Drain pump not kicking in to drain water
Need to know where i could get the drain pump,and is it so that it has to be replaced or what else can it be?
    President:
  • Washing Mach... Master
  • 662 Answers
You need not change your drain pump, you can examine it for blocks, can be examined. If faulty you can look for spares on this very site.
http://www.youtube.com/watch?NR=1&v=4IBvHbQ_3pA&feature=endscreen
Pl click if helped..................
Posted on Apr 24, 2013
jsrock516
  • 5911 Answers
SOURCE: Washer still wont drain, even after cleaning drain pump line
"F02" is a Long Drain error. If you have managed to verify that the drain lines are clear from the tub - to the pump - the the wall, then this usually indicates that the pump has failed. It can be common for this pump to make noise and still not work.
Just to be sure: Is water running freely form the tub to the drain line when you drain the water? If not, make sure you double check the line from the tub to the pump. Is can be common for small articles of clothing (i.e., wash cloth or underwear) to get caught in this area and restrict water flow. Don't ask me how these items get between the wash tub and basket, but I have seen it happen.
The pump is usually sold as a complete unit and can be found at searspartsdirect.com. Just type in your model number and the part will be listed under the "Pump & Motor" heading. It is listed as item #10 (part #8181684) and sells for about $71.00.
This is a fairly simple job that you can accomplish yourself if you feel inclined to do so. If you click on my profile and look under "Tips and Tricks", I have step-by-step instructions posted on how to replace a drain pump like yours. If you cannot find the information you are looking for, please post back and I will assist you further. I hope this answers all your questions.
Posted on Apr 03, 2008
IB4G2008
  • 3587 Answers
SOURCE: Fisher Paykel Wash Machine GWL11US
hot drain pump? suggests that the pump is not being lubricated properly...
Posted on May 28, 2008
SOURCE: Drain pump on LG Washer
Have the same problem , but when it gets to the drain cycle ( about 12 min left ) will chime and show an i con on display ( washer with a hose on bottom left with an X on it ) and it doesnt drain. I un plug and let sit for awhile , turn on and go to no spin and it will manually drain ( sometimes ) Do I need and New drain pump?
Posted on Jun 05, 2009
  • 1531 Answers
SOURCE: Water doesn't drain
you could have a bad drain pump.
have you checked the hoses that come from the bottom of the tub to the drain pump for anything that might be stuck in there,also check the hose that comes off the drain pump to the wall and look for an obstruction.
Posted on Jan 31, 2010
  • 10865 Answers
SOURCE: Need to buy drain pump for LG washer WM1812CW but
Hello. you can order the LG parts from any home depot.
Posted on Mar 08, 2010
The machine start to work ,but then i can see 5d and i don't know what it means
Hi
Error code SD/5d means LONG DRAIN. This error appears when the drain time exceeds 8 minutes and the water valves turn off. After 4 minutes the "Sd" error will be displayed, and then 4 minutes later the F21 error code will be displayed. Press PAUSE/CANCEL two times to clear the display. Please Check the drain hose and make sure it is not plugged or kinked. If the drain hose if fine then unplug the washer and check the electrical connections at the pump and make sure the pump is running. Check the drain pump filter for foreign objects. To access the drain pump and filter remove the front kick panel and trace the drain hose to the bottom of the washer, drain pump would be located there. If you are not able to access it, then replace the back panel as well. Plug in washer or reconnect power. If the issue is still not resolved then you would need to replace the drain pump. Hope this helps...please post back for further assistance.
Daniel
Aug 10, 2011 | Kenmore Washing Machines
Whirlpool front load washing machine (Duet Sport) is Flashing a F-21 and F22 code and will not spin and drain.?????
The drain is clogged. remove the bottom kick panel. should be 3 or 4 1/4" nuts. open drain pump slowly. you may want to have a container to catch the water and some towels. check drain pump for foreign objects. also check the drain hose. make sure its not kinked or clogged. also check electrical connection to the pump.
if all the above have been checked and the unit still doesn't drain, then you may need to replace the drain pump
Mar 21, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite HE3 - Washer stopped - door locked - did not drain and spin - Getting error message F02
  1. Unplug the washer.
  2. Remove the 3 Torx head screws (located left, center, and right) from the front bottom kick panel of the washer.
  3. The drain/filter/pump is right in front.
  4. You can see a diagram of the pump at http://www.repairclinic.com/PartDetail/Drain-Pump/1200164.
  5. First remove as much water from the washer as you can. Place a large towel under the pump - a lot of water will come out when you remove the filter cover cap.
  6. Remove the drain filter cover cap by turning the filter cover cap counterclockwise.
  7. Remove the filter and check the housing and pump impeller vanes for debris (see if you can move the pumps impeller by hand).
  8. Clean the cover cap gasket and the gaskets mating surface.
  9. Replace the filter and close the cover cap firmly.
  10. Run a short wash cycle and check for any leaks at the filter cover cap. If the error comes back, you may need to replace your drain pump.
  11. Replace the kick panel if none are found.
Feb 27, 2011 | Kenmore Washing Machines
Washer will not drain water frigidaire
Hi
If the washer is not draining then it is due to a clogged drain pump or a drain filter or a kinked drain hose. To resolve the issue you'll need to clean the drain hose, inspect if the drain hose is plugged. If the hose is fine, then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn't work then you'll need to check the connections of the drain pump, check the electrical connections with a multimeter. If it still doesn't work then you would need to replace the drain pump. Please revert for any further assistance.
Hope this helps...
Daniel
Feb 17, 2011 | Washing Machines
My bosch dishwasher will not drain and makes a humming noise
Humming noise is an indication of your drain motor getting power but not spinning. Either your drain pump is defective and needs to be replaced, or something is stuck in the pump preventing it from draining out the water. Either way you will have to take the dishwasher out and get at the pump from the bottom of the machine.
Jan 31, 2011 | Bosch SHX4AP05UC Dishwasher
NOT POMPIN WATER OUT.I CAN HEAR POMP GOING BUT NOTHING HAPPENS
Hi
Dishwasher not draining issue occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. To access the drain pump, please follow the procedure---
1. Drain pumps are mounted to sumps in the front of dishwashers --they're easily accessible from the front of dishwashers by removing toe kicks.
2. Tools needed: small flat blade screwdriver (for unlocking terminals).
3. Remove toe kick/base cover, pull up terminal cover and disconnect wires (using screwdriver to unlock locking terminals).
4. To remove pump, pull latch (on circular collar) & rotate pump clockwise (cw).
5. To install new pump, insert @ 2:00 position & rotate counterclockwise (ccw).
6. Clean water & debris from base, then check float operation.
7. Connect wires, then install base cover & toe kick.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Jan 29, 2011 | GE Nautilus 24" Built-in Dishwasher
Water in bottom of bosch dishwasher will not drain. How do I get this water to drain
Hi
Daniel
Jan 26, 2011 | Bosch SHU9915UC Dishwasher
My model wdc1025 will not drain wash water or rinse water
Hi
If the washer is not draining then it is due to a clogged drain pump or a drain filter or a kinked drain hose. To resolve the issue you’ll need to clean the drain hose, inspect if the drain hose is plugged. If the hose is fine, then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn’t work then you’ll need to check the connections of the drain pump, check the connections with a multimeter. If it still doesn’t work then you would need to replace the drain pump. Please revert for any further assistance. Hope this helps...
Daniel
Sep 02, 2010 | Splendide Washing Machines
How can i clean the pump
Remove the lower kick panel that is located directly below the door. If this is a Frigidaire model, the pump will be located in the front under the drum. Some pumps have a clean out trap with a screw on cover. Most Frigidaire models and GE models do not, however. You will need to remove the rubber hose from the inlet side of the drain pump in order to access the pump impeller. This is usually the larger of the two hoses attached to the pump. There will be some residual water inside the wash tub that you will need to drain, or be prepared to clean up when you remove the hose. An easy way to get rid of the residual water is to use a wet/dry shop vac and pull a vacuum on the drain hose at the wall. This will pull and remaining water from the tub and drain lines. Otherwise, you will need to lay down some towels.
NOTE: It is normal to have residual water in the tub and drain lines.
If you are experiencing drainage issue and cleaning does not correct the problem, you will need to replace the drain pump.
If you have any questions, please let me know. I hope this helps you.
Aug 24, 2009 | Frigidaire Affinity ATF6000F Front Load...
Washing Machines Logo
98 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
