I have a Fujitsu AC model ASY9AMQCW that is malfunctioning. When I on the AC, it does not blow out cooling air, only wind. The compressor does not function when I on the AC. This occurred after several power trips, although we did not on the AC at that time. Please advice on any solution, thank you
2 Suggested Answers
SOURCE: AC Fan doesn't blow cold air, frozen coil noticed outside, resetting power resolves temporarily
You need to call a reputable service technician.  The freezing up usually is associated with a low refrigerant charge or low air flow.  Check your return air filter and replace as needed.
Posted on May 30, 2009
Why is hot air blowing out of air conditioner
If it is a wall mounted one like the one in the picture and it is fairly new, and possibly a Fujitsu or LG, it may be by design. Modern AC can run backwards to become a heat pump and takes the cold air from outside, extracts warmth and blows it inside for the winter months. The remote has different symbols for heat or cool.
If not new, and only blows cold it needs refrigerant gas, or at worst a new compressor..
Oct 30, 2015 | Heating & Cooling
Question about a fujitsu lifebook P5010. when i power up i have a blank/black screen although i can hear the fan running constantly. the little lcd display area next to the power button works. there are...
Hi insurancedud...
Try blowing the dust out of the laptop by using compressed air in a can or an air compressor, the compressor is the pefered choice (max air pressure 90 psi).
Blow the air into the fan discharge of the laptop, (be sure not to overspeed your fan) then blow the air into the intake of the fan.
Do this a few times until you have no more dust in your laptop.
Then see if that cooled it down, if not maybe your fan is faulty and not cooling properly.
You can also put a cooling pad with fans under the laptop to help cool , they have the laptop coolers with usb power.
Please take time to rate me thumbs up
Sep 11, 2011 | Fujitsu Computers & Internet
I am having Sanyo room AC model SA185 DX6. The AC was working when all of sudden it stopped working. I checked & found Circuit breaker had tripped. I turned on the Circuit breaker and started again,...
Hello, sounds like the compressor is shorting to ground, this means that one of the windings is making contact with tje shell of the compressor and making the breaker trip. The only option is to replace the compressor, you can check the windings by taking the cover off the compressor which holds the terminals, make sure the unit is unplugged and take one meter lead to each terminal and the other lead to a ground such as a screw you should have no resistance if the compressor is good, if the compressor is bad you will read resistance.
Apr 29, 2011 | Sanyo Heating & Cooling
I have a 2004 2.7 6 chrysler sebring lxi. ac blows really cold and periodically just starts blowing warm air. is there a relay or temp. sensor that might be going out and through a malfunction shuts down...
Cooling fans working? If you notice the air getting warm mostly while stopped, probaby cooling fans not turning on. if the fans are working properly, may be low on freon and need a recharge.
Jun 26, 2010 | 2004 Chrysler Sebring
04 mitsubishi outlander ac is not working
What to you mean not working?
a) Air blows but is not cool.
If this is the case, suspect refrigerant leak. Do not operate AC untill it is checked fully. Operating AC with freon leak may lead to compressor failure and expensive replacement.
b) No air blows at all.
If this is the case, suspect blown fuse or burned blower motor. Sometimes is just a fuse or may have a malfunctioning resistor (blower motor works only at full speed).
Jul 13, 2009 | 2004 Mitsubishi Outlander
Air conditioner not blowing cold air anymore
hi! there,
if no cold blowing,evaporator is not working,have you ever heard compressor is running,check this out,no compression of course you dont have cool on evaporator.if the compressor is running check the oprating current,if still have enough freon charge,if not running check thermostat reset setting on the coldest,ifn still not run check overload relay on panel control reset lever to put back compressor to run,check condensing fan if working,if not check also over load protection,this should be done by ac tech nician.have a nice day,dont gorget to rate me, thank's
Apr 18, 2009 | Fujitsu 24R1 Air Conditioner
Car ac malfunctioning
/Does the compressor kick in compressor or the compressor clutch might be shot
Feb 05, 2009 | 1998 Honda Civic
Heating & Cooling Logo
56 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
