Phrm01l question answer paper - Office Equipment & Supplies
What is the maximum temperature for 20lb Office Depot copy print paper?
The answer to your question is on the office depot website and it catches fire at 450 degrees F. So your answer is no it cannot accept 467 degrees.
Jan 31, 2016 | OKI Office Equipment & Supplies
Tip
IITJEE 2011 FULL SOLUTIONS
Download the full solutions of IITJEE 2011 from below given links.
IITJEE 2011 FULL SOLUTIONS PAPER 1
IITJEE 2011 FULL SOLUTIONS PAPER 2
IIT-JEE 2011 AnalysisIIT JEE 2011 was conducted on 10th April 2011 in 131 cities all over India in 1051 centres for 4,85,262 registered candidates. For the first time, JEE has announced that scanned images of the Optical Response Sheets (ORS) with the candidates' details and their responses (answers) will be displayed on the JEE website after 25th May 2011. Answer Keys to JEE 2011 questions will be displayed on the JEE website on 15th May 2011 after completing the evaluation of OMR Sheets.
There were 10 versions for IIT-JEE 2011 - 0 to 9. The order of subjects in both papers were the same - Chemistry, Mathematics and Physics but the total marks, the number of questions and types of questions in both papers were distinct from each other.
Paper-1Paper1 had 69 questions in total for 240 marks - in the order of Chemistry, Physics and Mathematics. Each subject had 23 questions and the pattern was exactly the same for all the subjects.
Chemistry
This is a moderate level paper leaning more towards easy level of difficulty. The usual weightage of Physical > Organic > Inorganic Chemistry is maintained. Most of the questions in this paper evaluate the conceptual clarity of the student.
Physics
Overall the difficulty level of the paper was moderate. Still there were a few numerical questions involving elaborate mathematical calculations making them time consuming and hence difficult. No representation of Optics in this paper. Major focus in this paper was on Mechanics (for a total marks of 31)
Mathematics
Mathematics part of the 2011 JEE paper 1 was considered easier than the paper 1 of 2010. Few questions in Integer answer type require in-depth understanding of the concepts with perseverance in solving problems. Trigonometry had a good representation in the paper; the passage on matrices required quick thinking to interpret and solve the questions. One question about '3 x 3 non-singular skew symmetric matrices' has a basic flaw since odd ordered skew symmetric matrices are always singular. Paper 1 was a moderately difficult paper.
Pattern of Paper-1:
  • Q.No.1 to 7 - Single Correct Choice Type (7 questions for 21 marks). +3 for correct answer and -1 for wrong answer
  • Q.No. 8 to 11 - Multiple Correct Choice Type (4 questions for 16 marks). +4 for correct answer with NO negatives
  • Q.No. 12 to 16 - Paragraph Type(5 questions for 15 marks). There were 2 paragraphs- one paragraph with 2 questions and the second one with 3 questions. All questions were of Single Correct Choice Type. +3 for correct answer and -1 for wrong answer
  • Q.No.17 to 23- Integer Type (7 questions for 28 marks). Answers were of single digit (ie, 0 to 9) . +4 for correct answer with NO negatives.
Instructions for the exam was given in the front sheet itself and only 2 pages were provided for rough work. Among the subjects, students felt that Mathematics was a bit tough while Chemistry was easier.
Paper-2Paper 2 had 60 questions in total - in the order of Chemistry, Physics and Mathematics. Each subject had 20 questions and as in paper 1 the pattern was exactly the same across the subjects. Questions had differential markings, each subject had 80 marks and the maximum mark for the paper was 240.
Chemistry
Paper 2 of IIT-JEE 2011 was difficult compared to paper 1. Weightage wise the Physical > Organic > Inorganic formula is maintained. Generally the nature of the questions in Physical chemistry is calculation oriented and hence the difficulty. Also complexity of Organic questions made this paper a challenging one.
Physics
Questions from certain areas which were not represented in paper 1 (gravitation, optics etc.) appeared in paper 2 thus balancing the Syllabus coverage. The difficulty level of this paper was slightly less than paper 1 especially the Integer Answer Type.
Mathematics
Paper 2 Mathematics part was tougher than the first paper - for the complexity in combining topic areas, for e.g. the matrix match had questions from 4 different areas posing a challenge for the student in the exam hall. Likewise, this paper required more calculations in solving than the first paper. Overall Mathematics part of IIT-JEE 2011 was less difficuly and less time consuming than that of 2010. The second paper was restricted to lesser number of areas, for e.g. there were no questions from Trigonometry. But this time Differential Calculus and Coordinate Geometry were well
represented.
Pattern of Paper 2:
  • Q.No.1 to 8 - Single Correct Choice Type (8 questions for 24 marks). +3 for correct answer and -1 for wrong answer
  • Q.No. 9 to 12 - Multiple Correct Choice Type (4 questions for 16 marks). +4 for correct answer with NO negatives. There was NO partical marking as well.
  • Q.No. 13 to 18 - Integer Type (6 questions for 24 marks). Answers were of single digit (ie, 0 to 9) . +4 for correct answer with NO negatives.
  • Q.No.19 & 20- Matrix Match Type (2 questions with 4 rows each - for 16 marks). There were 4 elements in the first column to be matched with 5 elements in the second column. Each row carried 2 marks. There were NO negarive marking.
Chemistry section in Paper2 was difficult compared to Paper1. Mathematics and Physics sections were only moderately difficult.
Courtesy: TIME
on Apr 11, 2011 | Computers & Internet
HP mfp 1005 have paper jam
Have a look at these:
1) Step by step from HP
http://h20564.www2.hp.com/hpsc/doc/public/display?docId=emr_na-c00765431&sp4ts.oid=1839460
2) Video "Fixing a Paper Jam - HP LaserJet P1005 Printer"
http://www.fixya.com/answer/answerpageslideview.aspx?ctg=6&fml=0&brd=29&p=2&thid=25695693
3)A brief answer:
https://in.answers.yahoo.com/question/index?qid=20120106072829AAnt9Db
Good luck
May 14, 2015 | HP Office Equipment & Supplies
What does it mean when my printer say output tray is full?
Please specify which model you have for a more complete answer. But the basic answer is that when the paper exits the machine and falls in the bin it hits a paper exit sensor. As the paper piles up it will eventually hit the paper full actuator and then energize the paper full sensor. Check to see that the paper full actuator is intact and not broken or missing.
Sep 06, 2014 | Xerox Phaser Office Equipment & Supplies
Paper won't feed from tray canon mp760
check in your front panel the button "Feed switch"
If you press the butto, the led change to show where the printer get the paper
If led up, you must place paper on Autosheed feeder
If led down, you must place paper on tray Cassete
If the error continue. check if they are Jam paper .
Is important for people who share their knowledge, know your comments. If the answer is helpful, rate my answers
Sep 27, 2011 | Canon PIXMA MP760 All-In-One InkJet...
Will a ricoh printer automatically print once paper has been replenished
Short answer: Yes.
Long answer: As long as there was no other error or problem, if you send a print job and the tray it wants to pull from is out of paper, then as soon as you put paper in the tray and the printer recognizes the paper, it will resume printing.
(If you put in paper of a different size or type than the paper the printer is looking for, it will display a mismatch error and won't print until you tell it to continue or form feed.)
Jun 15, 2010 | Ricoh Aficio AP610N Laser Printer
Copier
found the answer here
http://answers.yahoo.com/question/index?qid=20080723123315AAN1eBy
Jul 12, 2008 | HP PSC 1610 All-In-One InkJet Printer
Panasonic KX B520 does not ptint
I'm not sure if this will help, but we pulled my Panasonic KX-B520 printing whiteboard apart to find out why it didn't print. After a couple of hours and much head-scratching we figured out the paper was in the wrong way around. The printer was working fine, it just couldn't print on the wrong side of the paper. Even though the diagram on the inside of the paper bin showed the the print side of the paper on the outside of the roll, this particular paper roll had the print side on the inside. Answer? Put the paper in the other way around. It works a treat.
To see which side your paper prints on, hold a match or lighter to one side of the paper and see if it goes black from the heat. One side will, and the other won't (well, it will burn, but not like the other side. Use your common sense here.) The print side of the paper should contact the horizontal metal strip at the top of the paper holder bay.
Good luck. I hope my answer works for your problem, because it's so easy to resolve.
James from Canberra.
May 03, 2008 | Office Equipment & Supplies
Check paper
Normally the paper sensor is a leaf switch which gets operated by weight of paper being pulled in the paper movement path.Since this is a plainpaper fax u must be using A4/legal size paper sheets.Check the paper path visually to find the paper sensor .If its a switch u need to clean the contacts with WD40 or similiar switch cleaning fluid.
Other chance is an optical reflective sensor maybe used in which case you may need to just clean the upper surface which rides below the paper.
Hope this info helps.
Samir
Mar 13, 2008 | Brother IntelliFAX 770 Plain Paper Thermal...
14 people viewed this question
k24674
