Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Lawn mower tractor doesnt start
When I turn the key, theres a clicking sound, but the engine doesnt turn over. I charged the battery, but it did the same thing.
  • 2 more comments
  • taddesso Mar 13, 2009
    I'm the guy who couldnt start his lawn tractor. Thank you for responding to my question. I tried cleaning the battery leads and also the lead to the starter, but it didnt work. Do you have any other suggestions. Thanks.
  • taddesso Mar 15, 2009
    No, I put a battery pack on it and it did the same thing.
  • joe May 11, 2010
    can you jump start with another battery or portable battery box?
  • Anonymous Mar 22, 2014
    NO START HAVE INSTALLED NEW BATTERY
  • 42 Answers
Sounds like you have a bad connection on your battery or on your starter. check out the battery first. take wires off of it and clean them good. then make sure and put them back on securely. Try this and let me know if it works. Thanks.
Posted on Mar 13, 2009
When I try to start my 60" Ariens rider all I get is a loud clattering sound. I just replaced the battery 2 months ago. What's wrong with my mower?
Joel, Recheck battery to make sure it has good charge >12 v and all battery and starter wiring,plugs,connections are clean,tight and undamaged. If you remove spark plug and engine spins freely from the key, the engine compression release or valve clearance needs adjusted. It is probable the solenoid or starter is faulty, the starter Bendix/drive may be sticking. If you can, give the starter a couple sharp raps with a hammer or bar and then try to start.
Check the attached links,instruction and guides to help diagnose starting issue. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://troybilt.custhelp.com/app/answers/detail/a_id/86/~/clicking-sound-while-attempting-to-key-start---riding-mower
What Are the Symptoms of Bad Starter Motor on Riding Mower Engine
My Bolens lawn tractor won start It just clicks when turn the key even...
Craftsman riding mower won start Just clicks the starter motor
Aug 27, 2016 | Ariens MaxZoom60 60" 25HP Kohler Zero Turn...
Solenoid clicks but starter does not kick in to start tractor
Clicking Sound While Attempting to Key Start - Riding Mower
troybilt.custhelp.com/.../clicking-sound-while-attempting-to-key-start---r...
Jul 19, 2002 - Why does the tractor make a clicking sound and not start? ... Thesolenoid connects the battery to the starter motor when the solenoid is energized. ...It can click, but not make a complete connection. ... Starting - Riding Mower · Professional Shop Manuals · Basic Troubleshooting - Lawn & Garden Tractors.
How Do I Tell If the Starter Solenoid Is Bad on My Kohler ...
homeguides.sfgate.com > Real Estate Advice > Basic Real Estate Advice
Most large Kohler engines on riding lawn mowers use an electric starting system. ... A bad solenoid can deny electricity to the starter motor and prevent engine startup. ...Lawn Mower Will Fire but Not Start · Replacing a Solenoid on a Craftsman Lawn Mower or Tractor · How Does a Starter Solenoid on a Lawn Mower Work?
My Bolens lawn tractor won't start. It just clicks when I turn ...
Dec 03, 2015 | Garden
Riding mower won't start & makes clicking sound when I turn key over
MAKE SURE BATTERY IS CHARGED IF IS THEN JUMP LAWN MOWER AT STARTER IF STARTS BAD BATTERY ARE STARTER RELAY COST 60.00 I STILL THINK YOUR BATTERY IS BAD OR DEAD NOT ENOUGH CHARGE IN IT
Sep 01, 2014 | Garden
Won't start
battery flat.disconnect and put on charge
Jul 07, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
42 in. Deck 19.5hp Lawn Tractor: Craftsman Lawn tractor my engine clicks but will n...
battery has a low charge or the starting gear on the starter is bad. just remove cover and see if the starter ingages and cranks the fly wheel. look at the gear itself to make sure the teeth are good ,if not replace the plastic gear. takes 5 min.
May 18, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Rally ride on lawn mower not starting. briggs and stratton 12 hp engine. battery fully charged but engine not turning when ignition key turned
i have a rally lawn tractor when i hook up the battery it wants to start key is off only thing i did was change the belt. was working fine before .
May 03, 2010 | Garden
I have a sears lawn tractor with a Kholer courage 20 HP. Engine just clicks with the key is turned. Took the battery to have tested and was told the battery is good. But, the tractor will start if I jump...
No, it sounds to me like it is one of the safety switches is a bit corroded, along with a battery that may not be fully charged, you are not getting enough voltage to turn the engine over. What I would first do it disconnect the battery, take apart all connections of the cables, where it mounts to solenoid, where ground cable connects to the tractor, etc. Then put everything back on. Charge the battery, or jump the tractor to get it started and let it run a bit, which will charge the battery. You may need to check wire connections that go to various safety switches, too. Under the seat, where it connects to the transmission, etc. This does not sound like a big problem at all.
Mar 08, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Won't start
it sounds like the battery doesnt have enough crankinc amps. thats a pretty big engine and should have probably have atleast 250 cranking amps. its possible the starter is going bad also
May 03, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
224 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
