Question about Apple iPod nano
My mp3 wont
Hey i just bought a brand new p3 and the battery is dead i put it on the usb port but its still not charging any solutions??
  • 3 Answers
Re: my mp3 wont
Iif you have bought an mps player the only thing i can suggest is changing the battery at the back of the mp3 xXx.zeddy.xXx
Posted on Aug 15, 2007
0 characters
3 Points
My fuse wont charge at all. i bought a new charger and still get no charge
Make sure that the USB cable is properly plugged in and use the original cable that came with your player.
Computer in Hibernation mode
Make sure the computer isn't entering hibernation or sleep mode while the device is connected. The computer must be ON in order to charge your player.
USB Port 2.0
Make sure the player is connected to a USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location
Try plugging into different USB ports (i.e. USB port in the back of the computer); occasionally the front USB ports have limited power to charge up the device.
Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery.
Latest firmware
Depending on what Sansa player you have, make sure it's up to date with the latest Firmware.
AC charger (optional)
AC chargers (sold separately) have a 500-1000 milliamp max output, which provides much better charging ability than a USB port. These accessories are available at SanDisk web site.
Dec 04, 2010 | SanDisk Sansa Fuse MP3 Player
My mp3 go gear wont charge, i've tried to charge it on the ubs port and i've tried to synx it again and nothing is charging it
try getting an old usb phone charger and using that if that wont work then your battery may be dead and its time for a new one
Sep 20, 2009 | Philips PSS110/17 MP3 Player
My sony walkman nwz-e436f was working fine and all the sudden its taking no charge from any usb ports
Check the connector of the USB Ports and Sony. Also it's internal battery require replacement.
Jul 06, 2009 | Sony NWZ-E436F MP3 Player
Not charging
Try connecting directly to USB port on your computer, NOT a hub. It needs power to charge.
Apr 29, 2009 | SanDisk Sansa c240 MP3 Player
Wont charge
put it in the hold position, hold the center button while you plug it into the cpu, keep holding untill it is recognized by your cpu. about 5 or 6 seconds
Oct 23, 2008 | SanDisk Sansa Clip MP3 Player
Brand new unit ...battery (or unit) died.
it sounds like the battery.but if new batterys dont work.then its the unit and you need to take it back.
May 13, 2008 | SanDisk Sansa MP3 Player
sound like you need a new mp3....might not be the charger
Feb 20, 2008 | MP3 & Digital Media Players
I have a brand new "my musix"mp3 player pd-6070,and i want to know how do i recharge the battery on it.thanks
you have to charge it by putting it in the USB port on your computer, but I am looking for an a/c charger if anyone knows where i could get one that will work with this! i got two off Ebay and neither will charge it! they charge my daughters Craig MP3 player but not my musix!
Feb 12, 2008 | MyMusix PD-6070 MP3 Player
It´s dead
hey buddy just do one thing.. open the metal cover removing the 4 philips screws.. and then remove the battery then reinsert the battery and try.. it should work ... i had the same thing few days back.. it was charged and in my pocket when i tried to listen to it the damm thing wont switch on .. so i removed the batter and put a LED to the terminal to check power and inserted it back it and valaaa it hot and running again..
Jan 25, 2008 | SanDisk Sansa e250 MP3 Player
New SanDisk Sansa m240 MP3 Player
Hey regan have u fixed it yet?? Mine is doing the same thing and it wont turn on at all well write back!! ~sam~
Dec 24, 2006 | SanDisk Sansa m240 MP3 Player
Apple iPod nano Logo
56 people viewed this question
Top Apple MP3 & Digital Media Players Experts
 Mike M
Mike M
Ron Dufek
Ron Dufek
Raisin Brann
Level 1 Expert
Are you an Apple MP3 and Digital Media Player Expert? Answer questions, earn points and help others
