Question about Titan Air Tools & Compressors
Titan 440i wont turn on....
When i switch the titan ON the fan spins about a quarter turn and then just stop and does nothing. If I keep turning it off and on it will make the piston go down and up a little bit each time....not sure what it could be....any suggestions?
    Problem Solver:
  • 5 Answers
Your Transducer is shot the 440i has had this problem since inception. Now they are getting part made elsewhere. Your 440i has a four year warranty. it is covered the part if you dont have warranty cost 85.00 US. It is not a hard thing to replace on your own about 12 min. and your set.
Sincerely Steve Winters
Posted on May 29, 2009
My titan 440i primes but wont stop in priming when in spray position
I am not very familiar with airless sprayers but try this link to a youtube video...
https://www.youtube.com/watch?v=5DGUHwBmdaM
May 12, 2017 | Air Tools & Compressors
Jukebox AMI 80 made in 1955 turn table will not stop turning
Could be a defective switch. It there is a switch it would have been intended to open after the record returned.
Sep 22, 2016 | Audio Players & Recorders
My washer doesn't work right. It does not spin on any cycle. It will turn a quarter of a turn one way then the other way and so on.
Mine locked up. I had it laying on it's back as I rocked the tub back and forth, A penny fell out. works good now.
Apr 03, 2015 | Washing Machines
Is there a fuse in th 440i, keeps popping th breaker?
Check the brushes these motors for ever
You could also disconnect the pistion from the motor shaft the connecting rod to make sure the pistion is not the thing that is not moveing and binding the motor .
Most of the time problems come when people don't clean them correctly after use then store then for a few years .
Now I need my pump again except the old paint is now rock hard and nothing moves anymore the lines are cloged filters guns tips check valves .
All I know is my 660 titan witch is the same as the 440 except mine has flat valves instead if balls for check valves has been working great for the last 35 years but I clean it .
Jun 13, 2014 | Titan Air Tools & Compressors
Titan 640i wont prime
If you still have a problem with a Titan 640i please give us a call. We introduced this sprayer to the UK back in 1985. Lion Industries UK Ltd 01543 251 560
Dec 31, 2012 | Titan 440 Impact Airless Paint Sprayer...
440i wont stop spraying
Either your gun is dirty and the valve spring can't close the tip valve properly or the seat it pushes against is damaged. First try cleaning the gun very throughly. Take it apart and get everything out of the gun that doesn't belong there. If it still does the same thing you can buy a repair kits for the paint guns but they're usually expensive and you're almost always better off replacing the gun.
Sep 29, 2012 | Titan 440I Spray Guns
440i titan only pressure is between 0-200 psi no matter the setting
If an airless paint sprayer won't prime it's usually because one or both check balls are stuck. First try hitting the head where the pump is sharply with a hammer, hard enough to knock the balls loose but not so much that you do any damage to the pump. If that doesn't free them up you may have to take the pump apart and clean them and their seats.
If an airless paint sprayer won't develop pressure, it's usually because the packing rnigs are damaged or collapsed. The only way to check this is to totally disassemble the pump and check them. Also look for any damage to the piston and cylinder. They must be very smooth and shiney, if they are scored they will eat up any new packing rings you put in.
Jul 19, 2012 | Titan 440 Impact Airless Paint Sprayer...
Air Tools & Compressors Logo
1,486 people viewed this question
Top Titan Air Tools & Compressors Experts
JOHN LAPIER
Steve Pack
Steve Pack
Vernon Taylor
Are you a Titan Air Tool and Compressor Expert? Answer questions, earn points and help others
