Question about DigiPoS Systems 714A LCD Monitor
Digipos touchscreen software
Saved reciept, won't delete
Installing oovoo
Try downloading with a different browser.
Jun 24, 2013 | ooVoo
My touchscreen won't work
Check www.manualowl.com for owner's manual and troubleshooting section of the free PDF.
Apr 11, 2012 | LG KP500 Cell Phone
Garmin 1450t stuck in loader loading error after downloading maps
Please follow the instructions below to remove the "Loader Loading" message from the unit.
To fix this problem on Windows:
  1. With the nuvi powered off, press and hold the upper left hand corner of the touchscreen with your finger
  2. Continue to hold the touchscreen while pressing and releasing the power button on the device. The Garmin Logo should display
  3. Continue to hold the touchscreen while connecting the device to your computer
  4. After 30 seconds, the screen should flash white. At this point, release the touchscreen. A green progress bar should display on the device. After the progress bar completes (45-60 seconds), the device should go into Mass Storage mode
  5. Open the nuvi drive that appears in My Computer or Computer
  6. Locate the Voice folder and delete the extra Voice files that are not needed
  7. Type ".System" (without quotations) after the nuvi's letter in the address bar
    • For example, if your nuvi appears as E:\ then after typing ".System" in the address bar, it should look like this: E:\.System
  8. Locate the GUPDATE.GCD file and delete it
  9. Safely remove your device from your computer
After the corrupted update file has been removed, the device should work properly. Run the WebUpdater program to update the device's operating software.
To fix this problem on a Mac:
  4. After 30 seconds the screen should flash white. At this point, release the touchscreen. A green progress bar should display on the device. After the progress bar completes (45-60 seconds), the device should go into Mass Storage mode
  5. Open the nuvi drive that appears on the Desktop
  7. Click the GO menu at the top of the computer screen
  8. Click Go to Folder
  9. Type .System
  10. Click Go
  11. Locate the GUPDATE.GCD file and move it to your trash
  12. Empty the trash
  13. Eject the nuvi from the Mac
Jan 06, 2012 | Garmin Nuvi 1450T GPS Receiver
Logitech v120 don't save settings
It's probably the OS's fault as the camera software saves the settings in a readonly file and, thus, the settings don't get saved at all.
Nov 19, 2011 | Logitech C120 Webcam
My computer won't turn on properly. It keeps saying disk error press control alt delete. When I do it just says it again and again. It won't load and turn on.
First you should check if there is any disk on your cd room, if there is any disk you should remove the disk from the cd room, if there is no disk the possibility is your hard drive getting error
Press f2 or delete to enter your bios set up system
Look for boot menu
Set the first boot as a HDD and the second boot as cd room and disable the third boot
Save and Exit the setting
if your computer still won't load you need to reinstall your windows
insert windows cd and go to set up again by pressing f2 or delete button
Set the first boot as cd room then the second boot as HDD
Save and exit the setting again
When the message press any key to boot from cd appears you should press the space bar or another key
Then just follow the instruction of formatting
Jun 03, 2011 | Acer Computers & Internet
I accidentally deleted text stored in Notes. Can it be retrieved?
you may try some data recovery program that helped me before, you may use asoftech data recovery that helped me before.
http://www.asoftech.com/adr/
Apr 17, 2011 | Computers & Internet
Deleted file...how can iget it again?
You can often successfully recover deleted files from a PC, phone or camera memory card or USB Memory stick, it just depends on what's happened since the files were deleted.
When you delete files the data itself isn't deleted, just the index entry that says where the data for those files is located. The space containing the deleted files is also now marked as free space so it is available to the system for any new files to be written there instead.
If and when that happens, then it becomes too late to recover your deleted files so it is very, very important to not save any new files or data to the device concerned.
If the deleted files are on a memory card or USB memory stick, just don't save any new files to it.
One of the easiest ways to see if you can recover deleted files is to try some file recovery software. Recommended asoftech data recovery as it saved my life many times.
Apr 11, 2011 | Computers & Internet
SOUND DRIVERS FOR THIS COMPUTER
Hey,
See if this link helps you
http://www.digipos-solutions.com/na/drivers.asp
May 13, 2009 | DigiPoS Systems DIGIPOS DGPH-VFD1-B PC...
DigiPoS Systems 714A  LCD Monitor Logo
99 people viewed this question
Top DigiPoS Systems Computers & Internet Experts
David Payne
David Payne
Are you a DigiPoS Systems Computer and Internet Expert? Answer questions, earn points and help others
