Question about Dell Computers & Internet
Error 0122 when i diagnosis then give memory error 2000-0122. validation 81628
  • Dell Master
  • 27,725 Answers
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
Right click on the error message select properties you will see all details about the error
or click start type in event viewer press ENTER
you might be able work your way through the problem
Posted on Apr 25, 2013
2 3 4 orange blinking lights/ automatic start up and forced shutdown/ optiplex 960
Log in to: http://www.dell.com/support/home/us/en/04/product-support/product/optiplex-960/diagnose and send this info to Dell. As I recall lights 2,3,4 are either memory or HDD failure.
Run Diagnostic Run Diagnostic Diagnostics can be run on supported Dell devices with a full version of Windows.
Already have an error code from running ePSA diagnostics?
Dell devices come with preboot diagnostics to capture error codes. If you have already run a preboot system assessment (ePSA), enter the error and validation codes with your Service Tag below and complete the steps to resolve your issue. Enhanced Preboot System Assessment Error Code (without 2000-prefix) * Validation Code * Service Tag * Part Serial # (optional) ; ;
Mar 28, 2015 | Computers & Internet
Tip
Beep Code Explained
Thanks to Transcend Technical Support for this great Brief of understanding beep codes that is found here
This is a long post and it may be truncated at the bottom. If so, use the link above to go to the Transcend web site where these are found
1.General POST (initial system boot) BEEP Codes
If you do not know the BIOS manufacturer, the following will be the general Beep codes:
• 1 Long and 1 Short Beep ?Bad Motherboard
• 1 Short Beep and nothing else happens ?Disk Drive/Video Related Problems
• 1 Long and 2 Short Beeps ?Bad Video Card
• 1 Continuous Beep or Non-stop short Beeps ?Bad Power Supply
• 3 Short Beeps - Bad Memory
2.American Megatrends Inc. (AMI) BEEP Codes
• 1 Beep - Memory refresh timer error.
Reseat the memory, or replace with known good modules.
• 2 Beeps - Parity Error
• 3 Beeps - Main memory read / write test error.
• 4 Beeps - Motherboard timer not operational
• 5 Beeps - Processor Errors
• 6 Beeps - Keyboard controller BAT test error.
• 7 Beeps - General exception error.
• 8 Beeps - Display memory error.
If the system video adapter is an add-in card, replace or reseat the video adapter. If the video adapter is an integrated part of the system board, the board may be faulty.
• 9 Beeps - ROM checksum error
• 10 Beeps - CMOS shutdown register read/write error
• 11 Beeps - Cache Memory Bad
Beeps 4-7, 9-11
Fatal error indicating a serious problem with the system. Consult your system manufacturer.
Before declaring the motherboard beyond all hope, eliminate the possibility of interference by a malfunctioning add-in card. Remove all expansion cards except the video adapter.
?If the beep codes are generated even when all other expansion cards are absent, the motherboard has a serious problem. Consult your system manufacturer.
?If the beep codes are not generated when all other expansion cards are absent, one of the add-in cards is causing the malfunction. Insert the cards back into the system one at a time until the problem happens again. This will reveal the malfunctioning add-in card.
3.Award Bios BEEP Codes
1 Long Beep: Memory problem
Explanation: There is a failure of some sort related to the system memory.
Diagnosis: The first bank of memory probably has a failure of some sort; this is usually just a physical problem such as an incorrectly inserted module, but may also mean a bad memory chip in a module. It is possible that there is a failure related to the motherboard or a system device as well.
• 1 Long, then 2 Short Beeps: Video error
Explanation: The BIOS is unable to access the video system in order to write any error messages to the screen.
Diagnosis: This is usually caused by a problem with the video card, or the memory on the video card. It can also be a motherboard issue.
• 1 Long, then 3 Short Beeps: Video error
• Continuous Beeping: Memory or video problem
Explanation: The system is producing constant beeping in no specific pattern, or a fast "ringing" sound.
Diagnosis: This is usually caused by a problem with the system memory, or possibly the video card. The memory is more likely--the system complains long and loud if it can't find any usable memory, as there is no way to even start the boot process when this is the case. The motherboard itself could also be the problem.
• Other Beep Codes
Explanation: You have encountered an Award BIOS beep code I do not have documented.
Diagnosis: Award says that any beep patterns other than "one long followed by two short" are likely problems with the system memory. However, of late they have started adding other beep codes to their systems as well.
4.Phoenix BEEP Codes
• 1-1-3
Explanation: Your computer can't read the configuration information stored in the CMOS.
Diagnosis: Replace the motherboard.
• 1-1-4
Explanation: Your BIOS needs to be replaced.
Diagnosis: Got to your motherboard manufacturers web site and download the new Bios.
• 1-2-1
Explanation: You have a bad timer chip on the motherboard.
• 1-2-2 or 1-2-3 or 1-3-1 or 1-3-3 or 1-3-4 or 1-4-1
Explanation: Motherboards is bad.
• 1-4-2
Explanation: Some of your memory is bad.
Diagnosis: Go to Basic Trouble Shooting
• 1-3-1
• 2-_-_ Any combination of beeps after two
Explanation: Some of your memory might be bad.
• 3-1-_
Explanation: One of the chips on your motherboard is broken.
• 3-2-4
Explanation: Keyboard controller failure.
Diagnosis:
• 3-3-4
Explanation: Your computer can't find the video card.
Diagnosis: Is it there? If so, try swapping it with another one and see if it works.
• 3-4-_
Explanation: Your video card isn't working.
Diagnosis: Replace Video Card.
on Jan 20, 2009 | ASUS P5W DH Deluxe Motherboard
How can I fix a errror code 2000-0142 dell vostro with windows 7
It is unfortunate that the computer is giving 2000-0142 error, you may want to try running the hardware diagnostics again and provide me the Validation code along with the error code. Then I can check and see what can be done.
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
Jun 18, 2014 | Dell Inspiron E1505 Notebook
Error code 2000-0122
Error code 2000-0122 means that the RAM failed its tests, the steps to fix it are:
  1. Locate the RAM modules in your laptop, (refer to product documentation for help)
  2. Remove the RAM modules one by one, if you have say 2 stick of RAM installed, put one in and leave the second out and try again if it still fails, remove it and put the other one in and do the same.
  3. Failing that place both the RAM modules in together and try a third time
  4. If this is still failing, you require new RAM
May 31, 2013 | Dell Computers & Internet
My laptop gives 3 beeps and then doent want to start up .. what can i do?
2 Short Beeps Your computer has memory problems. First check video. If video is working, you'll see an error message. If not, you have a parity error in your first 64K of memory. First check your SIMM's. Reseat them and reboot. If this doesn't do it, the memory chips may be bad. You can try switching the first and second banks memory chips. First banks are the memory banks that your CPU finds its first 64K of base memory in. You'll need to consult your manual to see which bank is first. If all your memory tests good, you probably need to buy another motherboard. 3 Short Beeps Basically the same thing as 2 beeps. Follow that diagnosis above. 4 Short Beeps Basically the same thing as 2 beeps. Follow that diagnosis above. It could also be a bad timer
Mar 08, 2013 | Computers & Internet
My dell, latitude d630 gives error 0123 on diagnostic and beeps. how do i solve this?
Remove and reinstall the memory for the error codes: 1000-0122
1000-0123
2000-0123
Please see the Service manual for instructions on how to remove and replace the memory.
Aug 06, 2011 | Dell Studio XPS 1640 Notebook
ERROR E061-0122
e061 is a code for a drum charge error on the first drum in line from right to left i think yellow ? any way its either a worn drum broken charge wire if you have not changed drums in a while the other ones may be coding out next
Jan 28, 2009 | Canon CLC 2400 Color Copier
Trying to download Windows 2000 Registry Repair Utillity?
why are you using Windows XP boot disk instead of Windows 2000???
Nov 08, 2008 | Microsoft Windows 2000 Professional for PC
E061-0122
this is a very old machine and canon do not make certain parts any more------01= yellow check corona wire, grid, drum, develpoer replace if necessary
Oct 16, 2008 | Canon CLC 1000 Color Copier
Error code 0122 when trying to play blue ray disk on hdtv through hdmi cable
Hy guys
I had this problem earlier on today and after much searching found a solution that worked for me.
This error message relates to piracy issues. If you are running 2 screens at once (laptop monitor and HD TV) I guess it's seen as an easy way to pirate DVD's, Blu-rays etc.
Go into your graphics card settings (i think I did this in the end by adusting screen resolution (was hungover, there's probably a quicker way - this gave me access to my ATI graphics card settings). you should be given an option of taking your HD TV as the primary monitor and disabling the built in monitor.
This should resolve the conflict that caused the 0122 error message - there are no longer 2 monitors, I guess making it harder for the pirates to comoplete their dastardly deeds - aaaarrrr.
I hope this helps some peeps out - thought I'd return the favour for my own various questions.
StrangePlanet
Jul 12, 2008 | Computers & Internet
Computers & Internet Logo
77 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
