Question about Lenovo IdeaPad Computers & Internet
Lenovo laptop:check cable connection!
I had trouble with my hard drive. It used to say no bootable device and it would not be able to progress into the desktop. I had my computer repaired, and now ,When I start it, it says ''check cable connection!!'' ...but it does go further after that message ,and to the Windows 8 mainscreen,where I can use the computer normally, go to the internet, browse Windows..Except, It seems slower than before now. There is also a message saying ''RESTART TO REPAIR DRIVE ERRORS''! I have restarted already at least twice, and it says the same thing.. Thank you !
  • 1 more comment
  • Alain dood Apr 24, 2013
    I had my HDD replaced..
    I think my previous hard drive had sustained damage, as did my whole laptop. I think it was shock, like bang, but not BANG!!(with caps) If you get what I mean..
    Thank you! If you can, but you don't have to! I have a question! What is the hard drive cable?
  • Lenovo Master
  • 2,385 Answers
Deat
Replace the harddisk cable it will solve the issue
Posted on Apr 24, 2013
Lenovo b460 laptop
it sounds like you have a hard drive failure hopefully you have restore cds and you can change hard drive and install your restore cds
Aug 18, 2013 | Computers & Internet
When laptop says no bootable device
re-seat hard drive and check settings for boot devices in bios.
run ibm diagnostics and see if it is seeing the hard drive . if it is run the hard drive tests if they pass then you probably have misconfigured the bios settings somehow. if the hard drive is not found or fails the tests then im afraid your going to have to look in to an exspensive data reclamation service, your best bet there is go to the hard drive manufacturer or even ibm itself.
Jun 13, 2013 | Lenovo Computers & Internet
Acer Aspire one 722 windows 7 netbook. "Check cable connection" and "no bootable device--insert boot disk and press any key" are two common things appearing. The computer recognized hardrive, hardr
Hello, it looks like somehow the master boot record was erased from the hard drive, maybe viral? You mentioned the hard drive was recognized in the bios correct? If you need data from the hard drive the easiest way would be to pull the hard drive out and use an external hard drive enclosure to remove the data before you erase everything from the hard drive. If you dont need anything thing you can proceed to do a new install of Windows 7. Turn the computer on then hold alt and the f10 key to perform a factory recovery. This will erase everything and reinstall Windows 7. If this doesnt work then you will need a new hard drive and a bootable usb drive with Windows 7 on it. Hope this helps.
Feb 22, 2013 | Computers & Internet
After replacing hard drive still getting check cable connection no bootable device
you may need to enter the bios setup and change the setup for the hard drive from sata to ide connection then it should recognize the new hard drive then simply install windows to your new h/d
Dec 19, 2012 | Toshiba Satellite C655-S5082 Laptop
Loveno S10-2 - No bootable device found
Make sure your hard drive has higher priority in the boot options in BIOS. If it still doesn't boot then you will need to replace your hard drive. If it shows no hard drive in BIOS then the drive is most certainly bad and needs to be replaced.
Dec 02, 2012 | Lenovo IdeaPad S10-1211U Netbook
My laptop says no bootable device insert disk what is wrong?
NO BOOTABLE DEVICE When the PC cannot see a boot file/disk on either the hard disk or floppy drive it gives an error message "No bootable device. Insert boot disk and press any key" First thing, check to see if the is a floppy disk in the floppy drive, if so removes this disk. If there was no disk in the floppy drive then it may be a hard disk problem.
Check the BIOS to see if the hard disk is detected, if not open the case and re-seat the data cable on the hard drive and also where it connects to the motherboard disk controller.
If it still gives this error message and the BIOS does not detect this hard drive, then the hard drive is probably faulty.
A further check on the hard drive, remove the hard drive and connect it to an USB hard drive adapter and connect it to a working computer's USB port, if this computer does not detect it as an external storage device then the hard drive is faulty.
To get the computer operating again, install a new hard drive in your computer and then install Windows on this hard drive plus the computer's device drivers and your programs.
Oct 30, 2012 | Toshiba Computers & Internet
Why is my bootable device not found
It is more than likely the hard drive has issues, have the hardware tested for possible replacement.
Jul 27, 2012 | Acer Aspire One PC Notebook
My gateway says "Check cable connection!PXE-MOF: Exiting Intel PXE ROM. No bootable device--insert boot disk and press any key". What should I do?
Sounds like the hard drive isn't getting power,the data cable to the drive isn't connected,or the drive controller on the motherboard is toast(I'm a novice tinkerer,not an expert).
May 25, 2012 | Computers & Internet
Check cable connection! PXE-M0F : Exiting Intel PXE ROM. No bootable device
Your machine is trying to boot off a network and not the hard drive. You need to set it in BIOS to boot from the hard drive. If it cannot find a bootable device, then your hard drive or your operating system is defective or disconnected.
Sep 17, 2011 | Acer Computers & Internet
My toshiba lap top starts up as normal then the msg media test faiure and no bootable device whats wrong
The laptop isn't seeing the hard drive. It has either bounced loose (doubtful) or the hard drive is defective. You can open panels on laptop and find the hard drive, remove and then replace it and see if it reads. Failing this check to see if it's still on warranty or buy another one similar to yours.
Nov 27, 2009 | Computers & Internet
Computers & Internet Logo
104 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Lee Durbin
Lee Durbin
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
