
Usually there is a way to cycle through programming.... by repeatedly pressing program button...
Hardwired timers usually have reset button.
Some battery-operated timers can be reset by removing battery
Add comment and attach photo of timer and include model number
Aug 11, 2014 | Hardware & Accessories
My rain bird 1800 head keeps leaking how to fix it
if this is an older sprinkler ,it may just be worn.usually the leak is around the white plastic surrounding the popup shaft.in this event the cap needs to be replaced.
Apr 17, 2013 | Rainbird Rain Bird 1806nsi Pop Up No Side...
A station does not come on as sceduled for rain bird
Okay, then you answered your own question. I like it! However, did you test the wire to see if it will start a different valve and vise versa?
Sep 08, 2012 | Rainbird Rain Bird 6 Station Automatic...
I need a Rain Bird manula for ESP Modular Controller. I don't want to download it. I want it in a manual for my rental.
Try contacting Rain Bird directly here, to request a copy of the manual via mail:
Rain Bird Online Store
6991 East Southpoint
Tuscon, AZ 85756
Online Store Phone Orders - (877) 727-8772
Available 7am - 3:30pm PST
Tech Support - (800) Rain Bird
Fax (800) 843-4162
Jan 11, 2011 | Rain Bird Hardware & Accessories
Rain Bird sprinkler timer blowing fuses
Disconnect all zone wires and see if timer blows fuses. If not, one of the zone valves is drawing too much amperage.
Oct 02, 2010 | Rain Bird 4 Station Single Program...
Our rain bird was off and i changed the battery. I tried to turn it on manually and it says, no ac?
The battery only holds the program in the memory. The No AC message tells you that the AC power that is supposed to operate the valves is not getting to the control unit. Someplace there is a power cord with a transformer that is taking the house current at 120V and powering the unit. Something has been disconnected or a circuit breaker is tripped. If there is an outside socket with a GFI in it, try resetting it.
Paul
Sep 17, 2010 | Rain Bird Xerigation XCZ-075
How do you reset the timer for a rainbird sprinkler system?
Resetting involves reprogramming, but that's easy to do. You probably have a cheat sheet, like I do.
Unplug the timer, remove the battery, and go have a cold drink (let it sit for about 10 minutes. Reinstall the battery, plug it back in and you are good to go. Reprogram.
Regards, --W/D--
Jul 20, 2009 | Rain Bird Hardware & Accessories
Hardware & Accessories Logo
76 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
