Philips 200CW after turning it on screen binks for a second and goes black screen have to wait for 30 minutes then screen turns on.
Abypaulose
  • 10 Answers
SOURCE: Screen goes black
Hai,
Do you see any dull image on the screen ?
If yes the inverter Card/Backlight of the screen is having problem.
Regards,
Aby
Posted on Dec 22, 2007
Fix-4U
  • 293 Answers
SOURCE: LCD screen goes black repeatedly
Your inverter and AC Adapter is burnt out, need to be replaced.
Drop me a note, I'll give you a good price. repair@3rd-rocks.com
Posted on Mar 14, 2008
Fix-4U
  • 293 Answers
SOURCE: my Dell Monitro goes black about 4 seconds after being turned on
Hi..there,
It's seems you got a busted backlight inverter. Need to replaced a new one or repaired it.
Posted on Nov 13, 2008
Achabacha
  • 113 Answers
SOURCE: screen goes black, but power light is on (not blinking)
The problem is not with your screen. Its the problem of Video Card of your system which is unable to send Video Signals to the Screen.
Posted on Apr 23, 2009
dww0642
  • 79 Answers
SOURCE: SCREEN GOES BLACK AFTER A FEW SECONDS AFTER TURNING MONITOR ON.
More often then not, this is attributed to a failing Backlight Inverter. A Backlight Inverter, is a power board mounted below the screen that actually send power to the Lamp inside the LCD itself. Check to see, when it goes out if there isn't still some images faint in the screen. If this is the case take it to a local repair shop and have them order one and replace it. repair cost for this shuold be around 65-100 dollars.
If this helps, please rate my solution. Have a great day.
Posted on May 16, 2009
My Dell laptops is not working properly sometime it will on sometime it don't why,....!
Do you have the 7 beeps of death? Screen goes black for no reason? If so, turn it on, let it beep, wrap in a blanket for 15-20 minutes until it gets hot, remove battery, wait 30 seconds and try to restart. May take a few tries but it will work for a while and then you need to do it again
May 27, 2014 | Computers & Internet
How can I fix my laptop screen? It is black when I turn it on.
it's probably not your screen, it's your motherboard. if you get lights and some noise when you turn the power on but nothing on the screen wait about 30 seconds then press enter. then wait a couple of minutes with the sound knob turned to the right. if you get a windows startup jingle you're lucky and it's your screen or a bad connection, if you don't then it's probably your motherboard. sorry
Jan 11, 2011 | Compaq Presario CQ60-220US PC Laptop
Polaroid tv screen goes black after 30 40 minutes, sound is good. No picture. Turn set off and wait a few minutes and the picture returns for a few minutes then goes black again.
Ur tv now power on only have picture few mins,than dead,have sound only?Yes,than the 1 or 2 the long board call the LCD inverter boards are dead.The LCD inverter long boards help the LCD screen to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy 1 or 2 long LCD inverter boards for the replacement.
Jul 05, 2010 | Polaroid FLM-3232 Television
Philips tv with sound going in and out
Try bypassing the set's speaker by running an external audio amp. I use my bookcase stereo for audio direct from the satellite receiver and turn the volume off on the TV. Sounds better this way! Could be the audio amp in the TV is going bad or the speaker may be bad and the TV's audio amp goes through a shut down cycle.
Feb 10, 2010 | Philips 30PW850H 30" TV
I have a philips dlp 55pl9773 has one red flashing led on the front when i do a hard reset tv boots up lamps lites led goes from flashing yellow to green for about ten seconds and then back to red flashing...
MY philips tv model number 55PL9773/17 WAS TURNING OFF THE SCREEN AND LEAVING THE AUDIO ON FOR ONE MINUTE. THEN THE YELLOW LIGHT STAYED ON. THEN THE LIGHT TURNED OFF. thEN I TURNED ON WITH THE REMOTE AND THE YELLOW LIGHT TURNED ON AND A FEW SECONDS LATER CHANGED TO THE GREEN LIGHT AND THE TV TURNED ON. AFTER A FEW MINUTES, BETWEEN 10 AND 30 IT DID THE SAME THING. NOW IT IS OFF WITH A BLINKING RED LIGHT PERMANENTLY ON. TO TURN IT OFF I HAVE TO UNPLUG IT FROM THE WALL. I REPLACE THE LAMP A FEW WEEKS AGO AND IT IS FINE.
Dec 01, 2009 | Philips 55PL9773 55" Rear Projection...
System locked screen says Waiting for about 30 seconds then turns blank for about 30 seconds then goes back to waiting screen. is in a loop
prees Esc button the i hope u will able to break this cycle otherwise check ur start up by opening it in safe mode
Nov 24, 2009 | Computers & Internet
Screen tuns black after 15 seconds and comes back after about 15 minuts
The solder joints on the vertical output IC have cracked. This is a very common problem on those sets.
Nov 14, 2006 | Panasonic CT-27G34 27" TV
Computers & Internet Logo
87 people viewed this question
David Payne
David Payne
