Question about Whirlpool Washing Machines
Whirlpool 8255e Super Capacity: How to replace drain pump?
My washing machine is leaking like an excited puppy.
Water seems to be coming from the white plastic drainage pump on one end of the motor. Hoses seem dry and in good condition.
How do I remove this little plastic pump? Two metal clips seem to be all that holds it on, but it won't come off the motor spindle. This thing looks easy to swap out but the bugger won't come off! What is the trick?
Jon
  • jonathan_luk Mar 13, 2009
    Thank you: this all turned out to be absolutely spot on.
    An hour of prying, pulling and belting later, I got a little bit postal with the old pump. Eventually I was looking at the shaft.
    You were right, the shaft had swelled from long slow rusting. And yep, you guessed it, the new one wouldn't fit the shaft coz it was so distended from corrosion, so I spent some time filing it back into shape. Perfect, it's good as gold now. The most amazing part was that I didn't lose the two clips while I was doing all that.
    So a very big thank you for your legendary help.
    Jon
  • 188 Answers
Sounds like the drain pump has been leaking from the seal where the motor shaft goes into it. Usually you pop off the 2 metal clips, and pull the drain pump off the motor shaft.
If yours won't come off easily, chances are the motor shaft has expanded from corrosion, seizing the drain pump onto it. You can try prying it off by wedging a screw driver between it and the motor (be careful not to damage the motor). Last resort is to break the drain pump into pieces to remove it.
You will likely have to sand or file the motor shaft back into shape to install the new drain pump.
Let me know if you need more help.
Posted on Mar 13, 2009
How to remove aggitator from center of machine to clean inside of it, there seems to be little bits of whatever coming from there its a whirlpool super capacity plus 8255e commercial quality
Pry the top lid off the agitator.
Remove the plastic shield inside.
Use a 7/16 socket and extension to remove the bolt.
Pull the agitator off the shaft.
Mar 04, 2011 | Kenmore 3.2 cu. ft. Plus Top Load Washer
My Whirlpool Heavyduty super capacity washer is leaking from down underneath the machine. When I look under I see a return water hose that is connected to maybe a pump of somekind. Could water be comming...
sounds like it could be coming from the pump itself ( maybe a bad seal or a cracked hose connector ),, it could also be a bad/loose hose clamp. I run into this all the time and the way that I find the exact spot where it is leaking is to turn the machine around and loosen the back panel from the machine and use a towel to dry everything very well and then run the unit ( just fill part of the drum with water and then go straight to drain cycle ) look at the pump and hoses for any leaks,, it should be very clear where the leak is coming from --- if it is coming from the pump then remove,inspect and replace and all should be good. if it is just a hose then just replace the hose.
if you need anymore help with this problem, please feel free to write back and ask me,, I will do my best to walk you through the steps.
c...
Feb 01, 2011 | Whirlpool Washing Machines
Whirlpool Quiet wash super capacity. MY washing machine is leaking from the bottom when it is in rinse cycle only.
Sounds like the pump, seal for pump or a hose. Pumps crack and leak sometimes. These are pretty easy to fix if you have basic tools and are pretty handy. Try to look under as it's leaking to find out exactly where the leak is coming from, then replace that part. Hope this helps. :)
Dec 24, 2010 | Washing Machines
Roper RAX7245KQ0 Problem: Washing Machine Leaking Water
This is the best designed life long lasting Whirlpool washing machine. This core design is more than 35 years old and it is so good Made in USA design. Cannot go wrong.... Coming from 1969 Moon landing time where Made in USA matters....
Most of the time in this design, the drain pump leaks. Is the leak is coming from front middle. It might be the drain pump. Careful observation is needed. Check the drain pump seam for possible water marks or brown color water marks. Make sure before changing.
Make sure it is the drain pump. Can be something else too.
Part description for water pump for your model with a video clip how to change it.
https://www.repairclinic.com/PartDetail/Drain-Pump/WP3363394/3296?modelNumber=RAX7245KQ0
Oct 09, 2017 | Whirlpool Washing Machines
Whirlpool 8255e makes ''whirry'' sound when pumping - not spinning
there is probobly something small jammed into the pump
common for that sound would be a underwire for a bra.
is it still draining ok?
May 26, 2009 | Whirlpool Washing Machines
Water leaking from bottom
Replace water pump. Common problem. Unscrew the control panel ,two screws on each end. Flip control panel over and unsnap gold brackets from base to the back. Lift up housing and disconnect lid switch, remove housing. The water pump is in the front lower that has two hoses , disconnect hoses and unsnap pump. My sister fixed hers in about 25 minutes.
Apr 06, 2009 | Whirlpool 3.2 cu. ft. Plus Washer
Can't find Lint filter on a Whirlpool 8255e super capacity Plus Washer commercial quality top loader,
The Topload whirlpools are designed to take the lint out by reversing the water to drain out.any lint should be drained out.
Nov 01, 2008 | Washing Machines
Whirlpool super capacity imperial
We have a drain issue it seems like. I would first check the drain hose to make sure that an air gap exists to prevent drain water siphoning into the machine and then run a rinse and spin empty to see if this helps. Second is to check spin speed and pump condition as these two can work together to create a problem similar to yours.
Apr 05, 2008 | Whirlpool 3.2 cu. ft. Plus Washer
Washing Machines Logo
190 people viewed this question
Dan Webster
Dan Webster
Sal De
