1 tb external hard drive which is not been recognized
Hi. Its satya .. I have a problem in my External Hard disk which cannot recognized by my PC. When I plug it in the green light at front just flashed and it come sound and the motor inside doesn't even seem to be running. I have checked in disk management but it dosen't appear in there either. i have also tried to use to another computers but it still does not work. any help would be great, cheers, Satya.....
    New Friend:
    Problem Solver:
  • 8 Answers
Ops fail if you have soft info on hdd and you need it nesesery take hime to maitenuse to help you for recovery but these very expensive
Posted on Apr 26, 2013
dodgecharger
  • 254 Answers
SOURCE: Maxtor external hard drive
I'd first check the unit on a second computer. If it does the same thing, then you likely have a defective unit
Posted on Sep 12, 2007
SOURCE: External Hard Drive No Longer Recognized
hey im the same person who just posted above. i went to WD's website, and it said unplug the hard drive from the computer, and unplug it from the power source. then plug it into the power outlet, wait for it to spin up, then plug it in via USB/Firewire, whatever. it worked for me, so hopefully it will work for you.
Posted on May 13, 2008
darkoh69
  • 77 Answers
SOURCE: Flashing blue light on external WD hard drive & not recognised
sounds like you are using the wrong power supply. Check the amp output on the power plug you plug into the wall make sure its the same as the amp input of your external harddrive
Posted on Jun 01, 2009
SOURCE: Flashing green power light
Spoke to maxtor. The blinking green light on the power cord is a problem with the external casing for the hard drive. Several of the posts talked about taking the case apart and connecting it to the pc to download information. I thought they were crackpots. After talking to the service tech on the website it looks like that is the only fix. So... based on all the posts with the same issue I may avoid this product line int he future. Hopefully it is truely a backup for you in which case toss the old one and buy a new ext. HD. If it isn't a backup take it apart gingerly, download the information, replace the hardrive.
Posted on Dec 19, 2009
Schmead10
  • 650 Answers
SOURCE: my new Toshiba STORE ART
Open your command prompt and format the drive type format volume [/fs:file-system]
volume: Specifies the mount point, volume name, or drive letter of the drive you want to format.
/fs:
file-system: Specifies the file system to use FAT, FAT32, or NTFS Floppy disks can use only the FAT file system.
Example.........FORMAT E: /FS:FAT32.....Press enter. E: is my second drive
Posted on May 19, 2011
Seagate 1tb hard disk not recognized
This is a hardware problem but since you can't access to the removable you have to order a new one making sure the warranty of your product is still valid
Aug 05, 2017 | Seagate FreeAgent Pro 1TB External USB...
2 TB G-Raid External Drive connected with Firewire cable is not recognised after Reboot my PC
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Mar 16, 2012 | Acomdata USB 2.0 2 TB External Hard Disk...
The light is on but the hard drive is not being recognized on the computer or the tv, it was dropped only once. there is a humming sound but no response. no more pictures or movies. is this possible to...
Good Day Daniellevion!
Have you seen a hard disk inside your computer? That is exactly what is inside in an external drive.
You mentioned that you dropped the external drive once, and that could be the reason why your computer was unable to recognized it as external drive.
Danielle! The connectors of the hard disk inside the Samsung External Drive (or other term is hard disk enclosure) might be loosened.
If you can open the enclosure and expose the two connectors, disconnect them and reseat properly.
That might fix it!
Jun 12, 2011 | Samsung G3 Station Desktop External Drive...
How do I disconnect (uninstall) a WD External Hard Drive from my computer? I am using a WD 3200AAK WD External Hard Drive and want to install a 1 TB WD External Hard Drive. I would like to use the old one...
External hard drives don't need any program installed on your computer to run. Your operating system Windows, Linux should handle it as soon as you plug the usb in your computer. The programs included in your WD external hard drive are tools to backup your data.
If you try to hook up your hard drive to a Windows prior to XP, maybe your computer will not handle it.
It is always safer to safely remove your drive using the green arrow icon in the lower right corner of your screen. This way, the drive is shut down properly and you minimize chances of fails when you plug it again on another computer.
Hope this helps!
Feb 08, 2011 | Western Digital My Book Essential Edition...
My desktop model is Compaq SR5213 with 250G harddisk. Recently, I would add a new internal hard disk (3.5", 1 TB), is it possible? As I don't want to buy a external hard disk. thanks
You can add 1 TB hard as additional to 250 GB Hard disk. You did not need to buy a external hard disk. Both hard disks will work together and make total hard disk space- 1.25 TB.
Aug 04, 2010 | Compaq Presario 5000 PC Desktop
Hi im sachin want to purchase 1 tb hard disk of cgate and LCD of ither samsung or sony.... 1. will support an external USB hard drive on this lcd's ? 2.is there any other type of hard disk i need to...
I do not know if the 1 Tb external hard will work on the USB ports on the LCD TVs.
What do you want to store on the 1 Tb USB hard drive and display on the LCD TVs?
Most LCD TVs can access USB memory sticks and display DVI movies (if supported by the TV), photos etc. that are stored on these USB memory sticks.
Try inserting an USB hard drive (borrow one if necessary, can be any capacity) into the USB port to see if it works before you decide to purchase a 1 Tb USB hard drive.
My suggestion would be to purchase a 1 Tb USB memory stick. This would out perform an external USB hard drive.
May 19, 2010 | Dell Dimension 3000 PC Desktop
Won't recognize drive
Have you checked the disk properties to see if the 400 GB of data is still showing. may be your data might be hidden foir some reason. can you give more details pls
May 05, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
External hardrive not recognized
Try a different cable between the computer and the drive.
Disassemble the casing, and remove the "internal" disk-drive.
If the USB-to-disk-drive adapter has "died", it's possible that the
disk-drive itself is intact, and your data will be intact.
Connect the "internal" disk-drive as a "slave" drive in a desktop computer, and see if it can be detected.
If it's dead, and it's still under warranty, then exercise the warranty.
Jan 04, 2010 | Acomdata 1TB Puredrive USB Esata 1 TB Hard...
Pc not recognizing drive when turned on
Maybe this can help you:
http://www.devicedriverfinder.com/blog/device-errors/external-hard-drive-troubleshooting
Have you tried the disk on a different system?
Jules
Apr 02, 2009 | LaCie Big Disk Extreme with Triple...
Hard drive not recognized
hi I am using Hitachi external hard disk with aluminum case. When I connect my hard disk with my PC it is not recognizing my hard disk. I want retrive my data from the hard disk please let me know the solutions.
Thanks,
K.Venki
Jan 07, 2009 | Computers & Internet
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
