Thanks for your post, Daniel!
Based off the information you have provided the cycles inside of your Frigidaire washer will stop at 12 minutes and making a grinding noise. I also see that you receive an E11 error code and that stands for a long fill time. I would recommend checking over the hoses to assure they are installed properly and not restricted. You may have an issue with your drain pump, motor, or water valve. I would recommend performing a reset on your washer and you can do that by disconnecting power from it for at least ten minutes. I hope this information is helpful to you. -Matt
