Question about Buck My Baby Girl NDS for DS
In the bathtub the soap jel doesn't show up on the baby.
When I first got the game it worked fine, I gave her baths and everything. All the sudden when I put the washcloth up to the jel and it squirts soap on it, when I try to wash baby no soap appears. Is there a glitch in the program? Please help!!!
  • 3 Answers
Well buy new soap how old is she
Posted on Aug 28, 2010
NEED INSTRUCTIONS FOR EPOXY REPAIR KIT
If repairing a fibre glass bath you have to understand that the main bath is fibreglass and resin with a top coat . grind back to fiberglass top and bottom of repair , to reinforce place fibreglass patch mixed with resin under bath = top is jel coat . after repair cut back with wet and dry emery cloth .and polish= easy yes.
Mar 30, 2014 | Maax Home
Maxx jetted tub quit pumping water, pump motor just races.
When the bath pump runs and you get no water going through the jets in your bath Jet trim then the impeller has probably spun off the shaft of the motor.You will not know if this is the case until you take the bath pump out and remove the front cover of the bath pump and check the impeller.If this is the case it usually has to be replaced.
Rod
US Parts Center
888-521-6183
Feb 22, 2013 | Home
What are the advantages of bathing my baby in the sink instead of the bathtub?
the main advantages are that it is more comfortable for you, because you don't have to kneel down or bend over so much. it also gives the baby less room to move around
Jan 20, 2013 | Baby Gear
I have just had an iflo metal bath installed but am unsure what products should be used to clean it
When cleaning your metal bath you should clean your bathtub with a non-abrasive soap. Dishwashing detergent such as Joy®, Palmolive®, Ivory®, etc and a soft sponge or cloth is all that you need. If you spill something on the bathtub and need something stronger, the following are SAFE to use: Fantastic®, Tackle®, Top Job®, Formula 409®, ScrubFree®, Calgon Bath®, Windex®, Clorox Bleach®, Spiffits® Bath, Glass Plus®, and **** & Span Powder®.
DO NOT Clean Your Acrylic Bathtub with Paint Thinner, Goof OFF®, Scrubbing Bubbles®, Acetone, Lacquer Thinner, M.E.K. ® or other chemicals that attack the structural integrity of plastics (including, but not limited to, acetones). Use of these chemicals will destroy the acrylic surface of your bathtub and there is no way to reverse the damage caused by this type of chemical reaction. Use of these chemicals will void your warranty.
Oct 25, 2010 | Home
My baby is 2.5 months old and have colic problem
Gripewater is what you need to get.
Do not eat onions, broccoli, strawberries or coffee.
Vibrating chiar helps baby sleep.
Mar 18, 2010 | American Bath Home
I know I can take a bath without turning on the jets. However; does the bath water with soap flow back into the jets? I like bubble baths, If I leave the jets off can I use the bubble bath without having...
The soapy water will fill all of the jets, tubes and the pump assembly. Will it hurt the tub if the jets are not running? The soap film will build up in the jets, tubes and pump assembly and can possibly cause damage if the tub is run at a later date. Contact the tub manufacture and see if there is a safe bubble bath you can use.
Aug 23, 2009 | Jacuzzi - Bathtub - Alcove - Navona -...
When i try to give my baby a bath it makes a ! mark
every time the baby has the ! sign just was the bit with soap off as that is what i did.
Aug 02, 2009 | Nintendo DS Lite Console
"My Baby Girl" DS game cant finish giving her a bath
If there is an exclamation mark on the cloth, Simply tickle her head!
Keep doin tht until she is happy then continue washing, the soap bubbles should form!
xXx
May 29, 2009 | Nintendo DS Lite
Grid pattern showing through a cast iron bath tub less than a year old.
take digital photos and start the warranty process, it sounds like a poor enameling job.
Mar 11, 2009 | American Bath 60 Inch Windsor Cast Iron...
Buck My Baby Girl NDS for DS Logo
134 people viewed this question
Top Buck Video Game Consoles & Games Experts
dj ese
Level 1 Expert
Person On the...
Level 1 Expert
Are you a Buck Video Game Console and Game Expert? Answer questions, earn points and help others
