Question about AEG B2100-4 Electric Single Oven
AEG Oven Trips RCD when above 220 Degrees
Our B2100 single oven will operate fine up to around 220 degrees. Initially it would trip after about 20 mins. Found cooling fan not running, so replaced thermal cut out. Fan functioning fine now on all temps. However when oven has been on at say 200 degrees and temp increased to 240, runs for 5 mins or so, and trips RCD in dist box. There is another contact ( i think thermal ) next to fan fixed by 2 self tapping screws. I am wondering if this is opening too early and tripping as it is on full load, or element on way out. Anyone seen similar ?
5 Suggested Answers
SOURCE: Oven cuts out after ten minutes and comes back after cooling down.
We have the same problem with our oven, AEG B2190-1.It started on on Christmas day[worst day of year]gets up to temperature after 10-15 minutes cuts out everything switches off until the oven has cooled down, The oven is only 18 months old. We have been told that it is a thermostat problem.
Posted on Jan 09, 2007
barkencoa
  • 3463 Answers
SOURCE: AEG Competence Double Fan Oven Fault
Sounds like oven element is faulty, disconnect it and try again, if it does not trip, then it is definately the element..
It is easy to replace.
Plz leave feedback.
Posted on Dec 09, 2008
markfreedman
  • 312 Answers
SOURCE: went to switch oven on
HI, Sounds like your from the UK
If you are referring to a trip switch as being equivalent to an American circuit breaker. (Electrical safety device designed to shut down power to an electrical appliance). Then we are on the same page.
Do the following diagnostic procedure:
1 SHUT DOWN THE POWER SUPPLY TO THE OVEN. I.E. THE TRIP SWITCH/CIRCUIT BREAKER.
2 Open the oven door and look very carefully with a flashlight at the heating element. Look at the the entire element. If it blew (similar to when a light bulb blows) you will
find white powder around the hole in it or it will be completely broken, or have bubbles in it. Some indication like that. If so it has failed and must be replaced. It is probably tripping the switch because it is shorting out somewhere. There is also the possibility that the internal wiring connectors to where the element is mounted into the oven walls is broken off and short circuiting against the oven chassis (walls). That being the case, it may be just a wiring repair in which you install new appropriate electrical contacts and re-connect the element.
Hope this helps,
Happy New Year,
Mark
Posted on Dec 31, 2010
Testimonial: "Hi thanks will check it now . Happy New Year "
BADBOYJAY
  • 264 Answers
SOURCE: AEG D2100-4-M bottom oven is cutting out and tripping electrics. It comes on for 20 seconds before this happens, what could the problem be?
heater element need replacing and you stat Tod for sort OK
Posted on Oct 17, 2012
My caloric over keep tripping my breaker. seem to happen only when it is warm
I suspect it is the oven element causing the problem, as it gets hotter, the insulation resistance is probably breaking down, and causing the trip to operate.
Oct 31, 2010 | AEG B2100-4 Electric Single Oven
Aeg 3050b oven not getting hot fan running and both lights on no heat even when turned to 275 degrees oven was working ok yesterday but seems to have gone all at once
Does the thermostat click and the light go off and on when you turn it up and down if so it is mechanically working.
Fan will run irrespective of element working
Either the element has failed or the connections to the element
Both require you to take the back off the machine to check them out
Jan 26, 2010 | AEG B2100-4 Electric Single Oven
Not heating up
Hi.
I suspect you may have a faulty oven element, which is breaking down as it gets hotter, disconnect element and try if ,if it does not trip, then element is faulty
Nov 20, 2008 | AEG U7101-4 Electric Double Oven
Plz leave feedback.
Sep 22, 2008 | AEG B2100-4 Electric Single Oven
Main oven problem
I suspect not the oven element at fault. you only way forward is to actually test the resistance of the element to earth with a megga if you can beg the use of one. be cautious about the result as on occasion, elements are only faulty to earth when hot. another way to test if you are cdarefull, is to connect the element to mains independently of the oven and see if the rcd trips
Sep 22, 2008 | AEG U3100-4 Electric Double Oven
thermal cut out fuse, costs about £30, my company fits them for £78 all in in essex
Nov 19, 2007 | AEG B3101-4 Electric Single Oven
Dec 10, 2006 | AEG B2100-4 Electric Single Oven
AEG B2100-4 Electric Single Oven Logo
63 people viewed this question
Top AEG Ovens Experts
ashburton
Sal DeAngelo
Samyfam
Samyfam
Are you an AEG Oven Expert? Answer questions, earn points and help others
