Question about Polaroid P3500S Plastic Id Printer
Why i cant print use p5300s polaroid?
When i execute to print, nothing out from the printer, i dont know why, please give answer.
Hello.! my problem... i have modified my printer (external ink). its great for the first 2 month. but after that i having problem in printing. sometime there is nothing on the paper. sometime the...
Check to see if the breathers have been plugged correctly.
Run a couple of cleaning cycles.
Execute a nossle print test, from the supplied software
Also execute a nossle cleaning from the software
Feb 17, 2011 | HP DeskJet F4280 All In One Printer InkJet
My HP Photosmart Printer keeps printing out a blank page between each page i want printed and i dont know how to fix it. Please Help its a pain fishing out blank pages.
For windows XP & Vista
Check the function after every step.
Step One: Power Cycle with printer
1. Use the On/Off power button to turn off the printer.
2. Disconnect the USB cable from the rear of the printer.
3. Disconnect the power cable from the electrical outlet.
4. Allow the printer to sit for at least 30 seconds.
5. Reconnect the USB cable.
6. Reconnect the printer power cable.
7. Turn on the printer using the On/Off power button on the printer
Step Two: Disable DEP (Data Execution Prevention).
Disable the Data Execution Prevention in Windows Vista and check by following the below steps:
1. Click on Windows Icon.
2. Control Panel->System->Advanced System Setting->Performance->Settings->Data Execution Prevention
It needs to be set to "Turn on for essential windows programs only", which is the default.
If you set it to "Turn on for all programs except those I specify", then the all-in-one driver stops working and you get blank pages.
Alternate Option for DEP
Right Click on My Computer.
Select Properties, under the Advanced tab.
Properties --> Settings --> Data Execution Prevention.
Step Three: Check the option of Separator page.
Please refer the below mentioned web link for better understanding the steps with graphics.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c01449854
Note: Clicking the link may give an error indicating it is invalid. If this occurs, copy the portion of the address on the remaining line(s) and paste it at the end of the address showing in your browser until the complete address.
Step Four: Print directly from printer
Spooler bypass
  2. Click on Printers.
  3. Right Click on HP Officejet All-in-One printer.
  4. Click on Printer Properties
  5. Click on Advanced Tab
  6. Click on the option "Print Directly to the Printer"
  7. Click on Apply
  8. Click on OK
Feb 02, 2010 | HP Office Equipment & Supplies
Cant copy or scan in my All in One Lexmark X6170.
You must have a CD.
Make sure the scanner is unlocked.
Try copying from ADF and scanner glass.
Oct 09, 2009 | Lexmark X6170 All-In-One InkJet Printer
Printing on a 3x5 card
sounds to me its software issue, the best way to do this is to go into your printer properties and check to see if it has selected 3x5 for print not 8 1/2 x 11
my wife has that problem all the time when shes trying to print pictures of the kids and ushally its due to not being setup on the printers properties you can also set it up from right here
if you go to file on the top menu here and then goto print from here we will be able to select the printer and goto the options on it and make sure the page is set for 3x5 make sure your printer is highlighted and then click on preferances and then look in there. I dont have a printer hooked upto my laptop right now so I cant give you any further steps but I know its in there.
let me know how you make out if I have to put a computer onto my laptop and give you more detail on this then I will
Oct 02, 2008 | Canon PIXMA MP160 All-In-One InkJet...
A920
i don´t have driver
Dec 10, 2007 | Dell 922 All-In-One InkJet Printer
Polaroid P3500S Plastic Id Printer Logo
37 people viewed this question
Top Polaroid Office Equipment & Supplies Experts
Joseph Gallucci
Are you a Polaroid Office Equipment and Supply Expert? Answer questions, earn points and help others
