Question about GE AGQ08AH Air Conditioner
Descktop computer turns on, but no video
Hi, I have a desktop computer that went dead recently. I will describe a series of events that lead to that. I had a video card that went bad. I had it replaced. But that did not resolve my problem. I narrowed it down to the power supply. I replaced it and now it looks/sounds like it turns on, the usual start up sounds, but the monitor remains black and it never goes further than that. Somebody told me that I need to reset the bios so that it uses the integrated video rather than the graphics card. I dont know where to begin. Does anybody have any idea what else it could be wrong ? Any help is appreciated. Thanks
  • 1 more comment
  • Heather May 28, 2008
    I dropped my tower and the heatsink/fan came off of the CPU, making my computer come on for 5-10 seconds and then shut off. I cleaned the CPU and heatsink and then reapplied artic silver. (CPU never became unseated although I removed, cleaned and checked prongs - all good)
    Now my computer boots up, and sounds like normal - however, I'm getting no video whatsoever. I've tried disconnecting everything and adding each back in one at a time. I even took the battery out, cleared CMOS but still the same black screen. I tried connecting the screen to the on board video rather than my card and no luck.
    Any ideas? Prior to cleaning and reapply the artic silver - when my computer was turning on for those few seconds before shutting down automatically - the video was working fine. What the heck?
  • cpoluk Jan 30, 2009
    I am having the same problem. Powers up but no video or beeps. I went through this entire process and still am receiving no video or beeps. So likely the problem is the MB needs replacement?
    I am repairing this system for a friend. She said it worked fine, but when they moved it quit working.
    I have a computer has same problem. Powers on, but no video. I did the entire process you suggested and still get no beeps at all. So I'm guessing motherboard?? Lady I'm fixing it for said it worked fine until she moved then it started having this problem.
    Brigadier General:
  • 6,966 Answers
Hi, I'm assuming your motherboard has a built-in video card. Let's trying doing it by the numbers. 1. Remove all memories, cards, FDD, IDE or SATA cables from the motherboard. What should be left are only the power supply connector, the CPU + Heatsink & fan; 2. With the unit off & unplugged, pry/remove the 3V memory battery. Short the CMOS reset jumper. This is normally located very near the battery. If you can post brand/model of MB, we can probably point the exact location or you can go to the manufacturer's website and download the pdf file of the manual; 3. Leave it with no battery and the CMOS reset (not default) jumper in place. Give it a couple of minutes; 4. Re-insert the battery and remove the jumper from reset position and replace it back to default position (its original position); 5. Connect keyboard, power cord, monitor video cable (onboard video connector is below the printer port and beside the serial COM1 port) and; 6. Power up. Most cases you will have a series or combinations of beeps since there is no memory (and no video since the onboard video uses shared memory). Sometimes no beeps at all. Power off; 7. Install a single stick of memory. It would be a good idea to clean the edges/connector pins of the memory stick with the use of a pencil eraser. Further use a clean/new paintbruh to remove any other dirt. Use the same brush on the slot where the memory is to be placed. Seat the memory into one of the memory slots. Power up, there should now be a healthy pre-post beep (if you do not have an onboard video, a long beep will tell you that no video card present). If no beeps nor display in your monitor, power off, remove the memory and place it in the other memory slot and try again. If still a no go, try with another memory following the same sequence. 8. If still a no go, try with your videocard either in AGP or PCI-E slot as applicable; 9. If it works, you're set to re-install everything else; 10. If not, your motherboard and/or processor has to be replaced. Hope this works out for you. Good luck and pls post again how things turn up. Kind regards.
Posted on Aug 05, 2007
  • 63 Answers
From the symptom, it could be the main mother board faulty. the cost of mother board is about the same as the video card.hope it would help.
SOURCE:
Powersupply went out replaced power supply on my DX4300 powers on but no picture on moniter
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have secure dust free connections and are not faulty or just replace them they might be faulty
if its a 40 pin flat ribbon type it will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electical extensions
even something as small as an electrical fan and its lead can cause you problems
computers need all electrical power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
restart your computer then reinstall it this should activate found new hardware wizard
hope this helps
Jun 16, 2012 | Gateway DX4300-03 Desktop PC
Hi hi to all. We have a D-Link Wireless ADSL+Router and cant seam to connect on another computer in the house with a wireless USB stick. And the WLAN light is not on but comes on after turning off and on...
hi when you say you want to connect another computer do you mean a laptop or descktop if you are trying to connect a laptop you will need to click on internet options and search for your wireless network if you have it set up ,secondly if your trying to connect to a descktop this will have to have a wifi card installed if not it will not recognise it ,you can purcase these on ebay fairly reasonable i hope this helps you goodluck
Mar 27, 2011 | Computers & Internet
My computer wont start up
My name is Mike. A couple times a day I go looking around to give some pointers to our clients (you).
Look at it your question from our point of view, five words doesn't describe much. We need a little more info.
More is better:
If you are serious about getting an answer, include Make, Model of the product that's misbehaving and what type of product it is.
Describe your problem clearly, concisely and with as much detail as possible. Include recent events, is it new, used, has it ever worked, do people mess with it, etc. Anything that will help describe the problem.
For future reference:
Often, a problem can be the result of a seemingly unrelated event. It is always a good idea to include a recent history.
Additional information such as what steps have already been taken, has the product ever worked, is it new, etc. can have a bearing on providing the best solution for your particular circumstances.
Remember, you are a key participant in this process. We are not there, you are. We depend on you to be our eyes and ears. We can only respond to what you provide us. Without you, all our talent is worthless. How's that for an ego build?
What you get out of the experience depends on what you put in to it. So help us help you.
It would be also be advantageous in your case to repost your problem so that it is correctly categorized and starts over at the top of the queue. This way it can be directed to someone with expertise in the area you need.
Best regards
Mike
Nov 18, 2010 | HP Compaq dc7100 PC Desktop
I cannot shutdown my Windows 7 computer. It never shuts off so when I have to restart for an update, it never shuts down completely and just comes back up to the desktop.
Check if a particular program is slowing the machine when you switch on or shut down, e.g. an anti virus program.
Go to Control Panel > All Control Panel Items > Performance Information and Tools > Advanced Tools (in the left pane). On this screen the problem is sometimes shown. If not, click View Performance Details in Event Log (Event Viewer). Events in the 100 series are boot events and I believe those in the 200 series are shut down events. These can be followed up by double-clicking them, then clicking Event Log Online at the bottom.
Hope this initial information helps. Let me know for further instructions.
Thanks.
-TA
Oct 10, 2010 | Computers & Internet
I need a manual to tell why the car just died. there is a red light on on the "idiot" panel (dash). it died while my wife was driving but didnt sputter or stall , just went dead.
It is unlikely (but possible) that the type of troubleshooting you need can be derived from a manual. At least not with the information provided.
If you are serious about getting an answer, include Make, Model of the vehicle.
Additional information such as what steps have already been taken, recent events, is it new, etc. can have a bearing on providing the best solution for your particular circumstances.
It would be also be advantageous in your case to repost your problem so that it starts over at the top of the queue.
Best regards
Mike
Aug 14, 2010 | Dodge Neon Cars & Trucks
It's dead after I connected it to the computer for sometime and the computer is shut down. I cannot turn it off. the screen shows connected,nothing else is shown.
Look at your problem from our point of view. With potentially thousands of problems for each product, and thousands of products, we need a little more from you.
If you are serious about getting an answer, include Make, Model of the product that is dead, what you are trying to do and any other events related to the event.
Best regards
Mike
Aug 12, 2010 | Computers & Internet
No have image the descktop i plug a video card but no have image and i dont if is the motherboard and the procesador
Bro try to double check your video connector if it is attach and locked properly to its port of the video card but bro you can use and plug your video connector directly on it's motherboard built-in video port.
May 16, 2010 | Acer Aspire AM1640-U1401A Desktop PC
Hi, I need some tip (Video Hardware stop working)
Hi, when using any type of video (Hardware) or (Software); the problems are usally caused by: Low Memory; conflicts with incompatible software. When not watching TV, or Movies; check to see if (Programs) are active / running. Thanks paul7of9
Jan 01, 2010 | Gateway P-7807u Notebook
I had a loud fan noise coming from inside my desktop box for a while. One day (& ever since,) when I went to turn the box on, absolutely nothing happened: no fans, no BIOS, no LEDs. I made no config...
This may work however i think by ignoring the sound of the Fan you might have destroyed the cpu and the motherboard.If you can try the processor in another machine you might just have to replace the motherboard only.
Good Luck
Dec 03, 2009 | Intel Motherboard
How to install a ram stick
Looks like it is pretty simple to install ram on the iMac g4. Here are screen shots from the imac manual that describes the process. (see below)
Mar 30, 2009 | Apple iMac G4 Desktop
Heating & Cooling Logo
1,024 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
ray gallant
Todd B
Tom Chichester
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
