Question about Genicom Tally T6212/6215/6218 Black Ribbon 60m Chars 083683
Error 0x00000002 when install driver win 7 - Genicom Tally T6212/6215/6218 Black Ribbon 60m Chars 083683
I have sis 661fx Motherboard with intel 3.06 GHz processor with 1gb Ram.I have installed Win 7 last month.The Aero feature is not working on my system.i tried to update the drivers but wen i troubleshoot...
Did you run the Windows 7 upgrade advisor before you installed Win 7. You may find that windows 7 doesn't allow the use of your graphics hardware. With the issue of Win 7, Microsoft decided that they would only allow the use of hardware that had been tested by themselves. To enforce this all drivers for Win 7 onwards require "Signed Drivers" to operate properly. You may need to buy a Win 7 ready graphics card to continue with a stable computer.
Feb 19, 2013 | Computers & Internet
Error code 0x00000002
STOP 0x2 DEVICE_QUEUE_NOT_BUSY error code has a value that is 0x00000002. This is a fatal error typically known as STOP message or Blue Screen of Death (BSOD).
This error generally occurs in Windows XP but may also occur in latest version of Windows such as Windows Vista or windows 7. The computer may stop responding without warning. Moreover, your computer may give error messages like STOP 0x00000002 error or related errors and if blue screen appeared then you may have to restart the system in the mean time of your work due to which unsaved work will be lost.
Cause of Error:
  • You may be using corrupted profile in your system which raised this problem
  • The device driver of your system is not updated
  • Malfunction of hardware usually is the cause of error such as STOP 0x2 DEVICE_QUEUE_NOT_BUSY or similar error
  • Registry database of your system may have corrupted or modified erroneously by invalid application
  • You have installed new hardware unsystematic or installed unknown application
  • Spyware has infected the PC
  • Antivirus software is not working
  • The operating system or application might have run out of usable memory.
This is one of the serious problem in computer if it is not resolved instantly then it might create some more unexpected error. STOP 0x00000002 error and its related error will disturb you all the time and you may have to bear loss of data. When blue screen of death appear on your monitor screen then you need to restart directly whether you have saved your work or not. Therefore, you are suggested to fix STOP 0x00000002 error as earliest possible.
How to Fix:
To fix STOP 0x00000002 error you need to follow the following methods.
  • If this error occurs in your pc then you will have to restart the PC and then press F8 key before appearing Windows. You will see a black screen with white text giving many options. Select the option "Last Known Good Configuration" and press Enter. If you have configured the computer improperly then it may fix the error.
  • If you have installed any hardware in your system then the chances is more that the device driver is not updated and thus errors of type STOP are given at the time of operation. You must download latest drivers.
  • If your system does not become stable then you need to try scanning of registry with this tool. Since, registry keeps all configurations of your system if it gets impaired then you must download registry repairing softwareand repair it .
Mostly, spyware has been the reason of various errors in computer system. Spyware damages files in the computer system and if once damaged then it is no longer used and it also corrupt registry database. The file which is infected by virus may be a program file, system file etc. If STOP 0x00000002 error occur in spite of antivirus then download anti spyware to scan your computer.
Hope this information will help.
Your response is very much appreciated. Thank you for using Fixya...
Sep 28, 2011 | Microsoft Computers & Internet
0x00000002 from 1 and a half years
The stop code 0x00000002 normally appears when unit fails to install the Language Pack update from Microsoft. Check the below link for the instruction on how to manually install Language Pack to correct the issue.
http://windows.microsoft.com/en-US/windows-vista/Windows-Update-error-2
Hope this helps.
May 27, 2011 | Toshiba Satellite 1410-S173 Notebook
I have a Samsung external 3.5 floppy drive, a SFD 321u which has worked fine in my old Win XP computer. I have a new system with Win 7 and this drive will not work with the drivers on the CD and Win 7...
If it is a USB external drive it should be recognized by your laptop, it worked for my dell floppy drive from xp to win 7 64bit, if it does not you should download the winxp driver and use it to install in win 7 when it does not recognizes the drive.
-select have drivers
-select downloaded drivers
it would give you an error of pop up saying drivers are not "signed" just go ahead a accept that and it should work.
Let me know if it helps
Mar 17, 2011 | Samsung SFD 321U External Floppy Drive
When i install lg lxu 800 driver ... on windows 7 .. then i have a blue screen error ... dump memory so ,, sir plzzz help me what can i do ?
If you added a ram and reinstalled win 7 then remove that ram and reinstall win 7 clean install again
Mar 01, 2011 | Computers & Internet
I have a HP PSC 1402 All-in-one printer. I recently bought a dell laptop with windows 7 The installation CD does not support the OS I also downloaded a 363 MB driver from the HP site for win 7 -64...
Are you sure that the download was "successful" ?
> it still gave an error.
... and the text of that error-message is: ____________________
> How can install this printer on windows 7?...
You're on the correct track, namely download from http://support.hp.com and then install the software.
Aug 02, 2010 | Computers & Internet
Driver installation
some drivers won't work on win-7 so you have to load another one for win-7
Jun 12, 2010 | Computers & Internet
I want creative web cam pd 1001 driver for win 7
This particular model is compatible only till windows xp.... to download the latest xp driver for this particular product click here....
windows vista and win 7 are not compatible...
to know the available win7 drivers for creative products click here...
May 19, 2010 | Creative Labs PD1001 Webcam
Adi 6 channel for win 7
Win 7 is still in beta,so alot of kinks have not been worked out.
Jan 17, 2009 | ASUS M2N-MX Motherboard
Genicom Tally T6212/6215/6218 Black Ribbon 60m Chars 083683 Logo
47 people viewed this question
Top Genicom Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Genicom Office Equipment and Supply Expert? Answer questions, earn points and help others
