Question about Proscan PS36123 TV
Distorted picture on my 32" Proscan TV...(about 15 years old)
When I bring up the TV program listings, the vertical lines bend inwards from both sides towards the center of the screen, which explains why the TV picture of people are distorted. The horizontal lines look OK
  • 89 Answers
The RCA GE sets have a problem with bad solder connections in the tuner unit which also causes numerous symptoms including poor regulation, no vertical deflection, low audio or dead set.
Pulling in from the sides is either poor regulation or a bad eeprom/solder join issue
Posted on Mar 13, 2009
Why are there Vertical black and color lines along the right side of the screen?
If you've replaced its LOT recently, the replaced one do not match with the original number. The fault is called 'Yoke Rigging".
Gopakumar Gopalan Google
Aug 11, 2014 | Proscan PS32500 32" TV
Vertical lines on one side of the tv. It's only two years old
You need to consult the Service person. It may be faulty in the LCD.
Jun 03, 2012 | Vizio L32 32 in. LCD HDTV
Tv is about 4 years old. Suddenly developed two
Your plasma screen is made up of 1080 verticle lines and now a few of these lines are not working. This is the screen itself and needs replacing.
May 22, 2010 | Samsung HP-T4254 42 in. Plasma Television
TV picture distorted, bending in from the sides
main board is cold solder. resolder main board.
May 31, 2009 | Televison & Video
Proscan PS27123 TV Problem
just to be sure, is it vertical or horizontal? Anyway, if it is vertical, it could point out to the vertical Ic section or some loose contacts along the lines. If it is horizontal, it could be a filter capacitor along the horizontal Circuitry. Mark the high voltage capacitors along the high voltage sections.
regards,
chris
Jul 23, 2008 | Proscan PS27123 TV
Vertical line picture
problem is caused by the loss of horizontal deflection signal. It is quite surprising that the entire unit is still working, since usually, a loss of H-Out will disable the entire set. Problem can be as simple as loose solder connection to a more complicated defective horizontal circuit. I would suggest havint it checked by a professional TV tech.
Jul 16, 2008 | Proscan PS36500 36" TV
PANASONIC 32" CT-27SL14 model
This is a problem with the pincushion and convergence circuits. Are you planning on repairing this yourself? If so, I'll look up the circuit designations and parts. If not, expect a parts cost in the $15 range plus the local labor rate.
Dan
Jul 03, 2008 | Panasonic CT-27D31 27" TV
Its a phillips 28pw5324/05
the problem in your TV receiver. Some components in Horizontal and vertical deflection circuits must be faulty. Adjusting H & V frequency may also smooths the picture. Contact Authorisedservice personnel.. All the best !
Dec 07, 2007 | Philips 32PT6441/37 32" TV
TV Problem
No. Are the lines white or black? Does the picture look distorted at the top? Is there a chance it is still under warranty? It sounds like a problem in the vertical retrace circuit. Probably a capacitor near an IC that's used for timing. You shouldn't be having this issue already. A tech should be able to see a distorted waveform in the vertical section. Hope this helps.
Nov 11, 2006 | Philips 32PT5441/37 32" TV
Televison & Video Logo
322 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
