E system 1201 manual
My esystem 1201 laptop won't turn on at all, the battery light is on, not sure why it won't! Help please or is the motherboard broke?
wellanny
  • 70 Answers
SOURCE: Hi,
you can click here to get your answer.
Posted on Feb 05, 2010
djbr1ck
  • 158 Answers
SOURCE: E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
Posted on May 12, 2011
  • 3278 Answers
SOURCE: Since last two three days
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Posted on May 22, 2011
TechyDrood
  • 2072 Answers
SOURCE: My laptop won't charge. I have
For a test -Remove the battery from the laptop. (leave it out) -Plug in the adapter and turn the laptop on. -Gently wiggle the adapter plugged in
If the computer powers off the solder and/or pins have broken loose from the DC jack. This is very common. Average repair bill is around $150, if your in the Denver Colorado Area I can do the repair for about $50
If it won't turn on while you wiggle the adapter and hit the power button then the adapter is bad again sadly
Posted on Jul 09, 2011
byteguy
  • 2229 Answers
SOURCE: I bought a new charger
The first thing to do is check that the charger is putting out the correct voltage, which should be ~18 volt. Then try to start it without the battery.
If your voltage is OK and the battery out makes no difference, then I would suspect that you have a motherboard problem that must be fixed. If the computer starts up if you wiggle the DC plug where it goes into the computer, then it's the DC jack that is looks and must be re-soldered.
Posted on Sep 11, 2011
Dell Inspiron 1100 won't turn on
unplug, take out battery then hold power button for 30 seconds then plug back in and turn on
if the3 laptap gos on without the battery you need a new battery
Jun 14, 2013 | Dell Inspiron 1100 Notebook
Advent Q200 Quantum
Unplug, remove battery, leave battery out, plug in, reboot and try a System Restore to a date before this issue.
May 28, 2013 | Computers & Internet
No power
Hello, If the battery won't charge and the laptop won't turn on but the ac adapter works with other laptops, then the problem is the port where you plugin the ac adapter. Some of the laptops has it built in to the motherboard. So you might need to have it repaired by a technician. Or if the laptop is still in warranty, you might need to send it to the manufacturer to have it repaired or replaced. But if the laptop works without the battery, or it will turn on but the battery indicator is not lighting up, you're facing one of these problems. 1. The battery itself is dead. 2. the battery bay is loose 3. the battery itself is loose Hope this helps
http://www.chargerbuy.com/laptop-ac-adapter/toshiba-ac-adapters.html
Nov 10, 2012 | Toshiba Computers & Internet
My truck won't turn on not even my lights and radio the whole truck:) please help:)
Check the battery. Make sure both connections are clean and tight. If they have acid/crud on them,..use baking soda and water to clean it off. If it still doesnt work,...time to get a battery.
Sep 23, 2012 | 1997 Mercury Mountaineer
When I plug in my HP 530 Green light comes on then turns to amber. Will not come on even when I remove battery and just plug in. 1322dijim@gmail.com
The System / Motherboard has faulty Power Circuit. Contact HP and arrange a repair. If under warranty won't cost anything.
Jul 05, 2012 | HP 530 Notebook
Netbook charging indicator light won't light and battery won't charge. AC adapter works on other computers
Hope this helps...
Sep 15, 2011 | Gateway LT2021u Netbook
I have a 1995 Honda cbr 600 f3 it won't start won't try an start the battery is fine so are the fuses I'm getting nothing no lights not even the ones that show your in neutral. It's really...
ORDER A CLYMER MANUAL FOR YOUR BIKE!!! Everything is easier to inspect with the fairings and accessory covers removed. While you are waiting for the manual, trickle charge your battery. Make sure your charger is a maintainer as well. It charges your battery and keeps it conditioned. Keep in mind, even if it's a new battery, they are not impervious to fault. When you get your manual, two or three days later, the battery should have a full charge as indicated by a green light(normally) on the trickle charger. Now, key your ignition on and get your multimeter. Read for battery voltage on the down side of your ignition switch.Then measure and note the draw from your battery as you hit the start switch. Open your manual and start reading through components like your rectifier, coils, main power fuse (probably a 30A)on your fuse box. Remember, a bad ground within your electrical system will report a failure to allow passable current to the components that need the juice. Look for corrosion or gunk on the contacts of your electrical components. Good luck, let me know how it works out.
Aug 20, 2011 | Honda CBR 600 F(3)S Motorcycles
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
May 12, 2011 | Computers & Internet
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
