Question about NEC VT59 LCD Projector
Projector locked i have just bought a nec59 projector at auction and is displaying projector is locked enter key word witch i do not have as was sold to me sold as seen is there any way around this problem
Professional woodworker planer 13" (china made) bought at auction,(distributor ?)
go on the web and try distributors for this / maker . Don't be surprised if someone bought it back as luggage and sold it at auction because of the lack of back up people where you are.
Jan 17, 2013 | Tools & Hardware - Others
Svga vlp - es5 projector control key locked problem
Hello
Your projector is in security lock Enabled condition. If you have forgot the pascode . You can change the password by
Use the Menu'UP'/'Down' '<'/'>' buttons to enter the four digit pascode. The default password is "ENTER,ENTER,ENTER, ENTER". After this is entered, you can put in a new pasword. Therefore when you use this function for the first time, pleas input "ENTER" four times.
To cancel the security lock, press the Menu key, then turn OFF the "Security Lock" setting on the INSTALL SETTING menu.
If you call the customer service center because you have forgotten the password, you will need to be able to veryfy the projectors' serial number and your identity. The process may differ in other countries/regions. Once your identity has been confirmed, they will provide you a password. OK.
Oct 22, 2011 | Office Equipment & Supplies
How do you reset the lamp timer for a sony Bravia
Turn on the projector
press MENU (as show in picture step by step)
use down arrow key and select SETUP
press ENTER
use down arrow key to select LAMP SETTING
press ENTER
menu screen below will be appeared.
ON SCREEN display
setting for lamp replacement
Has the projection lamp been replaced?
YES NO
Select YES with left arrow key (yes is preselected)
press ENTER
ON SCREEN display
lamp replacement process is now complete
press ENTER
now exit the MENU with menu key and check the lamp timer
Feb 09, 2011 | Sony BRAVIA VPL-AW15 LCD Projector
When i turn on the video projector and send me this message"the panel keys are locked "
Your projector key panel locked you have two option to operate the projector
1 . Use remote control press MENU the menu window displayed.
use DOWN ARROW key and select SET SETTING.
press ENTER
use DOWN ARROW key to select PANEL KEY LOCK.
press RIGHT ARROW key to OFF the panel key lock
press ENTER and then press MENU key to exit the menu.
now you panel keys are working
2. If you loss your remote control then;
When the key panel lock is ON keeping the power key on the projector key panel pressed for 10 seconds turns the projector ON when it is in standby mode, and turns the projector to standby mode when the power is on. If you keep pressing the MENU key for about 10 seconds when the power is ON, the lock will be released and "panel key lock" is automatically set to OFF.
Feb 05, 2011 | Sony VPL-CS7 Multimedia Projector
How to change setting picture just opposite
If opposite means that you want to rotate the image or picture for projector mount in the ceiling.
KEYS location: (keys are located back side of the projector there is 2 keys 1 for menu and second is a joystick witch have 4 arrow keys and center press is a enter key)
Press MENU button to display the menu screen.
then use joystick UP and DOWN to select the OPTION menu. Press joystick for ENTER to display the option screen. Then press joystick UP and DOWN to select INSTALLATION.
Then press joystick RIGHT and LEFT to select your required image rotation there is four type of rotations.
1. FRONT DESK
2.FRONT CEILING
3.REAR DESK (A translucent screen is required for rear projection)
4.REAR CEILING (A translucent screen is required for rear projection)
If opposite means negative to positive so there is no any setting in your projector witch is chang your picture or image positive to negative.
Jan 21, 2011 | Panasonic PT-LB60NTE LCD Projector
My panasonic PTLB60NTE shuts down after couple of minutes when I use wireless mode. How can I solve this?
There is three indicators lights on the panel
1. lamp indicator.
2. temperature indicator.
3. computer input indicator.
If your projector shutdown itself without given any indication its mean that your projector function POWER OFF TIMER is on. You can off this function.
How: (two keys back side of projector one is menu second is a joystick witch have 4 arrow keys and center press is enter)
press MENU button to display the menu screen and then use joystick UP or DOWN to select the OPTION menu. press joystick to ENTER and then use joystick UP or DOWN to select POWER OFF TIMER use joystick RIGHT or LEFT to select DISABLE then press MENU two times to exit the menu.
If your projector shutdown itself with given any indication then
If LAMP INDICATOR flashing RED then lamp circuit failure its need to be repair or replace.
If TEMP INDICATOR flashing RED then the temperature inside and /or outside the projector is abnormally high.
CAUSE: The ventilation opening are covered. The room temperature is too high. The projector is located at high elevations (above 1400m)
REMEDY:clean the air filter. Remove the object from the ventilation openings or clear around the projector. Set the HIGHLAND option to ON
Jan 04, 2011 | Panasonic PT-LB60NTE LCD Projector
Keys mounted on projector got locked accidently
With System-Lock input window onscreen, press the "MENU", "ENTER", "ENTER", "MENU", "ENTER", "ENTER" and "MENU" keys, in this order,
on the remote controller.
Jun 17, 2009 | Sharp XR-30S Projector
My projector says all keys are locked.
Pls note down these procedures:
for forced Antitheft: press
MENU,ENTER,ENTER,MENU,UNDO,UNDO and MENU from the remote.
and for Forced disabling password is:
ON,+,-,ON,+,- and INPUT Buttons.
incase of any confusion you may call at +9814903739.
Viren
Nov 28, 2007 | Sharp Notevision PG-B10S Multimedia...
Accident, locking keys
you can unlock the projector as under:
Menu-enter-enter-menu-undo-Menu
press these keys within ten seconds as written in the order.
Viren
+919814903739
Nov 05, 2007 | Sharp Notevision PG-M20XU Multimedia...
NEC VT59 LCD Projector Logo
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
