Question about Home
What is more cost effective: hand dryers or paper towels?
    Problem Solver:
  • 56 Answers
We recently switched from paper towels to a hand dryer in my deli. Although the initial cost is definitely more for a hand dryer, I think that it will ultimately end up saving me money that I would be spending later on constantly having to buy more rolls of paper towels.
Posted on Apr 24, 2013
Staples Shredder SPL-TXC22A makes a "clunking" noise during use. Noise diminished after feeding a couple of WD-40 soaked paper towels but noise returned. Fixable?just use it until it dies and replace?
probably find that some cutters have been damaged and are hitting each other rather than sliding past each other
using wd 40 is lubricating those cutters but as the lubricant is used by the new paper it becomes inefficient
get a quote for repairs but generally ( unless the machine cost is in the 4 figure area) it is not cost effective to repair
Nov 28, 2016 | Staples Office Equipment & Supplies
Are hand dryers more eco-friendly than paper towels?
absolutely, see this study for more info
http://gogreen.theconsortium.co.uk/which-is-more-eco-friendly-electric-hand-dryers-or-hand-towels/
Jan 16, 2013 | Home
I have linoleum tile adhesive in my dryer, how can I remove it so I can dry my clothes someone put the towels that I was using by mistake in the dryer with the ...
You are going to need a hair dryer or heat gun; a throw away towel and some paper towels. Start out heating the adhesive until liquidy and then use the paper towel to absorb it. That should take care of most of it.
Then slightly dampen the throw away towel, put heat on the remaining adhesive until tacky then put the dampened towel over the adhesive and continue to heat the towel until the water steams.
That is way that works best for me.
Jun 19, 2011 | Dryers
The paper won't feed. I've repositioned the paper and it still doesn't work.
Check to see if the paper feed rollers are turning that push the paper into the printer. If so, then clean them with a soft cloth (not paper towels) moistened with alcohol. If they don't turn, you may have an internal problem and it would not be cost effective to get it repaired, considering how much new printers cost.
Feb 18, 2011 | Canon PIXMA MP150 All-In-One InkJet...
I have a LG Electric Dryer DLE5932W. When I run it on any of the settings in sensor dry the dryer turns off before the clothes are dry and you have to run it multiple times to get a load dry. Then if you...
this could be operator error please hear me out...... when wash bath towels you also put in wash cloths and hand towels .... there is a sensor in dryer drum shroud in front of lint filter to metal silver strips when the clothes are tumbling they sweep across this sensor telling the dryer heat to stay on and continue to dry.... if th small wash cloth sweeps it first before the bath towel then u get the same results as your describing just like if you were waqshing colors load like cotton tshirt and blue jeans the tshirt is going to dry way faster than blue jeans so if the tshirt sweeps that sensor first the dryer going to shut off we have to sort our clothes to thickness ans same size articles just try it once i bet your clothes are dry when cycle completes
Jan 31, 2011 | LG DLE5932W Electric Dryer
My dryer is leaving black marks on clothes, how can I fix it?
if you left a marker or ink pin in the dryer. then take a flashlight and look inside.if it is a mark then take a rag with a little fastorange handcleaner,and wipe on with small amounts. then take a clean paper towel and dampen with water and wipe all of the hand cleaner.thanks karl
Dec 02, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Heads will not clean, done everything Epson Stylus Pro4800 Manual says it has cost me a fortune in ink and waste tank. Is there an easy way to clean heads?
Usually the simple way to clean old ink from heads is to get a container of alcohol from the drug store and either using a Q-tip or paper towel soaked - wipe the print surface of the head to remove the old ink, then run the head clean utility once after. If you cannot reach the head surface, move the print head to change ink position, unplug the printer and fold and lay the paper towel soaked in alcohol under the head and manually move the head back and forth by hand to clean it. You may need several sheets of towel and alcohol to do this. Fold the paper thick enough so it will touch the head surface to clean.
Oct 26, 2009 | Epson Stylus Pro 4800 InkJet Printer
My dryer seems to be hot, however it takes forever to dry a load. Is 3 -4 hours normal to dry towels?
Your heater coil has burned into 2 parts. Find a friend WHO IS KNOWLEGABLE about dryers, Call a repair man or find a good used dryer. I understand this isn't what you wanted to hear, but this involves lint and 220 voltage. NOT to be taken lightly. The coil will cost around $50 and the repair men will be a minium of $75; Look in the paper and buy another one....
Aug 25, 2009 | Dryers
Trying to clean dryer vent
hello try this turn on your hair dryer but hold it about 8inches away from the problem aera and put the dryer setings on high and hot. be careful. hope it works.
Apr 25, 2009 | Kenmore 98702 Stacked Washer/Dryer
Home Logo
982 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
