Question about Zanussi Washing Machines
WASH MACHINE NOT WORKING RIGHT
WASH MACHINE KEEPS CUTTING OUT AND DISPLAYING E62 WAS WONDERING WHAT THIS MEANS AND WHATS WRONG WITH THE MACHINE
    President:
  • Zanussi Master
  • 662 Answers
E62 Overheating during washing --- Drain, end of cycle.
Try changing temperature or cold wash.
Click if helped pl.
Posted on Apr 24, 2013
  • 74 Answers
SOURCE: Washing machine keeps stopping
pull the machine out and put the drain hose into a bowl to empty the water out when you have emptied it try cleaning the pump filter and check the drain system for blockages if that is ok then it looks very much like your door interlock is duff good luck and rate me.....
Posted on Feb 17, 2008
SOURCE: My Hotpoint Aqualtis washing machine
My Aqualtis just stopped mid program with F-05 on the display. This is apparently a failure to drain properly. I was luckily able to hold the power button to cancel the current program drain the water out (very slowly) and empty the machine.
THIS IS HOW I RESOLVED MY PROBLEM.
Disconnect the machine from the mains. Turn off the water supply to the machine. Disconnect the cold water pipe from the machine at the top corner.(Watch out for some water) Remove the drain hose from where you have it going to.  Pull the machine out and lay it gently down on the left side panel (use a towel to protect the side and absorb any water). Then, from the now exposed underside there is a black rubber pipe connected to the pump (black) coming from the main drum. Use some pliers to pinch the steel spring that clamps the hose in place and remove. Then using your fingers (there is nothing sharp in there) see if you can find any blockage.
I REMOVED: A pound coin, a dairylea slice wrapper and a piece of kinder bueno packet.
Carefully replace the black hose making sure it is fully on. Replace the drain hose, reconnect the water pipe and turn the water back on. (check to see it's dry with no leaks). Plug it in, turn on and that for me was it. Job Done.
Posted on Feb 01, 2009
SOURCE: ZANUSSI WASHING MACHINE
I have taken out the filter and washed it thoroughly! Also flushed the out pipe to make sure the whole system was clean. This resolved the problem
Posted on Feb 08, 2009
mindreader
  • 578 Answers
SOURCE: what does nf mean?
NF = Not Full
Is displayed when machine does not fill with water in the allowed time. Could be low water pressure at the feed pipe. Could be dirt clogging the inlet hose screen. Could be that the faucet valve is not fully opened.
Let us know of your success!!
Posted on Oct 12, 2009
backwoodsctr
  • 169 Answers
SOURCE: hi our washing machine keeps displaying error code
F01 - Short circuit motor triac - Book a washing machine repair. F02 - Motor jammed tacho detached - Book a washing machine repair. F03 - Wash thermistor open/short circuit - Book a washing machine repair. F04 - Pressure switch jammed on empty - Book a washing machine repair. F05 - Pressure switch jammed on full - Book a washing machine repair. F06 - Program selector error - Book a washing machine repair. F07 - Heater relay stuck - Book a washing machine repair.  F08 - Heater relay cannot be activated - Book a washing machine repair.  F09 - Incompatible eeprom - Book a washing machine repair.  F10 - Pressure switch not sensing correctly - Book a washing machine repair.  F11 - Pump cannot be activated - Book a washing machine repair.  F12 - Communication error - Book a washing machine repair.  F13 - Dryer fan or dryer thermisotor faulty - Book a washing machine repair.  F14 - Dryer element faulty - Book a washing machine repair. F15 - Dryer element relay faulty - Book a washing machine repair.  H20 - Not fillings. Check tap, hose and inlet valves LOCKED - Check interlock - Book a washing machine repair.  Here is a list of fault codes. I hope this helps !
Posted on Nov 21, 2009
What does error code E60 mean?
Family error code E60 is visible to customers and (could be E61,E62,E66,E68 and E69 only visible in service mode) means problem with heating phase.
Possible failures : heating element faulty, NTC sensor faulty, PCB faulty, wiring.
Dado
Apr 21, 2016 | Electrolux Washing Machines
Zanussi zde47100w what else can a e62 error be
E62, is a faulty heater unit, faulty wiring or faulty main control board. You have already changed the heater unit so check all wiring. If OK, then you will probably be looking at a new control board.
Apr 08, 2015 | Washing Machines
My electrolux front load washer had a bang and a spark on electrical display now showing E60 EWF 1087
Dado
Feb 21, 2015 | Electrolux Washing Machines
I have a Frigidaire Affinity front load washer ATF6000ES. The lights on the control board go on and off on their own and it beeps at the same time. I've tried resetting it but have the same result. When I...
Thank you for your inquiry, Steve Lesko!
I understand that your Frigidaire washer is displaying an error code of "E62" and the lights on your panel go on and off with a beeping sound. I do not show "E62" as a valid code it could be a possible miscommunication with the control panel and I would recommend performing a reset on your range. You can do that by disconnecting the power from it for roughly ten minutes. Also, think about what may have happened prior to this occurrence. For instance, did you notice any strange functions or other error codes? With this information I can better address the issue at hand. In the meantime, I suggest resetting your washer. If resetting the power does not correct the issue, could you please inform me of the new error code or if your washer continues to display "E62". I look forward to assisting you. -Matt
Jan 30, 2015 | Frigidaire Washing Machines
E62 code on display
E62 - Power relay to heater unit faulty
Could be:
  • Heater unit faulty.
  • Wiring faulty.
  • Electronic board faulty.
At this fault appliance forced cooling cycle.
Dado
Mar 11, 2014 | AEG T57800 Electric Dryer
H20 is showing on the display screen of my hotpoint washing machine. I'm aware this means water but I'm wondering why this is displayed?
Possible that there is no INLET pressure or water flow to the machine, check the inlet filter and valve, check for good flow to the valve if the hose is disconnected. If not it needs to be checked if the panel board is showing error due to memory fault..
Jan 23, 2013 | Washing Machines
F02 keeps showing on display
If, after
four (4) minutes the pressure switch still senses foam in the wash tub, the Central Control Unit will
go into Failure Mode. The digital display will show, F02.
Cause: wrong detergent, too much of the right detergent, detergent placed in wrong compartment.
Feb 18, 2010 | Whirlpool GHW9400 Duet Washer
Indesit wie157 washing machine. led displays error code "door", ive bought a new interlock and replaced it but it still wont work, what is wrong? thanks paula
Make sure the door is positively latched in.,some times a weak or broken door spring or striker is the cause of the problem, if you are satisfied these are o/k, then it is probably a control board problem, and you will probably have to call an engineer.
Plz rate my solution.
Thanks.
Jan 09, 2009 | Indesit W 123 Front Load Washer
Washing Machines Logo
170 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
