Question about Xerox Office Equipment & Supplies
Printing canon ir3300
Dark print occures on ovrlay
  • 89 Answers
SOURCE: my ir3300 xerox machine not print out.please solve thins problem.
How are you trying to print? You need N boot rom. Press Counter Check. Do you see IR3300(IR2200N) or IR3300(IR2200). If you see the N then you should be able to print with it. If not, you can't.
In Service Mode (to get into this press Additional Functions (button with * on it) > 2 then 8 > Additional Functions) go to Copier > Display > Version. What do you see for BOOT-ROM (does it have a N at the end?). For PS/PCL what do you see?
If your BOOT-ROM is N and you don't have a number for PS/PCL then call a technician to install networked system software.
If BOOT-ROM is not N, buy a Network Multi-PDL Kit C1 and get a technician to install it and load N system software.
If BOOT-ROM is N and you have number for PS/PCL check your IP settings. Make sure that DHCP is turned off. Set up your printer using an IP port with the static IP address assigned to the copier.
Use PCL5e or PS drivers, don't use PCL6.
Posted on Jul 15, 2009
  • 89 Answers
SOURCE: Printer keeps pausing itself!!
By UI do you mean RUI (Remote User Interface)? Have you installed a network kit? If so did you upgrade firmware using SST? If not, you need to do this or printing won't work.
In service mode. Copier > Display > Version > PS/PCL there needs to be a number e.g. 30.06. If there is no number the copier does not have any print drivers on it and won't be able to print. You also need to have a N BOOT-ROM (included in network kit). There Should be a N next to the number for BOOT-ROM under Copier > Display > Version if a N BOOT-ROM is installed.
Posted on Jul 17, 2009
  • 89 Answers
SOURCE: Canon IR3300 model has some problem.
Don't recommend PCL6 for this copier. Try latest PCL5e and PS.
If that doesn't work get tech to come out and load latest firmware and see if it works.
Posted on Jul 31, 2009
  • 89 Answers
SOURCE: sir,error E00007-0000 displayed on screen of canon
E007-000: An error in the rotation of the fixing film is detected.
The reading of the main thermistor is 100°C or higher and, in addition, the
fixing film sensor does not detect the rotation of the film for 6 sec or more
while the fixing motor is driven.
Get a tech to service your copier.
Posted on Nov 16, 2009
  • 4 Answers
SOURCE: canon ir3300 pdf printing slowly, so what can i
this model pdf output is slow. no way to come fast.
Posted on Nov 24, 2009
How can I better the print quality of Cannon IR3300
How many copies drum made?Maybe you have to change it.Clean the optic mirrors platten glass,transfer roller...
Jul 31, 2014 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
Ir3300 black page coming how to rectified this problem plzz help
True multi-functionality means you get more for your money in less space with the iR3300 black and white office photocopier. Handling the work of many in one compact solution, the iR3300 provides a cost-effective solution to your printing needs.
Features of the iR3300:
  • Provides copying, printing, scanning and faxing all in one unit.
  • Has a print speed of 33 pages per minute .
  • High capacity paper supply
  • Double-sided printing as standard.
  • Compact and reliable design.
  • Productive and space saving finishing options.
Jul 22, 2012 | Canon imageRUNNER 3300 All-In-One Laser...
Hullo, i have a canon ir3300 that am trying to print with but it has failed how do i do it
Did you try to print test page from driver properties on PC? Did it came out OK? If yes then you have problems with document that you are trying to print.
Also it can be that you have wrong paper size set in cassete or in printer drivers.
Please be specific, how does print fails?
Jul 12, 2010 | Canon ImageRUNNER 3570 Copier/Printer
In my ir3300 xerox in very light
That means that you have to clean copy glass , lenses, ccd,...maybe even laser unit if you know how.
On digital machines dirty optics means light copy, on analog oposite, dirty optics dark copies.
Just one more question how do you mean " charge toner"?
Jun 07, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Sir, Print coming out like a sign wave..
sir i have a canon ir3300 machine its print clarity and neetness
but the problem is coming print out is in a waves how can i solve this
Dec 18, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Each time l switch on my machine canon ir3300 l have e000007-0000
Try this press additional functions,2 and 8 keys at the same time,additional functions,copier, function,clear,err.power off and on. If that does not work you will need a tech to fix your fixing unit.
Oct 01, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Canon IR3300 dark print out
You refilled the toner. Don't recommend refilling the toner. If you're going to spend the money on a copier. You should get genuine toner.
I suggest you make a service call and use genuine toner in future.
Aug 17, 2009 | Canon NP 6050 Copier
Jul 30, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
32 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
