Question about Audiovox Leather PDA Case Toploading Belt Clip Leather
Samsung wa7584c1 parts
Does not drain the wash water
E2 Code - Samsung SW50ASP Washing machine
Water drainage issue. Water is not draining from appliance.
·Check drainage pump filter for blockages (e.g. lint, coins hair, clips)
·Check drain hose and waste connection for kinks and blockages.
Then select a spin cycle to drain
the remaining water in the appliance.
·If problem persists please call CustomerCareline. *
Helpline Contact Samsung UK
Dec 08, 2016 | Samsung Washing Machines
My samsung automatic washing machine wa7584c1 is giving me a 1E error why
You can sometimes solve issue by unplugging unit from wall for ten seconds to reset sensors.
CERACOAT-NANOTECH.com
May 14, 2015 | Samsung Washing Machines
WHY AREMY POWER BUTTON NOT COME ON WHEN PRESS
www.samsung.com/in/consumer/.../washing-machin...
www.samsung.com/in/info/contactus.html
Sep 08, 2014 | Washing Machines
Samsung WA82HAG water leaks while running the machine
WA82HAG water leak :
I have been using a WA82HAG top loading washing machine for 7+ years without any issues. Of late water had started to leak out of the drain pipe when the machine was in wash or rinse.
I contacted the customer care and was pleasantly surprised with their professionalism. The support personnel patiently listened to what I had to say. They even called back when the line got disconnected during the conversation! All details were asked for, expected cost estimate and technician visit time estimate was provided over the call.
The next day the technician arrived and diagnosed the problem to be a faulty drain valve. The rubber in the valve had become hard over time and was not plugging the drain correctly.
The following day he returned with the spare part, fixed it and demonstrated that the problem had been solved.
The total cost was Rs.300 for engineer visit + Rs.750 for the spare part.
Attached images of the replaced part. Black rubber can be seen in the second image.
I am completely satisfied with the how the issue had been handled. I will consider a Samsung washing machine if i plan to upgrade in the future.
Thanks Samsung!
82352738-7acb-4c99-8997-c18e55abcd8b.jpg b6d9e50b-dbf2-46d8-b193-f961a1ac2bd2.jpg
Sep 30, 2013 | Samsung Washing Machines
My washer WA7584c1 is realising water when its on a processes of wahing?
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Jan 19, 2013 | Washing Machines
My samsung automatic washing machine wa7584c1 is giving me a 1E error why ?
Hello, the error code is due to a water pressure switch error the service manual says
6. WATER PRESSURE SWITCH ERROR - Display shows 1 E.
* Generated Frequency Signal of WATER LEVEL (WIL) SIW (KHz)
Normal Level = Abnormal W/L Frequency
Low Level = 30.00 Khz
High Level = 15.00 Khz
If the same signal is detected for more than 5 seconds, it is a PRESSURE SWITCH Error. When this error occurs the drain pump will operate for 3 min. and the display will show 1 E indicating a pressure switch error. If you have any further questions message me back and please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future. Thanks
Rick
p.s also before replaceing the pressure switch assure that the tube that comes off the switch that connects to the tub on the tub end has no debris or soap build up inside the hose this could also make the switch show as an error if the hose had something in the end of it. Thanks again
Aug 23, 2011 | Washing Machines
I get an error 1E on my samsung wa7584c1 washing machine. According to user guide it is a problem with overflow. How do I fix it. The mashine doesnt want to let water in
Hi you put your washing machine problem under as a shoe problem. If you change the problem to a more suitable category then the problem can be answered by an expert in that category.
Mar 23, 2011 | Skechers YouthTween Twinkletoes Pixie Dust...
Samsung washing machine wa7584c1 power is on, programming seems fine, push start and nothing happens,except water flows ok, no washing no spinning no draining
hello check the belt first to see if it's come off or snaped if ok then the fault could be the brushes on the motor 2 plastic blocks sit either side of the motor they wear down can cause the motor to stop working they just slide out hope it helps
regards
shaun
Mar 13, 2011 | Washing Machines
I noticed that your problem is of a washer machine, but you categorized it as a shoe problem. A simple solution to this is to change the category so the right expert can see it and hopefully answer it. I tell you this solution to help you get the right answer to your question. Hopefully this was useful, have a nice day.
Mar 10, 2011 | Clothing Accessories
Audiovox Leather PDA Case Toploading Belt Clip Leather Logo
19 people viewed this question
Top Audiovox Cell Phones Experts
Spud Howell
John Porter
Are you an Audiovox Cell Phone Expert? Answer questions, earn points and help others
