Question about Nintendo Super NES Console
Trying to hook up having problems with connication ,need manual
I bought a super nintendo system ,cant figure how to hook it up with cable tv ,need a manual
  • 28 Answers
Okay... with limited information I'll give it a shot...
Depending on the age of your tv, sometimes they have multiple input options. Since you are referring to hooking it up with cable, I'm guessing that you are using a coaxle for your super nintendo. The easiest way to get it hooked up it to upgrade to a 3-prong AV cable. You can find them on ebay for about $2.
If you don't have any open inputs on your tv you will need to either continuously change what is connected to the tv (unlikely) or buy an RF switch from any store that sells electronics. I think they are running $20 or less now adays. (They are worth the cost because they allow you to connect DVD player, VCR, game component, etc all using one input on TV.)
Posted on Jan 18, 2010
Cant hook up dvd or super nintendo to newer visio flat screen?
The system is reasonably old and I don't think they work on newer screens, sorry
Jun 01, 2013 | Televison & Video
Snes red horizontal lines
When hooking a super Nintendo or an NES system or a sega genesis system to a digital tv you need av cables for it to work then instead of using an rf switch
Sep 30, 2012 | Nintendo Super NES Console
HELP - 2 Super Nintendos w/ Same Problems!
Well for the old consoles to work on digital tv's you need av cables instead of using a rf switch.
Jan 21, 2012 | Nintendo Super NES Console
I have the first nintendo nes and i dont have the rca's i have the one you hook through the cable and it comes on but i cant find the channel to put it on to play the game ! What am i doing wrong ?
Original-Style Super NES RF to TV Hookup
Installation Steps:
Locate the TV's VHF IN [ANT, CATV, or 75(ohm)] or Cable Connector.
Disconnect the existing cable wire from the TV's VHF IN.
Connect the short, thick wire from the RF Switch (labeled ANT) to your TV's VHF IN.
Reconnect the existing cable wire (disconnected in step 2) to the silver post labeled ANT on the RF switch.
Connect the thin wire of the RF Switch (labeled Control Deck) to the back of the Super NES (labled RF Out).
On the back of the Super NES, set the 3/4 switch so that it matches the channel of the TV.
Note: The RF Switch does not produce stereo sound. To get stereo sound, connect your Control Deck to your TV or VCR using the Stereo Audio/Video Cable.
After the system is connected to the TV:
Insert the Game Pak firmly into the Control Deck.
Plug the controller(s) into the front of the Control Deck. Use the far left port for a one player game.
Plug the AC Adapter into the back of the Control Deck. Plug the other end of the cord into a wall outlet.
Slide the Power Switch to the On position.
Turn on the TV and set it to the appropriate channel (3 or 4.)
The game image should now be displayed on the TV screen. You are ready to play!
If after following these directions you are not able to view the game, try our Troubleshooting Tips.
Nov 25, 2011 | Nintendo Super NES Console
I bought a ac adaptor to my super nintendo, because the adaptor that I'd is a fuckin' fail, so when I bought a new super nintendo adaptor, but I can't see anything on my tv. The conexion is ok. What's up!?
Note: pictured above is the redesigned Super NES. The original Super NES uses the same hookup steps listed below.
Installation Steps:
Locate the Audio/Video inputs on the back of the TV.
Place the yellow end of the Stereo AV cable into the Video "in" on the back of the TV. Connect the red end of the cable to Audio "in" Right. Connect the white end of the cable to the Audio "in" Left. Use a slight twisting motion when inserting each cable and ensure the cables are firmly pressed into the input.
Note: If you have a mono television with only one Audio input, click here for a diagram of how the hook-up will look. The Y-adapter pictured is optional; you can also simply leave the white cable disconnected instead.
Connect the rectangular (gray) plug of the Stereo AV cable into the "multi out" connector on the back of the Control Deck.
Plug the Controller(s) into the front of the system. Use the far left port for player one.
Plug the AC Adapter into the back of the system . Plug the other end into a wall outlet.
Slide the Power Switch on (toward Game Pak).
Turn on the TV and locate the input select. It is often called: input select, AUX (auxiliary), Line, Line In, Input, Source, Select, In, or EXT (external). Switch the input select to show the Nintendo game.
The game image should now be displayed on the screen. You are ready to play!
Oct 10, 2010 | Nintendo Super NES Console
What cord do I need to attach tv to super nintendo game system
Here is a tutorial to hooking up a super nintendo
http://www.youtube.com/watch?v=9O4kjcXyZKI
Oct 09, 2009 | Video Game Consoles & Games
Problems hooking up an original nintendo
super nintendo set up to a magnavox standard tv
Oct 02, 2009 | Nintendo Super NES Console
Game console
Should be yellow,red and white a / v inputs on front of tv =
hook-up there and select that input number.........T.
Nov 17, 2007 | RCA Scenium HD65W20 65" Rear Projection...
How do I install this to my TV
I do not think i fully understand your problem, do you have a game boy, the hand held system? or larger Gamecube? If it is the small game boy, You do not hook it to your system. there is an adapter that fits in the Super Nintendo System that will hold and Play game boy games. It is called Super BOY.
If it is game cube and has a/v audio/video plug ends, you need a converter from Radio shack that converts those 3 colored wires to the same cable the you use for your cable input to the tv.
Nov 04, 2007 | Video Game Consoles & Games
Nintendo Super NES Console Logo
170 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
