Question about Frigidaire 13 cu. ft. / 368 liter Chest Freezer FFC13C3A
Hot side panels
The side panel and the compressor both get extremely hot.
  • Official Brand Answer
  • 4,342 Answers
Hello Robert - From what you have described, it seems like you may be referring to the perimeter hot tube. It is normal to be warm to the touch; however, since it may feel hot to you, I would suggest verifying that you have the proper clearances around the refrigerator. You can refer to your owner's guide for those specifications. If you do not have an owner's guide, you can download one at the manufacturer site. If the clearance is fine, you may need to clean the condenser coils. As part of routine maintenance, you can remove the toe grille (located at the foot of your refrigerator) by unsnapping the sides and lifting outward towards you. Now, using an extended vacuum attachement and condenser cleaning brush, remove dust buildup from condenser coils on left side underneath refrigerator. Cleaning condenser coils typically resolves this issue. But, if clearance is fine and the condenser coils are free from dust and you are still feeling too much exterior heat, you may need to check with a local service tech to determine what else could be causing this issue.
Posted on Apr 25, 2013
Freezer stopped after power outage
If the sides are hot, look at the defrost timer. Sounds like it has stopped running with the defrost elements on. The compressor has a safety switch on it that opens either if the compressor gets too hot or if it pulls too much current when starting. If your power flickered a lot before coming back on, that triggered the safety switch. Now that it's running normally, I wouldn't worry. The defrost timer is your problem now.
Jul 10, 2016 | Frigidaire 14.1 cu. ft. Upright Freezer...
Compressor gets very hot
The compressor has a start device that could be the problem. If you remove it it should not rattle if it does it is very likely the problem. If it doesn't rattle then it could be your compressor. Check the start device first. it is located directly on the side of the compressor. and is easy to remove and install anoter.
Mar 04, 2014 | Bush Freezers
I have a hoshizaki km 255bah compressor start then quits
Is the compressor overheating when this happens? Feel the top of the compressor when this is happening and tell me if the top of the compressor becomes extremely hot to the point that you cannot keep your hand on the compressor. Reason I ask you to do this is that it is possible that the compressor is short cycling because of a defective start relay and/or run capacitor. Let me know if the compressor is overheating of simply turning itself off. I will post a service manual if interested but would like to e-mail you the service manual for your Hoshizaki KM-255BAH because of copyright issues. You may contact me HERE if you like. Thanks Sea Breeze
Nov 21, 2012 | Hoshizaki Freezer Commercial Ice Machines...
MI have a Frigidaire chest freezer, model number MFC05M1FW1 that freezes fine but is extremely hot to the touch on the front and side panels. Is this normal?
No it is not normal. But it is an easy fix! Clean the condenser grill and make sure that the compressor fan is working.
When the condenser grill is dirty it can't get rid of the heat from the compressor, so it transfers the heat to the cabinet. Also make sure that you have air space behind your unit and it is not crammed against the wall.
Note: If this is in your garage or in a closet, suggest you put it up on 4x4 blocks so that it can get plenty of air flow around it and you will even save some electricity since it won't have to work so hard.
Aug 08, 2011 | Woods Chest Freezer C1501W3
Kenmore frostless freezer, Model 253-9280413. Food is properly frozen but both outside walls and the top are extremely hot to the touch, particularly the wall to the left of the door which is so hot you...
If your condenser grill is extremely dirty or air flow is not adequeate there will be heat transferance to the cabinet itself.
Highly recommend that you clean your condenser grill (the grill underneath the cabinet) and vacuum as much as you can then blow it out with an air compressor.
Jul 17, 2011 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Older Amana upright freezer, I think that is 18 cu ft in size. It started making a clicking noise....I assume when the compressor is trying to start, it sounds like it is trying to start, but cannot
Hi, the clicking you are hearing is the compressor overload/external overload. When your compressor is a burn out or you have a locked rotor which means the compressor has died on you, it gets very hot from trying to start and this relay which is tied into the common side of the common terminal on the compressor, will click on and off as the unit tries to start. I have repaired these units for years and know exactly what is going on and the unit is older as you say. I would suggest pricing a new box as changing out the compressor, you are looking at around $1800.00 and up. I hate to tell you this but this is the problem. If you want to confirm this, just pull the unit out from the wall and try to leave it plugged in. Remove the lower panel to excess the compressor, condenser fan motor, and coil. Just be careful as this compressor should be very, very hot when you put your hand on it. Then you will know that is the problem. It should be warm and running. Please keep me posted and I hope I have been of help to you. Didn't want to give you the bad news though.
Good Luck, and Sincerely,
Shastalaker7
Mar 20, 2010 | Freezers
We've got a GE American Fridge Freezer. 12 years
time to get a new freezer. check the floor under the freezer for coolant leakage, if none the compressor is ready to deep 6...
Nov 07, 2009 | General Electric Chest Freezer FCM5SU
Panel is hot and freezer does not work!
Check the condenser fan underneath the unit accessable form the back behind the cardboard cover. It should be running when the compressor runs. OR Check the evaporator behind the rear cover inside the freezer. Check for ice build up. . Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control
Sep 09, 2009 | Freezers
Freezer is freezing but the outer wall are extremly hot
This is a normal condition.  The condensor coils are in the cabinet and their job is to remove heat which is why it is hot.  You will want to make sure the freezer isn't in a tight spot where air from the room can't flow across it.  Without good air flow it will become too hot and not cool properly and lead to the compressor failing too soon.
Oct 13, 2007 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Frigidaire 13 cu. ft. / 368 liter Chest Freezer FFC13C3A Logo
128 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
