Question about Electrolux UltraLux 2000 Bagged Canister Vacuum
How to reset?
The filter light came on, so I changed the filter, now how do you reset it? Cause the light stays on.
  • jerawdon Mar 23, 2009
    THe "Protection Light" came on. I checked and my bag was full. I changed the bag but the light stays on and the power will not come on. I had this problem in December and the UltraLux repair reset some button, but I cannot find that button. I recall the salesman saying that most people were not aware of the button. I do remember that he said it was there to ensure that the machine is not operated without a bag.
    Scholar:
  • 70 Answers
The button I think you are talking about is the bag switch. It is located in the bottom right corner where you put the bag. If the bag does not cover it, the machine will not run.
Also, when the machine cuts off when the bag is full, you have to push the power switch off and back on to reset the full bag switch located in the switch control housing inside the machine.
Posted on Apr 02, 2009
I have a Windsor Sensor s12 and power shuts off after 5 min. of vacuuming. I'm wondering if it's overheating of if there is some other sensor that causes it to shut off.
Your Sensor most likely has an internal heat sensor that is shutting off the motor. Some vacuums install an external heat sensor with a reset button that you must push to re-start the vacuum. If your model does not have an external reset button it is most likely a sensor inside the motor. If it is defective the motor must be replaced to solve the problem. But first make sure the overheating is not being caused by a blockage somewhere or the bag is too full. Air must pass completely through a vacuum starting at the floor where it picks up the dirt through all the canisters, filters, bags, etc. and then is exhausted from the vacuum. Any restrictions or blockage can cause the motor to over heat.
That Vac Guy
Jan 04, 2013 | Windsor SR12 Sensor Bagged Upright Vacuum
Nikken Air Purifier, Model NKAP100: Change Filter red indicator stays lit after new filter has been installed
Under the front panel, under and to the right of the control panel is two holes, one the size of a pencil eraser and below it is one the size of a dime. In the hole (the size of a dime), is a pin hole use a paperclip and poke the hole. It will reset the filter light. We had the same problem, and couldn't find the manual. Our Nikken rep was No help either.
Apr 20, 2011 | Vacuums
I have a Miele Silver Moon 558 and the red light is staying on saying reset - what do I do? - I do not have a manual. Thank you marilyn@drmelvin.com
well for the manual, you may download it from here. note that you will first have to give some kind of rating before download link activates. otherwise, light indicate when replacement exhaust air filter (key RESET) (after approx. 50 hours of operation, which corresponds more or less, an average use a year).
Jan 23, 2011 | Miele s558 Silver Moon Vacuum
Not sucking and the perfomance indicator light is on
check the filters to see if they are clogged and the check the hose for cloggs
Feb 02, 2010 | Vacuums
The red light on my hayden 3600 vacuum won't go off
I have a 6000 and it does the same thing. I simply unplug the unit and plug it back in after cleaning the filter and dumping the cannister. That seems to reset the warning system.
Jul 06, 2009 | Hayden Industries SuperVac 6000 Central...
Reset light is on.
set big Cat to stay on porch. (Smile)
Dec 07, 2008 | Miele CatAndDog700 Bagged Canister Vacuum
It just shuts off!
Some of these have the Hepa filter on the back, if so there will be a door to access it. If there is one, some had a reset button that you push, mainly for when you change the fifter, if it has one, push that reset, if it needs to be re-set, it will shut off after a seconds. Remove the Hepa filter and look see if there is a reset button. https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM, this will give you a link for a user manual. If you disconnect the hose, will it shut off or stay on. If it stays on then there is a clog either in the hose, wands, or the inlet down by the brush roll. If it goes off, and there is no reset by the Hepa filter, then there could be a problem with the motor or motor protector.
Jan 30, 2008 | Bosch BSA2200UC Compact Plus Health Guard...
Electrolux UltraLux 2000 Bagged Canister Vacuum Logo
479 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
