Question about Datalogic Gryphon M100 901671000
Hi, i really got Problefunction "leading zero off" or " do not convert UPC-A to EAN13" for the Gryphon M100.
He alway fills up the 12 digits UPC with a leading zero to 13 digits. I read the manual for 10 Times without any success so help would be nice
3 Suggested Answers
SOURCE: Gryphon M100
Hmmm are these falling apart after 2 years? A customer of ours seems to be having that problem for about 1 or 2 months. Close to our date. I saw you are from America. We're located in Europe. I havn't seen it yet, but got told the red light / beam isn't rectangluar. Seems it more V shaped. Like at 1 end a piece is missing. A new pc installation didn't help. We still want more information before we drive there. So we know what to take with us. The clean the glass every now and then, so it should be clean. Wondering if it is the scanner if there is a led broken or some lose wiring or something. Then they probably need to buy a new one. IF someone knows any other tests to try or know the solution please let me know at niels@technico.nl
Posted on Aug 07, 2007
rdiodoro
  • 13 Answers
SOURCE: Reset on Datalogic Gryphon M100
Hello
you've solved? Do you want to reset the online? Roberto
Posted on Dec 17, 2008
UPC code85948500222
Hi. I'm not sure if this will help you, but I found this website:
UPC Database Item Lookup
According to this website:
"Enter the all digits printed on the UPC bar code, including any numbers to the right or left of the bar code itself, even if they don't line up with the main row of numbers. This should be 13 digits for an EAN/UCC-13, 12 digits for a Type A UPC code, or 8 digits for a Type-E (zero-supressed) UPC code. Anything other than 8 or 12 digits is not a UPC code! (And just because it's 8 or 12 digits doesn't mean it is a UPC.) You must enter every digit here.
If you have a barcode scanner that outputs plain numbers, you should be able to use it to enter the UPC number here."
So, apparently you need more digits to complete the bar code #. But if you have the full barcode, you should be able to enter it on the website linked above, and find the image of the frames that you are looking for. I hope this helped. Thanks!
Oct 23, 2014 | Datalogic QuickScan QS6000 Plus Bar Code...
Enable Leading Zero in Gryphon M130
Can you show us the printed numbers before going further?
Oct 05, 2014 | Datalogic GRYPHON M130 C Wired Handheld...
Honeywell
Scan "do not expand ean-8 to ean-13" in your programming guide.
Jan 18, 2013 | Honeywell Voyager 1200g Barcode Scanner...
My scanner reads only12 numbers not 13 numbers from barcode what h do?
Perhaps you should ask for replacements and ask for a bar code scanner who reads 13 numbers because even how many times you try it over and over again if the function of the scanner is limited in reading 12 number the results will be the same..Hope it can Help you.
Jul 02, 2011 | Metrologic Instruments 9520 Voyager
We need to convert UPC-A barcode number to EAN-13
Most scanners will convert UPCA to EAN13 as you scan if you have that setting checked. A 0 will be added in front of the UPCA to make it an EAN13. Nothing else changes. You can read about this stuff on Wikipedia.
Mar 24, 2009 | Symbol LS2208 Handheld
Hello
Nov 27, 2008 | Datalogic Gryphon M100 Handheld
Extra zero
The default setting for this scanner is EAN13 enabled. This means that all 12 character barcodes will be changed to 13 characters by adding a zero in front.
How to Disable:
Open the manual that came with the scanner (it's available to download on the Cipherlab web page if you don't have it).
Find the UPCA Parameters barcodes (currently page 29). The next heading down is Convert to EAN13. You will see the disable and enable barcodes.
1) Scan Enter Setup Barcode (on practically every page of the manual at the bottom). The scanner will beep 6 times.
2) Scan the Convert to EAN13 Disable barcode. The scanner will beep once.
3) Scan the Update barcode at the bottom of the same page.
Your scanner should now read both 12 and 13 character barcodes correctly.
Hope this helps:)
Nov 26, 2008 | CIPHERLAB 1000 Handheld Barcode Scanner
Ean 13 problem
you are probably reading to a inteligent software package like Excell, which sees the inputted data as a number (so ignores leading zeros) you need to specify to the sytem that the incoming numbers are TEXT not numbers.
Sep 30, 2008 | Symbol LS2208 Handheld
Wont scan The tracking number for FedEx Packages
hi You must identify the codec fedex. Then see if Manual can 'read. Roberto
Mar 13, 2008 | Datalogic Gryphon M100 Handheld
Datalogic Gryphon M100 901671000 Logo
50 people viewed this question
Top Datalogic Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Paul Bade
jackcity
jackcity
Level 1 Expert
Are you a Datalogic Computer and Internet Expert? Answer questions, earn points and help others
