Question about Swarovski Optik (58026S) Binocular
Condensation on several lenses in left tube of 10/42!!wow
10 42 with condensation on multiple prisims within tube, absolutley freaked out what shall i do.
  • 117 Answers
I live in Florida and my binocs frequently get wet.I put them out in the direct sun for a couple of hours and it cooks the moisture out of them. I have had a pair of Pentax 12x50s for about 30 years.I've probably dried them out a dozen times or so.Good Luck
Posted on Mar 25, 2009
In memory slot by mistake i had inserted small memory card i shall take it out
Yes , use only compatable memory card.. of your are unable to take it out , it's better to take it to a service center. You can use a plastic paper cut it in shape of the slot a bit longer in size. Place it within the slot and try to pull it out.
Apr 27, 2015 | Nikon D3200 24.2 MP CMOS Digital SLR with...
Refrigerator not defrosting?
Hello William;
My name is Peter. I am a retired field service refrigeration technician.
You freezer section goes into a defrost mode every 8-10 hours,where your unit shuts down except for the lights, and your defrost heater turns on for 20-30 minutes.
You have a bad defrost heater. If the defrost heater does not come on, then after several days your cooling coil will become blocked with ice and you will not get air flow thru it. Your evaporator (Cooling) fan may also lock up.
Test your heater. You did not provide a model number, so I do not know what type heater you have. Some heaters are steel bars and some are glass tubes with wire inside. They all test the same. You will need a multi-meter.
Set the meter to the lowest Ohms (Omega Symbol). Disconnect the two ends of the heater. With the meter, place one meter lead on one heater contact end and place the other meter lead on the other end. You should get some reading. It could be 25, 50, 150 something. If the meter reads '0' or infinity the heater is bad.
Dec 21, 2014 | GE Refrigerators
Have a meade digital telescope and i cleand the lenses and now i cant see outta the how is the eye piecers supposed to go back in ,in other words which way are the lenses suposed to face
No one can tell you-- with multiple lens eyepieces only the manufacturer knows-- you VOIDED any warranty by opening up the eyepiece. Only the outside surfaces should ever be cleaned.
Best bet is to try several configurations --- there could be several HUNDRED different ways to assemble.!!! ???
Chalk it up to experience and never disassemble an eyepiece again--- some of them have as many as 8 or 9 elements inside.
Sep 09, 2011 | Optics
Wollensak 15x, rochester ,usa I took the lens out of the smallest tube and need to put the lenses ,washers ,spacers, back in right order from eye side to fourth lens/
No one can answer this question-- there are multiple ways that lenses can go together. You should NEVER disassemble the entire lens-- only the outside surfaces ever need cleaning.
Mar 04, 2011 | Optics
Out of focus
Assuming you are focussing correctly. When binoculars are out of collimation the most usual effect is double vision as the optical axis do not line up. The only thing you can do is to take them to a binocular repairer. The problem is the cost. Proper repair need the use of a device known as a collimator and it is a laborious task to do it properly. Your binoculars do not carry a high monetary value and a proper repair will cost more than a new binocular of similar specs. Porro prism binoculars mostly have the objective lenses set further apart than the eyepieces. This holds true except for reverse porro prisms which are the other way round. Roof prisms have both the front and rear lenses inline.
Make sure when you focus that the first eye you use to focus with is the one where the eyepiece does not have its own focus ring (dioptre). The dioptre adjustment is on either the left or the right depending on the brand. That eyepiece should be left alone until you have focused using the center ring. Then leave the center ring alone and focus the eyepiece that has the adjustment ring.
Mar 12, 2009 | Optics
Left in the snow for a week
the board inside wil be damaged  try kepping it in charge for several hours  it must work if not then the  board has to be changed
Feb 15, 2009 | AT&T Sony Ericsson W580i Cell Phone -...
Pentax k110d Lenses are all a little lose
There are many little parts. I would think twice before considering the removal of the lens mount. Only attempt this is you are absolutley certain that it needs to be done.
Nov 23, 2008 | Pentax K110D Digital Camera
Swarovski Optik (58026S) Binocular Logo
207 people viewed this question
Top Swarovski Optik Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Swarovski Optik Optic Expert? Answer questions, earn points and help others
