Question about Maytag Atlantis MAV6000 Top Load Washer
Washer is over flowng
Washer is set on mini load and it fill all the way up and floods the house.
  • 51 Answers
Seems very likely that the water level sensor is malfunctioning, and not telling the water inlet solenoids to close when the appropriate water level is reached.
Posted on Mar 13, 2009
Front load washer filling up with water when off
if it's off or unpluged and still filling up you have a bad water valve,mark the hoses if they're not marked already so you know where the hot and cold fill hoses go after you change out the water valve on the washer,usually sediment gets stuck in the valve stopping it from closing and the water will keep filling into the washer,i've seen houses flooded from this,shut down the house valve that feeds the washer until you get the new washer valve.hope this helps and good luck,next time send the brand name and model number.
Oct 06, 2011 | Washing Machines
Washer will not shut off water in rinse cycle thus flooding house. Repairman said we needed a new control panel-just want to make sure. Could it be something else? Bailey
Bailey,
Did not see this second post. If the water continues to run filling the machine try this.
Lets determine if this is a Stuck Open Water Inlet valve. If you hit the Off button does water stop flowing into the machine?
If so then I feel you have a stuck closed pressure switch never signaling that the washer has reached the proper water fill level and flooding the machine.
Are you a DIY type of owner if so I will point you to a better forum for support.....D*ick aka dh1200s
Apr 16, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My GE WCSR2090D top load washer has flooded our house in the past, and when looked at by a repair man he said nothing seemed wrong... so we continued to use it and it now leaks/floods only once in every...
You might have a partially clogged drain past your drain hose
(In the wall etc)
Thats overflowing behind the washer.
Watch the drain for a few washings and see if it overflows
It may be second or third or fifth load. Its hard to catch
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Sep 08, 2010 | General Electric WCSR2090D Top Load Washer
My Maytag Performa washer loves to flood the house!!!!
sounds like pressure switch is bad or pressure hose is plugged or water valve is bad or drain overflowing
Apr 22, 2010 | Maytag Performa PAV2200
Water dose ot stop when washer is full. It continues to run.
If you disconnected power and water still flowed, replace the water valve. If water stopped flowing when power was disconnected, clean out tube from tub to water level switch.
Jun 07, 2009 | GE WDSR2080D Top Load Washer
OVERFILLED AND FLOODED HOUSE
1 of two problems happened.
1) either the water level sensor went bad. Which tells the water inlet valve when to shut off and the machine to start operating.
2) The water inlet valve has failed. This comes from the water hose and fills the washing machine.
May 25, 2009 | General Electric WCSR2090D Top Load Washer
Washer just started on fill cycle to start and continued filling
you have a hose that came loose to the pressure switch or the tub or you have a bad pressure switch
or the fill cup is blocked
Apr 22, 2009 | GE WJSR2070B Top Load Washer
Kenmore he3t drum filling on its own
replace fill valve under top rear left easy fix dont wait it call flood your house
Nov 13, 2008 | Kenmore Elite 45986 Front Load Washer
Washer is filling up with to much water...
possible fill valve is sticking open when filling after starting washer disconnect power and listen to see if water is still running in if so replace fill valve.. if water stops possible water level switch or small hose to switch plugged ..drain washer remove screws on each side of door frame front will pull off...small hose on some models was attached to pump housing and would become plugged with lint ckd for restriction in hose from bottom to top remove screws in console to acess other end attached to pressure switch
Aug 16, 2008 | Maytag Neptune MAH5500B Front Load Washer
Flood
To make sure did water keep coming in after washer power shut down? If so replace w. valve...it is stuck in open position
ps always keep screens in valve helps prevent this problem.
Oct 12, 2007 | Admiral AW22 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
110 people viewed this question
Top Maytag Washing Machines Experts
Richard Roth
Richard Roth
Bill Long
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
