IBM Laptop has no power
I know laptops and water do not mix .....but it did. Now, I have no power at all when I hook it up. Adapter has 20volts out of cord......Laptop is dead. Opened up computer......Doesn't look too bad.....Motherboard looks clear.NO BURNS.
  • Dwayne Dennis
    Dwayne Dennis May 11, 2010
    Sorry to say but *********** board has alot of little parts once they touch water they are done even if it doesnt show signs of water log
    you need a new one
  • computerscot May 11, 2010
    Motherboards have connections on both sides. One last resort you can try. Since you opened it up to look at it take a house hold fan and let it blow on it for a while. Also remove the battery and check the contacts. Remove all removable components and try to let it dry out.
    For next time if this happens again immediately shut it down (holding in the power button for 6 seconds) and then let it dy out for a good day with a fan blowing on it. I saved my 9 year ols laptop this way.
    Problem Solver:
  • 14 Answers
Your best bet is to bring your laptop in to either the manufacturer or a repair shop so that they can see if the motherboard is fried. It doesn't neccessarily have to smell or show burns to do this. Good Luck.
Posted on Mar 13, 2009
IBM ThinkPad T40, when connected to docking station the laptop will randomly stop working with USB connected items like mouse, keyboard, printer all connected to USB ports on docking station.
Try a power adapter with more amperage. When you connect a dock, the 3 amp adapter that comes with IBM laptops will not have enough power for lots of add-ons. You'll need the 4 amp adapter.
Oct 15, 2013 | IBM ThinkPad R51 Notebook
My toshiba laptop p10-792 turns off randomly. The plug in light and battery lights are flickering. Power light stands still. Whats the problem could be
Could be a few things:
I'd start with checking the security of the DC jack on the laptop, if it feels loose or sloppy, it is not making good contact with the motherboard and eventually it will spark across the internal terminals and damage the motherboard, needs replacing.
If that seem ok, get a multimeter, set it to DC volts at 20volts and touch the RED probe to the inner part of the ac adaptor plug (the bit that goes into the laptop), and the BLACK to the outside of the plug.
See it gives a constant 20 volts, if not (or the indicator light on the adapter flickers or pulses, then it is most likely a dying adapter (replace this).
If both the above are not the problem, then you have a more serious powerboard problem. Trying it on battery alone and then on mains alone will give some indication which is causing the fault, if both are giving you the cutting off problem, then you will need to have the laptop stripped and checked.
Jul 05, 2011 | Toshiba Satellite P10-792 Laptop AC Power...
I have a toshiba LT a205; the LED flashes 6x; what does that mean? the psu is rated at 19vdc, and puts out 18.5 vdc. The end of the power connector that goes to the mb only has 0.5 vdc on it, so I'm...
19volts is a nominal value. The AC Adapter will be fine from 18 volts up to 20volts because the power unit on the motherboard regulates the voltages very accurately.
You say you only have 0,5volts on the Mother Board power input. There's your fault. Between the Mother Board socket and the AC Adapter.
Replace the AC Adapter or Laptop Connection lead if you mean there is 0.5volts actually on the Mother Board but full oiutput from the Adapter.
Dec 15, 2010 | Toshiba Satellite A205-S4777 Notebook
My toshiba l300 can't even power.the led lights are not coming on.i have tasted the charger and it's working
When you connect the power adapter into the laptop, does the power LED light up? If not then -
The battery adapter or the adapter's power lead or the laptop's power socket could be faulty.
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Jul 22, 2010 | Toshiba Satellite Pro L300 Notebook
Ibm thinkpad R52 laptop no powering on, adapter is ok.
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
If this did not work, try also disassembling the laptop & make sure that all main components are seated properly. Also make sure that all ribbon cables interconnecting the various components of the laptop are tightly connected.
Dec 26, 2009 | IBM Lenovo ThinkPad R52 Motherboard -...
My Compaq Pres V2000 laptop does not get on with power on switch
Take out the battery and only hook up the AC Adapter to see if the laptop turns on. If it does then you know the battery is shorting out the laptop and either has very little power to turn on the laptop or is shorting out the laptop cause its bad.
If you don't get the laptop to turn on, make sure your using a well known working wall outlet to plug the laptop to and only use the AC Adapter. If you AC Adapter is hooked up and the Green Led turns on then you know the adapter is good.
After those two steps, you can also try taking out the dvd drive and the hard drive. Then try turning on the laptop and if the laptop still doesn't turn on then the motherboard is bad in the laptop.
Aug 29, 2009 | HP Compaq Presario V2000 Notebook
IBM thinkpad will not turn on ...had been used for 2 hous earlier..could heat have been the problem
Could have been a power surge that affected it by try a few things to be sure:
unhook the battery and only have the ac adapter hooked up. If you have a green light on the ac adapter then you know your getting power from that.
Try turning on the laptop and if you still get nothing then the motherboard is definitely bad.
Jun 27, 2009 | IBM ThinkPad T40 2373 Notebook
Power connector of T40 think pad loosen
If you can't charge the battery and you know the battery is good, hook up just the ac adapter to verify that the laptop can turn on without the battery hooked up and if your laptop turns on then you know both are good.
At that point I would say since its not charging then it could be that the dc jack has some bad solder points on the bottom of it and need to be resoldered. Sometimes if the solder goes dry and cracks just a bit if can cause the adapter not to charge the battery.
If that doesnt fix the problem the the motheboard is bad and would need to be replaced.
Apr 09, 2009 | IBM ThinkPad T40 2373 Notebook
My ibm laptop contionusly beeps and says power scource is battery,when i press esc, it boots normally and shuts down in about 15 mins to half an hour
A. Bad battery
B Bad power supply.
Sounds like the battery isnt charging correctly , the beeping is warning you it is running out of power.
Take the battery out , and boot normally with the ac adapter.
Does it work?
If yes, Get new battery. about 70-90 dollars.
If no. Get new ac adapter. 20-40 dollars.
links to parts
Mar 03, 2009 | IBM ThinkPad A21m 2628 Notebook
Ibm thinkpad no power with ac power adapter but works with battery
If prior to this it works intermittently with the AC adapter, it means the connection from the adapter power unit to the motherboard was lost and this is a typical problem with the Thinkpad. It needs a re-soldering job and not something that one can do without a proper repair manual on how to open the laptop. Try googling your problem and find out if someone has the same experience and managed to resolder by him/herself.
Oct 18, 2008 | IBM ThinkPad T41 Notebook
Computers & Internet Logo
David Payne
David Payne
