Question about GE AGQ08AH Air Conditioner
GE APH10AA - beeps once when plugged in but doesnt turn on
Hi, I have a GE portable air conditioner, I believe the model is APH10AA. It's been working, then one night when I go to turn it on, it doesnt turn on. I tried unplugging it and plug it back in. When I plugged it back in it beeps once, but is still not coming on. However the blades that moves to circulate the air is moving, but no fan comes on and no "ON" light turns on. What could be wrong? Is the complressor locked up ? Any help is appreciated !!! Thanks
  • Anonymous Apr 27, 2009
    I have a room air conditioner. Would there be different ways to test the problem or do I need to remove it from the window?
  • 72 Answers
It could be just the start capacitor for the compressor that has gone out. Easy way of checking is to take a screwdriver and short across the leads after you have unhooked it from the wiring connectors (don't touch metal while doing this, it CAN shock you) and take an analog meter, put it on ohms for resistance, and touch it across the two connectors. The meter should jump, then switch leads and touch them again. It should jump consistently like this. If it's not that, then it's probably either faulty wiring, switch or if all else fails it could be the compressor went to ground. Take off the leads going to it, again set the meter to full resistance, and put one lead on copper tubing going into the compressor, and touch each pin of the connector on unit. If any of them read anything, then it is the compressor. Hope this helps.
Posted on Jan 27, 2008
Hi, I have a GE Portable 120 Volt Room Air Conditioner Model: APH10AA. It is producing a humongous quantity of water every times it runs. For 8 hours of use at night, it produces close to 3 gallons of...
with real high humididty this will be a problem I might suggest that you find some kind of pair and place it inside the pail but stacked onotp a a block to keep the unit dry until things dry out a bit .. Its the weather not the unit thats the problem let me know
Jul 23, 2011 | GE APH10AA Air Conditioner
I need the flexable hose and adapator that expells the exhaust heat where in ft.worth,tx can I find these parts. Thanks
You could try GE Parts Service. You will need the correct Model Number of your portable AC Unit to do this.
And you can also try Factory Appliance Parts. Again, you will need the correct Model Number .
Hope this helped to get you started. Please let me know. Thanks.
Jun 20, 2011 | GE APH10AA Air Conditioner
I have a GE APH10AAG1 portable ac that has no control panel function. It does turn on and blow cold when pluged in. It does have some LED's that light up (dry, low fan and the display). But none of the...
I have the same problem, Just use it with its remote control. if you dont have it you can order it through sears parts : part# DG11A2-04 (GE) or 81401789
Sep 23, 2010 | GE APH10AA Air Conditioner
I have a GE APN10AA portable A/C unit haven't used it in a few years and I think that you need to put water in it prior to running it but can't find the owners manual - any help
I have the APH10AA model and the manual is compatible with the APN10 model as well. It claims that with regular use the unit produces water on its own. It has a built in evaporator but may occasionally have to be drained. A manual for this unit can be found at GEAPPLIACES.COM. Just need to input your model number and search "use and care manuals" in the top right corner of their site.
Jun 29, 2010 | GE APN10AA Portable Air Conditioner
Lost the manual. how can i get a new one for ge model #APH10AAG1. was a gift,need to figure out how to install and drain, etc... thanks
Jun 04, 2010 | GE APH10AA Air Conditioner
My ge ac model APE07AHM1 is not blowing cold air. What could be the problem?
This is an old question, but I am having the same problem with APE07AHM1 that I bought second hand. I'd like to recharge it.
The answer by binev_78 seems to be for outdoor AC compressor units but this is a portable stand alone unit, no outdoor unit.
Aug 30, 2009 | GE APH10AA Air Conditioner
E4 code is showing on my GE room air conditioner APE07AHM1
There is a water holding tank on the right lower side (when u are looking at the front), empty it and the unit comes back on.
Jul 12, 2009 | GE APH10AA Air Conditioner
System does not blow cold air, what refrigirant should be used and how to refill it ge room air conditioner model ape07ahm1
if you have a look at the outdoor unit there will be a label with the gas charge and type of gas,usually to charge the system with fresh gas you need to **** the old one out,evac. the coils and charge
Jun 27, 2009 | GE APH10AA Air Conditioner
Heating & Cooling Logo
250 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
