Question about HP Mini Computers & Internet
Hp mini 210 keyboard
Keyboard works in the bios but not in the operating system. AS in, I can press the ESC key on bootup and get into the bios and move around in there but when it boots to the operating system the keyboard does nor work at all. I can plug in an external one and that won works fine on USB. In the system list there are two keyboards and they are listed as both working. Any clues??
  • Ric Virtue Apr 26, 2013
    Thanks for all the suggestions. I will get a new keyboard for it.
    C640 keyboard is only for Toshiba. So ebay says.
    Ithere another number you have for me?
    HP mini 210 is what I have.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 114 Answers
Go into add remove hardware in the control panel and delete the aux keyboard
Posted on Apr 24, 2013
  • 188 Answers
SOURCE: keyboard problem
You just need a new keyboard - those are easy to come by check ebay.com and search for C640 keyboard. New ones should only be about $30-$40.
To remove the keyboard you just remove all the screws on the bottom of the laptop that are marked with the letter "K" then carefully pop the keyboard up.
Let us know if you need further help!
Posted on Jan 12, 2008
fixyathing
  • 341 Answers
SOURCE: Acer TM4720 keyboard not responding during BIOS
yes try an external keyboard
Posted on Aug 11, 2009
  • 8 Answers
SOURCE: Computer wont boot. Keyboard wont work
Make sure all connections are free of debri....USB connections can become wallerd out so to speak and create the intermittant problem... Built in keyboard could have been loosened underneath the keyboard on notebook is a flexible connection that if pc has been droped or fallen so to speak could be needing to be reseated........
Posted on Oct 14, 2009
MalKontent68
  • 748 Answers
SOURCE: Loud fast beeps on boot.( Toshiba Qosimo F45 )
Looks indeed as if the TAB key was stuck or malfunctioning. The most common cause for such behavior is a liquid spilled on the keyboard, a bit of which got between the layers of the keyboard membrane films and causes intermittent semi-short between conductive areas.
A trace of liquid caught between plastic films is hard to get rid of, as it practically sealed and doesn't evaporate.
If it doesn't go away, you may need to replace the keyboard, which is not very expensive fortunately,
Posted on Jul 08, 2010
javeedcare
  • 316 Answers
SOURCE: Keyboard buttons do not work only the some
Hi
It looks like your keypad is the culprit here. It requires the system to be opened and the contacts to be cleaned which requires a service person. If its beyond repair then you have to get it replaced. This might be due to some liquid entering the keypad or due to wear and tear.
Regards.
PLZ. rate my suggestion.
Posted on Jul 19, 2011
How do I get it to go into bios when pressing f2 doesn't work?
Per the internet site, it depends upon the model of laptop. Here are some examples:
Laptops - Access Bios Settings Key
Issue
The most common Access Bios key is the "DEL" button or "F2". This depends on the laptop model, however, and can be confusing if you do not know which key to press.
Solution
Here is a list of laptop models and brands with the keyboard commands / key for accessing the BIOS Setup:
Acer: F1, F2, CTRL+ALT+ESC
ARI: CTRL+ALT+ESC, CTRL+ALT+DEL
AST: CTRL+ALT+ESC, CTRL+ALT+DEL
Compaq 8700: F10
CompUSA: DEL
Cybermax: ESC
Dell Laptops:
Dell 400: F3, F1
Dell 4400: F12
Dell Dimension: F2 or DEL
Dell Inspiron: F2
Dell Latitude: Fn+F1 (while booted)
Dell Latitude: F2 (on boot)
Dell Optiplex: DEL
Dell Optiplex: F2
Dell Precision: F2
eMachine: F2
Gateway 2000 1440: F1
Gateway 2000 Solo: F2
HP (Hewlett-Packard): F1, F2 (Laptop, ESC)
IBM: F1
E-pro Laptop: F2
IBM PS/2: CTRL+ALT+INS after CTRL+ALT+DEL
IBM Thinkpad (newer) Windows: Programs-Thinkpad CFG.
Micron: F1, F2, or DEL
Packard Bell: F1, F2, Del
Seanix: DEL
Sony VAIO: F2
Sony VAIO: F3
Tiger: DEL
Toshiba 335 CDS: ESC
Toshiba Protege: ESC
Toshiba Satellite 205 CDS: F1
Toshiba Tecra: ESC then F1 or F2
Toshiba Notebook [Newer models]:
  • Turn on the computer by holding down the power button while pressing the ESC key
    • The machine will beep, then display:
    • Check System, then press [F1] key.
  • Release the ESC key
  • Press the F1 key
Laptops Access Bios Settings Key
Apr 03, 2015 | Computers & Internet
What keys change bios values on asus u46e
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
this will set the boot order
hope this helps
if this fails you might try some of these
Acer: - Ctrl+Alt+Esc
ALR PC: (F2) or (Ctrl)(Alt)Esc)
AMI BIOS: (Del), (F1) or (F2)
AST, Advantage, Award, Tandon: - Ctrl + Alt + Esc
Award BIOS: (Del) or (Ctrl)(Alt)(Esc)
Jul 28, 2012 | ASUS U46E-BAL6 U46E-BAL7 U46E USB External...
How 2 enter the CMOS and BIOS 4 HP mini 210-1160NR
As SOON as you press the Power On button start tapping on the F10 key.
Tap in two second intervals.
If you hear a beep, or beeps, ignore it. Stuck Key Error Codes.
Computer thinks the F10 key is stuck.
You can no longer use your mouse, only the keyboard.
The Navigation Guide is at the bottom, and side.
(Doesn't state navigation guide)
Also;
HP Support > HP Mini 210-1160NR PC > Manuals > Service Manual,
(Free),
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lang=en&lc=en&product=4221568&
Left-click on -
HP Mini 2102, HP Mini 210, and Compaq Mini 210 - Maintenance and Service Guide
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
It may take up to 30 seconds before the first page comes up.
Go to Page 71. (Using the Adobe Reader page number box, in the toolbar. It is to the right of the Down Arrow )
For additional questions please post in a Comment.
Regards,
joecoolvette
Dec 04, 2011 | HP Computers & Internet
I had lost my Dell Latitude D600 Bios passowrd. So I removed the comos battery (behind main battery) and reinstalled it. But now my laptop is giving this message on bootup "invalid system...
  1. Set the BIOS to defaults:
  2. Restart your Dell laptop. Click on "Start," "Turn off Computer" and "Restart."
  3. Press "F2" during the boot process to enter the BIOS. Press "F2" before the Windows loading screen. Certain models may use a different key. The key will be displayed during the boot process. For most Dell models, the key is "F2."
  4. Use the "Alt" + "F" key combination to load defaults.
  5. Press "Esc" on your Dell laptop keyboard to save and exit.
  6. Choose the "Enter" key to save all changes and exit the BIOS screen. Allow your laptop to restart for BIOS settings to reset.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 22, 2011 | Computers & Internet
How do I restore an HP Mini 110 Computer
To restore the original operating system and programs using the System Restore utility that is installedon the device, follow these steps:1. Turn on or restart the device, and then press the esc key repeatedly while the "F10 = BIOS SetupOptions" message is displayed in the lower-left corner of the screen.The "System Restore" page opens.2. Use the arrow keys to select System Restore, and then press enter.3. Follow the on-screen instructions to restore the system.
Doing this will wipe the hard drive.
Use the following link to download the service guide manual if needed.
http://h10032.www1.hp.com/ctg/Manual/c01895806.pdf
Dec 06, 2010 | HP Mini 110-1037NR Netbook
How do I acces the Bios on a Compaq Presario 5000 built somehere around 2002.
during the bootup post routines you should see a message that tells you what to do to go into the bios.
Sometimes the post routine is run without being shown on the screen. If so, try pushing the F2 button, or DEL key during the bootup sequence.
Dec 29, 2009 | Compaq Presario 5000 PC Desktop
How to go to boot settings in IBM 6578-PBU machine
Try each of the following: F1 F2 ESC DEL F10
Aug 26, 2007 | IBM NetVista A40 PC Desktop
Computers & Internet Logo
75 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
