Question about Pool & Spa
Jindara igniting button stuck - clicking noise - fan also not going on
I have a Jindara Gas heater I think series 4000 of which they don't manufacture anymore. When I turn on the switch which ignites the burners - in the past it ticked a couple of times which is normal till it ignited - now the ticking sound does not stop. This has been happening for months and I have found it hard finding someone to come out and look at it (gave up Winter last year). Additionally, I just turned it on after a year, thought I would try and ignore the noise but now the Fan isn't working either. Has anyone had this problem, will it be an easy fix, considering parts not made anymore, I am hoping there would be a generic part? Frustrated especially now winter is here and I no point turning it on. Please Help!
jsrock516
  • 5911 Answers
SOURCE: Stove burner igniter does not work.
Your problem is not the igniter itself, but the burner switch that controls the igniter. All the igniters get their power from one spark module that is mounted somewhere in back of the oven. That's why you are able to get all the igniters to spark with only one burner control turned on. This is normal. That is also why you are able to light the burner in question buy turning on another burner. The spark is being provided by a switch that is working. To answer your question: the igniter is removable, but I don't think it's necessary. Cleaning them generally doesn't make them work better. I would check the wiring from the spark module to the burner switch and/or replace the switch. I hope this helps.
Posted on Jul 18, 2007
SOURCE: Pool heater burners won't ignite.
Also you need to inspect the igniter.
Posted on Apr 25, 2009
  • 10865 Answers
SOURCE: Propane patio heater ignition problem
I would change the thermocouple and here is why:
The thermocouple is the pilot's, well, co-pilot! It is the electronic device that senses if the pilot flame is hot enough to sustain burning the gas fuel from the burner. If the thermocouple thinks it's safe, then it keeps open the main gas valve located in the pilot assembly. If the thermocouple does not sense enough heat from the pilot flame (such as when the pilot is out), then the thermocouple shuts off the gas valve to the burners.
How the Thermocouple Works
So what is this thing and how does it work? Well the thermocouple (technically called a thermocouple junction) is a device that contains two metal wires welded at the ends and placed inside a protective metal case. The thermocouple sensor is found at the business end of the pilot flame and is designed to be placed in the hottest part of the flame. The other end is connected to the pilot valve body. As the thermocouple heats up, it produces a small amount of electricity and when it gets hot enough from the pilot, send a signal to open the gas valve by using a solenoid operated by a 24 volt transformer. The thermocouple calls the shots, and by converting heat to an electrical signal, it allows the gas valve to open or close. Once the gas valve is open, gas is then constantly supplied to the pilot and as required for the gas burners (as called for by the thermostat). If the pilot goes out, then the thermocouple gets cold and produces no electric signal to open the gas valve's solenoid and the gas valve shuts off the gas supply to the pilot and burners
Posted on May 27, 2009
  • 82 Answers
SOURCE: Wolf Sealed Rangetop Stopped Igniting
Do any of the burners click? If not, you may need a new spark module. If only one isn't clicking you may need a new ignition switch that is just behind the knob. I have also seen wires get pinched,stopping the flow of electricity. It may also be a computer board issue which is rare. Sooo you really need to call for service.
Posted on May 28, 2009
SOURCE: Rinnai burner goes out when ignition button is released
The thermocouple [s] require replacement, or in my experience try servicing the unit first. There is an injector for the main pilot and a secondary injector for the flame thrower ignition. Both of these are prone to blocking due to dust and can be enough to shut the unit down. Although usually this is thermocouple related as you are manually keeping the unit running when you hold down the button, if the tcouple is broken it wont send enough millivolts to hold the magnetic valve open when you release the button.
Cheers
Posted on May 31, 2009
The hot tub Hester will not light up pilot but does turn on and bow cold air
Glenn,
Many things could be wrong. First off, the exhaust fan turns always goes on when you turn on(up) the thermostat. It does that to suck out any residual gas in the combustion chamber. After about 10 seconds you should hear a click which is the gas valve opening to let the gas into the chamber. You should also hear a series of clicks for about 10 sec, which is the electronic ignition firing. If you hear the clicking of the ignition, but do not smell gas from the exhaust, then the gas feed is being blocked. If you don\'t hear the ignition clicking then the computer board is detecting a fault condition by one of its sensors: over-temp, water flow, exhaust fan . These are all in series and if one doesn\'t pass then the ignition won\'t fire.
Jun 08, 2013 | Pool & Spa
Laars lx won't ignite
hot surface igniter may not be hot enough to ignite the burners
Jan 09, 2013 | Teledyne Laars Laars Lx Pool Heater /...
I bought a used six element ninnai propane ventless heater and I don't have the model number. It has three buttons and a push button igniter all spring loaded. After igniting (all burners work) it take...
Despite what you may think, Rinnai still makes vent-less portable gas heaters. The following is a link to all they have to offer. Find the one that looks like yours and click on it. From there you can find and download the Owner's Manual.
http://www.rinnai.com.au/index.php?option=com_products&task=categories&Itemid=2&cat_id=45
As far as adjusting the pilot flame is concerned ... there is no pilot flame adjustment on vent-less gas appliances. In addition to cleaning the tip of the Thermocouple, you should also blow out the pilot tip using canned compressed air with a straw nozzle (like you clean your computer with). Especially, if the pilot flame is curling up and away from the thermocouple. It may simply be a case of a dirty pilot.
I hope this helped you and thanks for choosing FixYa.
Sep 08, 2011 | Heating & Cooling
I have a Hotpoint gas range that has electric ignition for the oven. However, I don't have electric at my cabin. Is there a conversion kit for a straight pilot ignition available? The model number is...
Most gas ranges with electronic ignition aren't equipped to have a straight pilot ignition.
I'm don't even think they make conversion kit because of the routing of the gas tubing for the pilot source.
Usually you have to turn the gas knob way over to get the "click-click-click" of the igniter.
Its just as easy to turn on the gas and light with a match...or a long butane lighter.
Even a "striker" used in welding will provide a source of ignition.
A last ditch effort would be to get a replacement gas grill igniter...all ya gotta do is place the bottom of igniter on metal surface and press red button. (kinda works like a spark plug) and no A/C needed.
Hope this helps some.
Jul 18, 2011 | Hotpoint RGB745 Gas Kitchen Range
For some reason the heater does not generate heat. the fan works but no heat. Any Ideas?
I've got an easy way for you to check, and then we can help you from there.
First pop open both lids to your furnace (this may require a screwdriver). Turn up your thermostat, push the safety interlock button in if it has one (it's a button that turns off the power when the doors are removed), and watch.
On most modern furnaces (past 20-25 years) you'll hear/see:
1. Inducer fan
2. orange glow (ignitor)
3. Gas valve opening and ignition (flames)
4. Main Fan.
that's normal heater operation.
The most common issue here is a burned out ignitor, in which case you wouldn't see the orange glow but the sequence would attempt to continue anyway (the gas valve will open and hiss gas, but it won't lite, then it'll give up and try again a few minutes later).
On older furnaces there's a pilot light to start with, the click of the gas valve and boom... ignition.
On new furnaces it's
Inducer fan
gas valve opening
spark - ignition
Main fan.
and there are some oddballs in between, particularly the Lennox Pulse. If that's your furnace just back away slowly and call a professional... some guys won't even touch those, so be sure to mention what it is... if you call a pro.
So go ahead and watch it run, then tell me/us what you see.
May 06, 2011 | Bionaire Heating & Cooling
Heater making loud noises
I had this problem with mine ( hayward h series abg100 ): exhaust fan turned on, waited approx 15sec, gas turned on, ignition, flame lit (can verify in flame window below knob), stayed lit for ~5-10 seconds (varied), I heard popping, cracking, knocking, banging noises, then gas turned off.
I believe the reason it does this is the bypass/diverter plate in the exchanger (right at the inlet side) is loose; the weld broke loose. They weld this very poorly and is obviously a known issue with the unit. I think storing it outside in the winter doesnt help. Another reason for the noise could be not enough water going through the exchanger because of a problem with the diverter plate, therefore the exchange gets to hot and boils.
I believe the ignition board senses this somehow (not sure how though, only way I can think of is via the ignition sensor), and cuts off the gas. I managed to fix this by putting on a small stainless steel hose clamp around the thermostat forcing the divertor plate tight up against the top so the water flows through the 3 exchange pipes. This was a very difficult maneuver due to working inside the tight pipe, but it worked!
You can check if you have the same problem as me by taking off your hose input to the heater, and removing the outer 2 PVC reducer connectors. Then you'll have access and sight to the exchanger input (3" pipe?) and should see what I'm talking about. If the plate moves (or isn't tight) then you most likely have the same issue. kevin71246@hotmail.com if you have questions.
Jul 06, 2009 | Hayward H Series Induced Draft Abg 100,000...
Banging and shaking, still heating
Pool & Spa Logo
42 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
