Question about Viking VDSC365-6B Dual Fuel (Electric and Gas) Kitchen Range
Viking range creating a lot of soot?
M/n: vdsc3654qss
s/n: 082608c00056704
unit is burning a red-orange flame and it is creating a lot of soot.
  • 1,230 Answers
This is a definate sign of improper gas/air mixture. The flame needs to be even and blue.
Make sure the orifice is clean. Usually the burner (oven) will have a "Door" or "Shutter" type adjustment where you can turn it and add or choke off air. This is the primary air supply. The secondary air supply is usually supplied by louvers or vents close to the burner area.
Posted on Mar 13, 2009
My crosley gas stove oven has been converted to propane. My oven is now coated with a black soot inside. How can i fix this
Adjust the air mixture on the oven burner. This is a metal part where the brass orifice is mounted on the burner valve. You loosten the screw on the side of it enough to be able to slide it back and forth. Get a flame going and move the barrel until the tips of the flame in the burner is completely blue...no part of the flame should be orange. Once that is done tighten the screw . automotive brake fluid is an excellent soot cleaner. It smells bad so use it with a lot of ventilation.
Feb 24, 2015 | Crosley Kitchen Ranges
Flame burning too orange
You must get more air to water heater, and check venting .... immediate CO poison danger.
Call qualified plumber immediately.... because deadly carbon monoxide is not being vented properly.
http://waterheatertimer.org/Water-heater-safety-precautions.html#soot
Gene h
Mar 27, 2014 | Water Heaters
Help flames front of fryer
Hi there.
Try to check and clean if needed the fire tubes, soot may have build up inside blocking the flame path. Soot build up on fire tubes and burners are caused primarily by low gas pressure, assuming that the orifice size are correct with respect to the type of gas used.
Regards.
Sep 03, 2013 | American Range Kitchen Appliances - Others
SOOT PROBLEM CAUSED BY YELLOW FLAME
If they burn yellow then they are blocked IE lack of air causing flame to burn floopy yellow hence soot , clean burners and orfices to burners .
Mar 25, 2012 | Grilling
How do I adjust the air mix on Mod ES800 Btu All I get is white flame
I got one of those. I dont think there is an air adjustment. Let it burn awhile. It should glow somewhat red after some use. As long as its not creating black soot its fine.
Jan 20, 2011 | Uniflame 200209 Open Flame Patio Heater
Propane stove burns yellow & creates soot
clean the orfices and tubes and then if possible adjust your air mixture setting also
Sep 21, 2009 | Frigidaire FGB24S5A Gas Single Oven
Flames in the exhaust of my american range deef fryer
Is this a propane unit?If so the baffles get clogged with soot and burn.Let me know.
Feb 27, 2009 | American Range AF-25 Deep Fryer
Kenmore gas stove. Oven burns big flame which soots
The manifold needs to be cleaned and adjusted could have rust etc in it Not a good thing to do yourself unless you know what you are doing
Jan 24, 2009 | Frigidaire 30" Self-Cleaning Slide-In Gas...
Empire GWT-50 creating soot and sometimes flashs when starting
if it giving off soot then it is wrong it sounds like the air mixture is wrong and the flames are light back to the injector that would be the woosh , no heat er should give off soot if combustion is correct
Jan 09, 2009 | Empire GWT-50 Wall Mounted Panel Heater
Gas oven that cooks unevenly
clean your orifaces.
Also make sure that it's the correct stove for your gas type. If you're using a NG stove on Propane, you're wrong. It's making a lot of soot, and could potentially blow up your house. Stop using it until you're sure.
Dec 05, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Viking VDSC365-6B Dual Fuel (Electric and Gas) Kitchen Range Logo
268 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
